Nintendo GameCube Controller Buttons Replacement
Introduzione
Vai al passo 1This guide will show you how to properly remove most of the buttons from the controller. You may want to read this if your buttons are sticky
Cosa ti serve
Place the controller (buttons down) on a solid surface.
Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
Gently lift the back panel up, separating it from the front panel.
For some reason, it was simpler to take the top half off, although it could be because it is most probably refurbished before
Grab the Z-button by the peg with tweezers and lift it out of the controller.
So how do you put it back in like the replacement because I have a controller I'm working a junker my Friend gave me and I'm trying to fix it the z button doesn't work here it's a pelican wireless controller it's actually not to bad bulky but not bad
Carefully unhook the cable that is looped around the peg.
Um can soneone explain the peg and cable part? I dont understand it...
I would say that the cable is somehow "hooked" to the case and you have to get the cable away from the case so that you can pull out the board
My1 -
Altre 19 persone hanno completato questa guida.
3Commenti sulla guida
Is there a way I can buy the buttons separably? I lost a the X button and it's gone missing and i wanna buy one :(
u can either get a 2 dollar full button set on ebay by searching ngc buttons or u can buy from battle beaver customs for 1 dollar
How do you put the back back on?
