Salta al contenuto principale
Nintendo 3DS 2015 D Pad Replacement
Tyler Starr
Tyler Starr e 2 altri collaboratori
Ultimo aggiornamento il 1 apr 2025
25 minuti
Moderato
Introduzione
Vai al passo 1
If you aren't getting full range of motion on the D pad replacing may fix it. Go slow. There are several delicate ribbons cables. Make sure that components are completely disconnected before you pull them apart.
Cosa ti serve
Strumenti
Mostra di più…
  1. Nintendo 3DS 2015 D Pad Replacement, Battery: passo 1, immagine 1 di 1
    • Unscrew the two 3mm Phillips #1 head screws along the top edge of the device.
    • The screws on the back panel strip easily. Go slowly and press down firmly.
    • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
  2. Nintendo 3DS 2015 D Pad Replacement: passo 2, immagine 1 di 2 Nintendo 3DS 2015 D Pad Replacement: passo 2, immagine 2 di 2
    • Pull the top corner tabs of the front face plate outward and towards you.
    • Pull the faceplate up and out of the slots at the bottom of the device.
    • Set aside the back faceplate.
  3. Nintendo 3DS 2015 D Pad Replacement: passo 3, immagine 1 di 3 Nintendo 3DS 2015 D Pad Replacement: passo 3, immagine 2 di 3 Nintendo 3DS 2015 D Pad Replacement: passo 3, immagine 3 di 3
    • Insert a plastic opening tool into the notch at the top of the battery.
    • Pry the battery up with the plastic opening tool.
  4. Nintendo 3DS 2015 D Pad Replacement, SD Card Reader: passo 4, immagine 1 di 1
    • Unscrew the three 3mm Y0 screws along the right and bottom of the SD card reader.
    • The bottom of the SD card reader should slightly pop out after removing the screws.
    Caution. My N3DS required a Y00 screwdriver.
    Phantom Kirby - Replica
  5. Nintendo 3DS 2015 D Pad Replacement: passo 5, immagine 1 di 1
    • Pull the SD card reader from the edge with two holes gently to free the tab at the top of the SD card reader.
    • Don't completely pull the SD card out of the device yet. There is a ribbon cable connected under the SD card reader.
    • Reorient the device so that the power jack faces you.
  6. Nintendo 3DS 2015 D Pad Replacement: passo 6, immagine 1 di 2 Nintendo 3DS 2015 D Pad Replacement: passo 6, immagine 2 di 2
    • Lift the SD card reader gently.
    • Use a plastic opening tool to pry the SD card ribbon cable off the socket on the motherboard.
    • Lift the SD card reader out off of the lower casing.
    Where can I buy a new SD card reader? Cant seem to find any.
    Aldair - Replica
  7. Nintendo 3DS 2015 D Pad Replacement, Lower Case: passo 7, immagine 1 di 3 Nintendo 3DS 2015 D Pad Replacement, Lower Case: passo 7, immagine 2 di 3 Nintendo 3DS 2015 D Pad Replacement, Lower Case: passo 7, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Reorient the device so that the game slot now faces you.
    • Remove the two rubber bumpers along the top of the device using tweezers.
    • Unscrew the seven 6mm Phillips #00 screws along the top and bottom of the 3DS.
  8. Nintendo 3DS 2015 D Pad Replacement: passo 8, immagine 1 di 2 Nintendo 3DS 2015 D Pad Replacement: passo 8, immagine 2 di 2
    • Lift the top edge of the lower case slightly off on the 3DS.
    • Don't pull the lower casing completely off, you may break those connections. There are ribbon cables that must be disconnected first.
    • Pry the ribbon cable socket under the right trigger using a plastic opening tool.
    • Pry the ribbon cable socket under the infrared receiver cover using a plastic opening tool.
  9. Nintendo 3DS 2015 D Pad Replacement: passo 9, immagine 1 di 3 Nintendo 3DS 2015 D Pad Replacement: passo 9, immagine 2 di 3 Nintendo 3DS 2015 D Pad Replacement: passo 9, immagine 3 di 3
    • Open the device slowly from its top edge. Be careful not to tug the ribbon cable connected near the bottom edge of the device.
    • Pry the last ribbon cable attached to the lower case using a plastic opening tool.
  10. Nintendo 3DS 2015 D Pad Replacement, Gamecard Reader: passo 10, immagine 1 di 2 Nintendo 3DS 2015 D Pad Replacement, Gamecard Reader: passo 10, immagine 2 di 2
    • Locate the gamecard reader near the bottom right corner of the motherboard.
    • Unscrew the four 3mm Phillips #00 screws along the edge of the gamecard reader.
    • Lift the black latch on the ZIF connector along the right side of the reader using a plastic opening tool.
  11. Nintendo 3DS 2015 D Pad Replacement: passo 11, immagine 1 di 2 Nintendo 3DS 2015 D Pad Replacement: passo 11, immagine 2 di 2
    • Pry the ribbon cable from its socket, just left of the joystick, using the flat side of a spudger.
    • Grab the right edge of the gamecard reader and lift it out of the device, watching to make sure the ribbon cables don't snag.
  12. Nintendo 3DS 2015 D Pad Replacement, D Pad: passo 12, immagine 1 di 2 Nintendo 3DS 2015 D Pad Replacement, D Pad: passo 12, immagine 2 di 2
    • Remove the four 3mm Phillips #00 screws from the four corners of the D pad board.
    • Lift the D pad board out of the device.
  13. Nintendo 3DS 2015 D Pad Replacement: passo 13, immagine 1 di 2 Nintendo 3DS 2015 D Pad Replacement: passo 13, immagine 2 di 2
    • Peel the rubber piece, backing the D pad, out of the device.
    • Lift the D pad out of the device with a pair of tweezers.
Conclusione
Preparati per le riparazioni future
Acquista tutti
Tyler Starr
Membro da: 10/06/16
1.696 Reputazione
7 Guide realizzate
Cal Poly, Team 4-6, Livingston Fall 2016 Membro di Cal Poly, Team 4-6, Livingston Fall 2016
CPSU-LIVINGSTON-F16S4G6
4 Membri
40 Guide realizzate
4Commenti sulla guida
I think you missed a few steps after step 9. There is no mention of removing the 3DS Cartridge reader or Circle Pad.
jharris - Replica
Jharris is right
Birby B. - Replica
Thanks for pointing that out! I think it is fixed now.
-Tyler
Tyler Starr -
My new 3DS d-pad is stuck in the up direction, what could be the problem?
Flute_Boi - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 29
Ultimi 30 Giorni: 102
Tutti i Tempi: 4,674
