Salta al contenuto principale
Nikon Coolpix AW130 LCD Screen Replacement
Lauren Stepp
Lauren Stepp e 2 altri collaboratori
Ultimo aggiornamento il May 7, 2024
40 minuti
Difficile
Introduzione
Vai al passo 1
Without the LCD screen, you cannot preview your nifty vacation photos. If this screen is cracked, the waterproof qualities of the Nikon may be sacrificed. Allowing water to infiltrate into the body can cause for additional problems.
Cosa ti serve
Strumenti
Mostra di più…
  1. Nikon Coolpix AW130 LCD Screen Replacement, Battery: passo 1, immagine 1 di 2 Nikon Coolpix AW130 LCD Screen Replacement, Battery: passo 1, immagine 2 di 2
    • Using your thumb and pointer finger, open the card/battery hatch by pressing the center button of the wheel and turning the entire wheel to the left.
    • When reassembling, you must turn this wheel to the right until it clicks.
  2. Nikon Coolpix AW130 LCD Screen Replacement: passo 2, immagine 1 di 2 Nikon Coolpix AW130 LCD Screen Replacement: passo 2, immagine 2 di 2
    • You should feel the door begin to loosen. Carefully pull the hatch open.
  3. Nikon Coolpix AW130 LCD Screen Replacement: passo 3, immagine 1 di 1
    • Push the yellow battery/charger compartment tab up using your thumb nail.
    This yellow tab spring broken, how I can repair
    Surendra kumar - Replica
    From where I can get this yellow tab, and how I can replace
  4. Nikon Coolpix AW130 LCD Screen Replacement: passo 4, immagine 1 di 2 Nikon Coolpix AW130 LCD Screen Replacement: passo 4, immagine 2 di 2
    • After pressing the yellow tab, the battery should loosen.
    • Slowly pull the battery completely out.
  5. Nikon Coolpix AW130 LCD Screen Replacement, Back Panel: passo 5, immagine 1 di 2 Nikon Coolpix AW130 LCD Screen Replacement, Back Panel: passo 5, immagine 2 di 2
    • Using the T5 Torx screwdriver, remove all four 4mm screws.
    It's a T4 on both my cameras
    Daniel Bardua - Replica
  6. Nikon Coolpix AW130 LCD Screen Replacement: passo 6, immagine 1 di 1
    • Using a Phillips #000 screwdriver, remove the single 3mm screw found inside the battery/charging compartment.
  7. Nikon Coolpix AW130 LCD Screen Replacement: passo 7, immagine 1 di 1
    • Remove the upper cover (connected by glue) and unscrew the single Philips screw.
    Start with a metal spuge from the buckle on the lens-side and work your way from there.
    Its not necessary to remove the whole thing - cause the side on the other buckle tends to break.
  8. Nikon Coolpix AW130 LCD Screen Replacement: passo 8, immagine 1 di 2 Nikon Coolpix AW130 LCD Screen Replacement: passo 8, immagine 2 di 2
    • Remove two Philips screws from the bottom cover, lift gently the cover and remove the single Philips screw under it.
    In the case of my camera, I had to move the plat that says “EAC…” to the side. Underneath was another small Philips screw that I had to remove before I could take off the back panel
    marcelzarrouk - Replica
  9. Nikon Coolpix AW130 LCD Screen Replacement: passo 9, immagine 1 di 1
    • Carefully remove the back cover from the camera body.
    Hi, do you have a photo of the back panel but inside, my camera it's cracked in the GPS. Pleaseeeeee
    Gon - Replica
    Merci Tutoriel parfait
    Patrick M
    Patrick Malot - Replica
    The back cover is connected to the main board with two flexible flat cables (FFC). The connectors on the board have lids that lock the cables, so first lift the lids with a plastic tip, then tear the cable with no force aut of the connector.
    Christoph Kunz - Replica
    bonjour , pour ma part le capot ne se retire pas , il semble encore retenu au niveau de la vis centrale du capot inferieur alors que j'ai retiré toute les vis !!! merci de m'eclairer
    gregory bernard - Replica
  10. Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: passo 10, immagine 1 di 3 Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: passo 10, immagine 2 di 3 Nikon Coolpix AW130 LCD Screen Replacement, LCD Screen: passo 10, immagine 3 di 3
    • Using a Phillips #000 screwdriver, remove all 11, 4mm screws on the LCD screen cover.
    • Two screws are located on the right.
    • The remaining screws are hidden behind a connector ribbon on the left.
  11. Nikon Coolpix AW130 LCD Screen Replacement: passo 11, immagine 1 di 2 Nikon Coolpix AW130 LCD Screen Replacement: passo 11, immagine 2 di 2
    • Pull the LCD screen from the plastic frame after removing all of the screws.
  12. Nikon Coolpix AW130 LCD Screen Replacement: passo 12, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Using a pair of tweezers from the precision tweezer set, carefully remove the screen from the metal frame.
    • Since the tweezers could shatter the screen, causing for broken glass, exercise extreme caution.
Conclusione
8Commenti sulla guida
Hi.
Where can you buy a replacement screen?
Ben - Replica
Hi.
my contact is josem6073@gmail.com
Thank you .
Jose Martins - Replica
Please add Torx T5 screwdriver at the tool needed, required at step 5
macreateur - Replica
Hi.
my contact is cpapacon@gmail.com
Thank you .
Costis Papaconstantinou - Replica
Hi.
my contact is Keithdurkan@gmail.com
Thank you .
Keith Durkan - Replica
What appears to be the most difficult step —Step 7 —has its critical parts skipped over: how to carefully remove the top cover from its glued surfaces without breaking it. What tool is used? Where does one start the process? Are there particularly vulnerable sections where caution should be used to avoid breaking the cover?
Also not included are the instructions for replacing the top cover and making sure it stays in place. If it is re-glued, what type of glue is used?
Other than that, the instructions are clear and beautifully illustrated.
Peter Jursik - Replica
Mas falta vocês dizerem onde se compra uma tela nova , ou usada e outras peças , seja do que for
Cari - Replica
Mesmo assim obrigado por tudo
Cari - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 34
Tutti i Tempi: 3,176
