Salta al contenuto principale
Nikon COOLPIX P7700 LCD Screen Display Replacement
Matthew Seidel
Matthew Seidel e 8 altri collaboratori
Ultimo aggiornamento il 1 lug 2024
20 - 40 minuti
Moderato
Foto Azione
Introduzione Migliore
Introduzione
Vai al passo 1
This guide explains how to replace the Nikon COOLPIX P7700 LCD display screen.
There may be problems or damage done to a Nikon COOLPIX P7700 LCD display screen. It could be scratched, broken, or damaged in any number of ways. This guide will help you replace the screen in just six steps and your camera will look brand new!
Cosa ti serve
Strumenti
  1. Nikon COOLPIX P7700 LCD Screen Display Replacement, LCD Screen Display: passo 1, immagine 1 di 2 Nikon COOLPIX P7700 LCD Screen Display Replacement, LCD Screen Display: passo 1, immagine 2 di 2
    • Push down and slide the lock of the battery compartment to the unlock position.
    • The battery door should pop open.
    • Remove the battery.
  2. Nikon COOLPIX P7700 LCD Screen Display Replacement: passo 2, immagine 1 di 1
    • Open the camera LCD screen so it's away from the body of the camera.
  3. Nikon COOLPIX P7700 LCD Screen Display Replacement: passo 3, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the 4.3 screw on both the top and bottom of the screen's casing.
  4. Nikon COOLPIX P7700 LCD Screen Display Replacement: passo 4, immagine 1 di 2 Nikon COOLPIX P7700 LCD Screen Display Replacement: passo 4, immagine 2 di 2
    • Place the camera lens-side down and twist the screen so that it is perpendicular to the camera.
    • Remove the 4.3 mm screw on the side of the casing using the Phillips #00 screwdriver.
    • Twist the screen in the other direction and remove the other 4.3 mm screw.
    • These screws are very brittle! Be careful not to strip the screws. If you find that one has become stripped, follow this guide.
  5. Nikon COOLPIX P7700 LCD Screen Display Replacement: passo 5, immagine 1 di 1
    • Remove the case from the screen.
  6. Nikon COOLPIX P7700 LCD Screen Display Replacement: passo 6, immagine 1 di 1
    • Replace the LCD display.
    OK, OK…but how to remove the display itself????
    P.L. Pajzs - Replica
    OK. OK…but how to remove the display itself?????
    But the ribbon cable goes into the camera ... that's only half the repair ... what's the point?
    lothar4460 - Replica
Conclusione
Altre 3 persone hanno completato questa guida.
1Commento della guida
Do NOT follow this guide. There are numerous details left out of step 6 and there’s no troubleshooting guide. Most importantly, there’s no warning that this kind of repair really isn’t meant to be done by laypeople and that it’s to be done at the user’s own risk. These instructions don’t equip someone for this delicate task that, if done wrongly, can waste a lot of time and damage the camera, as happened in my case.
Alan Green - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 29
Tutti i Tempi: 1,707
