Salta al contenuto principale
Nexus 9 LCD Screen Replacement
Kelsey Rodriguez
Kelsey Rodriguez e 5 altri collaboratori
Ultimo aggiornamento il 30 giu 2022
2 ore
Molto difficile
Necessarie Più Immagini
Introduzione
Vai al passo 1
This guide will take approximately two hours, and involves the use of the iOpener for the adhesive located inside the board to be removed. In addition, all components of this device must be removed before the LCD can actually be removed.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Nexus 9 LCD Screen Replacement, Rear Case: passo 1, immagine 1 di 3 Nexus 9 LCD Screen Replacement, Rear Case: passo 1, immagine 2 di 3 Nexus 9 LCD Screen Replacement, Rear Case: passo 1, immagine 3 di 3
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
    • The rear-facing camera seems to fit a little too snugly in its compartment on the rear case; so make sure that it stays connected to the motherboard.
    Just removed the cover. On mine, there is a piece of double sided tape, 2"x1", bottom middle, sticking the back cover to the battery. The battery pack's black skin ripped as I pulled the cover off. I was able to peel the skin from the tape and reposition on the batteries. Don't think this black skin is nothing more then a way to print branding and other texts onto the batteries.
    Sccoaire - Replica
    Same here. Ridiculous!
    rexograph143 -
    I can confirm that the camera does fit very snugly into back cover.
    Start by prying off the cover from the end opposite the camera. When you get near the camera lens, press the lens gently into the body as you continue to release the cover.
    Graham Taylor - Replica
    Careful pressing that lens into the body, though, because the lens is actually attached to the back cover, not to the camera module (stupid, frankly). It is def a good idea to work from the other corner around, though.
    Drew Rushmer - Replica
  2. Nexus 9 LCD Screen Replacement, Front Facing Camera: passo 2, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use a spudger to disconnect the front-facing camera ZIF connector.
    • Use a pair of tweezers to gently lift the front-facing camera up from the motherboard.
    Use spudger to flip white part of connector forward (towards camera). Then use tweezers to pull camera upwards and towards edge of case. It will slide right out.
    Darryl Whitmore - Replica
  3. Nexus 9 LCD Screen Replacement, Battery: passo 3, immagine 1 di 2 Nexus 9 LCD Screen Replacement, Battery: passo 3, immagine 2 di 2
    • Carefully peel up the copper shielding with your fingers.
    • Before fully removing the copper shielding, make sure that the blue antenna cable is out of the way of the copper tab.
    On mine, the copper shield is smaller then shown in this picture. It does not cover the battery connector, hence you don't need to remove the copper shield to remove the battery.
    Sccoaire - Replica
    Ditto. My theory is that ours were later model Nexus 9s produced after this ifixit featured this product!
    rexograph143 -
    Sur certains modèles, la feuille de cuivre est sous la batterie et n'a pas besoin d'être enlevé.
    Rohanec - Replica
    To reinstall the heat shield use E6000 adhesive. It's good up to about 185 Fahrenheit. Apply a very thin coating to the heat shield. Install and Put some weight on the heat shield and let cure for 16 hours.
    M Gasque - Replica
  4. Nexus 9 LCD Screen Replacement: passo 4, immagine 1 di 1
    • Using the spudger tool, carefully remove the bottom of the battery from it's location below the logic boards.
    • The battery is attached to the motherboard with some adhesive, so you may need an iOpener to loosen up the adhesive. Check out the iOpener guide for info on how to do it.
    • Do not pull the battery from the tablet yet, as it is still connected to the motherboard.
    On my tablet, it was not glue, but double stick tape along the both long sides. I used the iOpener, which I laid along the sides. (My iOpener had printed on it, “Wait 10 minutes before reheating again.”) I slowly peeled the tape off of the battery. The copper shielding was below the battery. I carefully peeled the tape up in hopes of reusing it.
    Gregg Ferry - Replica
    On mine, the battery was held by two strips of double stick tape. My iOpener helped. (my iOpener had written on it, “Wait 10 minutes before reheating again. ) As I lifted the battery, I peeled the tape away from it. Then I peeled up the tape in hopes of reusing it.
  5. Nexus 9 LCD Screen Replacement: passo 5, immagine 1 di 1
    • Now remove the metal clip covering the battery's connector cable located above the top left of the battery with the spudger.
    • After the metal clip is wiggled free, the battery's connector cable can be easily removed by just gently tugging it free.
    Use spudger to apply light pressure to right (as seen in picture above) side of clip near the board. Right side of clip will spring left and up. Use tweezers to lift clip upwards and to the right. It will come right out.
    White battery connector lifts straight up to disconnect.
  6. Nexus 9 LCD Screen Replacement: passo 6, immagine 1 di 1
    • The battery should now lift free of the tablet.
    Again, on my Nexus 9, were I trying to actually remove the battery, it is double side taped to the frame. The battery’s casing would be further torn to shreds, should I try to remove it.
    Good thing I’m just trying out a XDA repair for the “white/pixellated screen-150 decibel scream issue” that seems to be plaguing N9s nowadays, which involves cleaning the battery contacts. I may just have to replace it now, should it’s performance get any worse.
    (It’s almost as if HTC wants the battery to be seriously damaged if replacement is attempted.)
    rexograph143 - Replica
    It isn't necessary to remove the battery from device to replace the mobo. Ensure you've disconnected the power cable from the MoBo and you will be fine.
    Arcade - Replica
  7. Nexus 9 LCD Screen Replacement, Antenna Board: passo 7, immagine 1 di 2 Nexus 9 LCD Screen Replacement, Antenna Board: passo 7, immagine 2 di 2
    • This step is not necessary if you have already removed the battery.
  8. Nexus 9 LCD Screen Replacement: passo 8, immagine 1 di 1
    • Unscrew the three 3 mm Torx T5 screws on the antenna board.
    • This step and the next show the battery removed, but it is not necessary to remove it if you are only replacing the antenna board.
    The antenna board is tricky to reinstall. The board must be jammed against the stop above the left most screw in the middle of the tablet, and then slipped under the holder toward the middle top of the board. This board drives the speaker beneath it and if it is above the stop the speaker might not work correctly and the back cover will not fit like it should.
    M Gasque - Replica
  9. Nexus 9 LCD Screen Replacement: passo 9, immagine 1 di 1
    • Use your fingers or a pair of tweezers to disconnect the blue antenna cable from the motherboard.
    • When reinstalling the antenna, be sure to clean it with a degreaser such as windex or isopropyl alcohol. The oils on your fingers have the potential to create wireless interference.
    • The antenna board should now lift free of the motherboard.
    If you happen to own a Nexus 9 LTE model, I strongly suggest that you take a photo of the exposed back (i.e. with the rear cover removed) and all wires still in place. You will later find that the LTE model differs in terms of daughter boards used, apparent connection points, number of wires used, and most importantly the way the wires even connect various components. At that point, you will also find that guides that cover the WiFi-only model are useless, for said reasons. You will additionally find that the only guides that are commonly accessible cover only that model. Lastly, before you replace any of the boards, I also strongly encourage you to compare the photo you will have taken to any replacements, to ascertain that they are compatible (to get you started: you will note a connection point on the daughter board that houses the micro-USB connector present in the LTE edition and absent (although the board does contain the solder points forming a circle) in the WiFi edition).
    poser1999 - Replica
    These antenna connectors are very fragile and if crushed are toast. I go out of my way never to disconnect them unless absolutely necessary. I take the antenna board the cable and the main board out as one piece and keep it that way.
    M Gasque - Replica
  10. Nexus 9 LCD Screen Replacement, Speakers: passo 10, immagine 1 di 1
    • Use a spudger or your fingers to remove the first speaker. The speaker may be heavily glued in and require heat to lift. Be careful as you can pull the speaker apart.
    My speaker was kind of glued in place and I hosed it pulling it out. Take something really pointy (tweezers?) to lift it out from the right side.
    The speaker by the charging port is easier to take out. I'd skip the one by the main board until you see how to do it on the charging port speaker. I also ripped apart the CPU speaker and you will probably destroy it as well. Get a replacement set from parts4repair.com which costs about $9 with shipping. Or check eBay.
    M Gasque - Replica
  11. Nexus 9 LCD Screen Replacement: passo 11, immagine 1 di 1
    • Disconnect the two ZIF connectors attached to the daughterboards.
    • Gently pull on the ribbon cable to remove it.
    Mine had an additional 3rd ZIF cable and an antenna cable.
    This is the USB charging board. There are three connectors on it. Remove all ribbon cables by rotating the white part of the connector up.
    M Gasque - Replica
  12. Nexus 9 LCD Screen Replacement: passo 12, immagine 1 di 2 Nexus 9 LCD Screen Replacement: passo 12, immagine 2 di 2
    • Remove the two 3mm T5 Torx screws securing the metal USB port bracket.
    • Use your fingers or a pair of tweezers to remove the bracket.
  13. Nexus 9 LCD Screen Replacement: passo 13, immagine 1 di 3 Nexus 9 LCD Screen Replacement: passo 13, immagine 2 di 3 Nexus 9 LCD Screen Replacement: passo 13, immagine 3 di 3
    • Unscrew the two 3mm T5 Torx screws securing the daughterboard to the device.
    • Use a pair of tweezers to disconnect the vibrator cable. It will lift straight up from the daughterboard connector.
    • Use your fingers to lift the daughterboard upward and out of the device.
    On mine, the vibrator connector slide away from the daughter board
    Mine had an additional antenna black cable.
    The button battery looking thing is the vibrator. I pryed it out and left it connected to the daughter board. The ribbon cable connects to the orientation gyroscope, very gently pry it up.
    M Gasque - Replica
  14. Nexus 9 LCD Screen Replacement: passo 14, immagine 1 di 1
    • The daughterboard has an orange ribbon cable that is adhered to the device. Gently pull the ribbon up and remove the daughtboard.
    Mine was held with tenacious double stick tape. Better to pry up the board with pointy (tweezers?)
  15. Nexus 9 LCD Screen Replacement: passo 15, immagine 1 di 1
    • Use a spudger to remove the second speaker.
    Mine was held in place with a perfectly cut piece of tenacious double stick tape. I pried it up with the pointy (tweezers?)
  16. Nexus 9 LCD Screen Replacement, Vibrator: passo 16, immagine 1 di 2 Nexus 9 LCD Screen Replacement, Vibrator: passo 16, immagine 2 di 2
    • Use a pair of tweezers to remove the vibrator from the device.
    My vibrator was held in place with tenacious double stick tap. I bent my tweezers; use a pointed knife instead.
  17. Nexus 9 LCD Screen Replacement, Motherboard: passo 17, immagine 1 di 2 Nexus 9 LCD Screen Replacement, Motherboard: passo 17, immagine 2 di 2
    • Remove the three 3 mm T5 Torx screws.
    • Remove the five 2 mm Phillips #000 screws.
    For the Phillips screws, I found Phillips #00 to be a better fit.
    In mine, the mother board exended all the way to the right. Two of the phillips screws held the SIM slot daughter board and connected to the motherboard with a ZIF connector. Next the the SIM board was a white antenna cable.
  18. Nexus 9 LCD Screen Replacement: passo 18, immagine 1 di 2 Nexus 9 LCD Screen Replacement: passo 18, immagine 2 di 2
    • Using your fingers, pull up on ribbon connector to expose another ribbon connector below.
    • Remove the two 2 mm Phillips #000 screws on top of the second ribbon connector.
    • Pull up the ribbon connector with your fingers.
    The top ribbon cable goes to the (now) right daughter board and the ZIF connectors were already opened. The bottom ribbon cable is connected kind of underneath the second daughter board. This is a ZIF connector and one would lift the black (on mine) part that would be away from the disassembler.
    I use a plastic leverage tool to remove the ribbons from their connectors. The upper ribbon goes to the charging board. The lower ribbon goes to the LCD display. At the connector on the LCD display, lift the BLACK part of the connector to remove the LCD cable.
    M Gasque - Replica
  19. Nexus 9 LCD Screen Replacement: passo 19, immagine 1 di 1
    • Gently lift the motherboard up from the device.
    I also had to remove the volume up/down rocker that was attached to the old motherboard with a connector and an adhesive strip. Remove this and transfer to the new motherboard before beginning to install the new motherboard.
    On mine, the copper shielding was still attached. I wish I had left it attached. I slide a spludger from the right to get the board up.
  20. Nexus 9 LCD Screen Replacement: passo 20, immagine 1 di 1
    I don't understand by what it means transfer it to the new one? I only want to replace the display and LCD.
    Rashmi Goonasekera - Replica
  21. Nexus 9 LCD Screen Replacement, USB Daughterboard: passo 21, immagine 1 di 1
    • Remove the single 3mm T5 Torx screw.
    • Use a spudger to disconnect the display ribbon cable ZIF connector.
    • Gently lift the USB daughterboard up from the device.
    I lifted at the USB connector first.
  22. Nexus 9 LCD Screen Replacement, LCD Screen: passo 22, immagine 1 di 2 Nexus 9 LCD Screen Replacement, LCD Screen: passo 22, immagine 2 di 2
    • Use a spudger or your fingers to remove the LCD connector from the display assembly.
    The small ribbon cable and connector in the photo are actually the touch screen connector and ribbon cable. The LCD connector is to the far left on the LCD assembly itself.
    M Gasque - Replica
  23. Nexus 9 LCD Screen Replacement: passo 23, immagine 1 di 2 Nexus 9 LCD Screen Replacement: passo 23, immagine 2 di 2
    • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
    • Place the iOpener in the center of the microwave.
    • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
    To be honest, removing the touch screen from the LCD is extremely difficult because of the optically clear adhesive (OCA) that is used to bond them together. In most cases the LCD is also destroyed. If possible get the LCD touch assembly together either with or without a frame. Being an older tablet this is becoming very difficult and expensive. I bought one from Mobieparts in Europe on September 25th 2023. They had two in stock and I bought one. It cost me $93 with shipping but came with the assembly mounted in a frame. I just had to swap my parts into the new frame. The LCD and touch worked perfectly. I highly recommend them.
    M Gasque - Replica
  24. Nexus 9 LCD Screen Replacement: passo 24, immagine 1 di 1
    • Heat the iOpener for thirty seconds.
    • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
    • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst.
    • Never touch the iOpener if it appears swollen.
    • Always wait at least three minutes before reheating the iOpener.
    If all you want to do is remove the LCD touch assembly from the frame, remember that the frame should not be warped or twisted so that the new assembly will fit properly. Heat will soften the adhesive of the assembly to the frame and careful light application of mineral spirits will also tend to break down the adhesive to the frame. Use the spirits to clean the frame of all residual adhesive.
    M Gasque - Replica
  25. Nexus 9 LCD Screen Replacement: passo 25, immagine 1 di 1
    • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
    • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
  26. Nexus 9 LCD Screen Replacement: passo 26, immagine 1 di 2 Nexus 9 LCD Screen Replacement: passo 26, immagine 2 di 2
    • Place the iOpener on the sides of the LCD where the adhesive is located beneath.
    • Let the iOpener sit for at least a minute to soften the adhesive beneath the glass.
    • This should be repeated for every side of the tablet, and each side will most likely need to be heated more than once.
  27. Nexus 9 LCD Screen Replacement: passo 27, immagine 1 di 3 Nexus 9 LCD Screen Replacement: passo 27, immagine 2 di 3 Nexus 9 LCD Screen Replacement: passo 27, immagine 3 di 3
    • Using the picks located in the iOpener Kit, insert the picks into the corners of the tablet, and move it back and forth along the sides of tablet.
    • Do this for every corner of the tablet until it is possible to pull the LCD from the display assembly with your finger.
    • Carefully remove the LCD from the display assembly because there is a ribbon located at the bottom that could be ripped with force.
    • The LCD should come completely free from the back assembly now by just leading the ribbon through the opening in the display assembly.
    Almost impossible to avoid ripping the touch ribbon cable from the display. Much too much adhesive in the way. Buy an LCD / touch assembly with or without a frame when you destroy yours.
    M Gasque - Replica
Conclusione
Altre 6 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Cal Poly, Team 19-11, Maness Winter 2015 Membro di Cal Poly, Team 19-11, Maness Winter 2015
CPSU-MANESS-W15S19G11
5 Membri
9 Guide realizzate
2Commenti sulla guida
What if the glass is broken and the lcd seems fine? Can I just get a new piece of glass and do the heating/pick steps?
Weston S - Replica
So I replaced the lcd abd glass but it won't display any thing when I turn it on I get haptic feedback and the led turns on but nothing on the screen I plugged it in and no battery charging display either I checked yto make sure the screen was not damaged in anyway what could be the problem ? I followed your guied to the letter ???
kanif88 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 24
Ultimi 30 Giorni: 52
Tutti i Tempi: 15,140
