Nest Learning Thermostat 2nd Generation LCD Screen Replacement
Introduzione
Vai al passo 1The replacement of the LCD screen is not difficult. The tools need to replace it are the plastic opening tools.
Cosa ti serve
Grasp the display's metal outer ring with your fingers and pull directly away from the wall.
Turn the display over.
Remove the four 6 mm screws from the back of the display using a Phillips #0 screwdriver.
Pinch the gray 20-pin connector with your fingers and pull directly away from the display.
I pinched the connector and it will not pull out
I’m my case, the white backplate cannot be pulled until it is turned about 1cm counterclockwise to disengage the brackets that hold to the internal plate. To do this, yo need to hold the front of the Nest with the metal frame (so the it doesn’t turn), while turning the backplate.
And in my case, there are only 2 screws (in the 9 and 3 o’clock positions) and not 4 as shown in the photo.
Locate the blue pull tab at the end of the ribbon which says, "1. Pull".
Grasp the tab with your fingers and pull directly away from the motherboard.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Locate the blue tab which says, "2. Pull".
Use tweezers to pull the battery up and away from the display.
Locate the blue tab which says "3 unplug".
Grasp the battery with your fingers. Pull gently directly away from the display to unplug the battery from the motherboard.
Grasp the battery with your fingers and pull directly away from motherboard to separate the battery from the display.
Same question
At least say the tipe of battery that's needed.
I just ordered the battery model specified. When it arrived, I realized it doesn’t have the same specs as the battery that comes with the thermostat.
The part listed (TL284443) is 3.7 VDC, but it is only is 380mAh (1.41 Wh) (if you zoom in on the image when you click “Buy”, you can see)
You can clearly see in the tear-down that the battery that comes with the thermostat is 2.1 Wh.
It might work as a replacement, but doesn’t have the same capacity.
To be fair, most people don’t know that there are different generations of the Nest Thermostat and clearly they didn’t read that this was for the 2nd generation Nest Thermostat. Probably should have been pointed out in the instructions more clearly for those folks. Then they wouldn’t have been so confused about the battery voltage differences.
I am a 64 year old woman, I had the Nest next generation installed last year. So far it keeps telling me that the connection to my wi-Fi is not working and now it’s saying the battery is dead. I’ve gone through all the steps to re-connect to wi-fi to no avail. Could this be because the battery needs replacing?
It’s 68 degrees in my house now and that’s thanks to my fireplace not this horrible device. I am going back to the regular thermostat, what a waste of hard earned money.
Remove the four 3mm screws with a #0 Phillips screwdriver.
Remove the one 4mm screw located at the edge of the auto-away sensor. Use a #0 Phillips screwdriver.
Lift the auto-away sensor from motherboard using tweezers.
Peel the copper foil gently from the EMI shield.
Remove one 4 mm screw from the motherboard using a #0 Phillips screwdriver.
Remove the EMI shield from the motherboard using the plastic opening tools.
Unsnap the LCD ribbon from the motherboard gently using the tweezers.
Locate the black tabs that hold the display to the motherboard.
Push the black tabs gently away from the motherboard using the plastic opening tools.
Push the crescent shape bottom of the display away from the plastic frame using the plastic opening tools.
What is that crescent plastic part for?
My gen 3 seems to be bubbling and not flat
Pry the LCD screen gently from the plastic frame using the plastic opening tools.
Pull the LCD screen away from the plastic frame gently using your fingers.
Altre 8 persone hanno completato questa guida.
5Commenti sulla guida
Thank you for providing this tutorial. My dog, not making this up, knocked my nest off the wall. Where can I purchase the replacement green itself and the plastic opening tools you used throughout the repair? This will be my first time on something like this, but with your guide I should have a decent shot at not screwing it up.
Skip step 12. There is no reason to remove the EMI shield.
Where can you get the replacement lcd screen for gen 2 nest learning thermostat?
