Nespresso Pixie Internal Diffuser Replacement
Introduzione
Vai al passo 1The chosen product here is the Nespresso Pixie. This repair guide will give you all of the necessary tools in order to replace the internal diffuser plate. The guide will take approximately 45 minutes to an hour depending on past experience. At this end of this guide, you will be able to completely take apart this machine in order to cleanse or replace the internal diffuser plate. The most challenging issue you have will be pulling with enough force to pull it apart without breaking it.
Cosa ti serve
Unplug the machine from any outlets.
Remove the water tank by pressing the top button and pulling outwards.
