Salta al contenuto principale
Nespresso Pixie Drip and Grid Plate Replacement
Victory
Victory e 2 altri collaboratori
Ultimo aggiornamento il October 2, 2024
5 minuti
Molto facile
Introduzione
Vai al passo 1
The chosen product here is the Nespresso Pixie. This guide will outline the steps to replace the drip and grid plate. The guide will take approximately 5 minutes. At this end of this process, you will be able to successfully replace the drip and grid plate in your Nespresso Pixie.
  1. Nespresso Pixie Drip and Grid Plate Replacement, Drip and Grid Plate: passo 1, immagine 1 di 1
    • Before beginning disassembly, make sure there is no fluid left inside the water tank or any capsule in the capsule’s chamber.
    • Unplug the machine from any outlets.
    • Remove the water tank by pressing the top button and pulling outwards.
  2. Nespresso Pixie Drip and Grid Plate Replacement: passo 2, immagine 1 di 1
    • Remove the drip tray using your hand.
    • Remove the drip tray grill using your hands.
    • Once removed, separate the capsule container from the grid plate.
Conclusione
Victory
Membro da: 11/03/23
85 Reputazione
1 Guida realizzata
UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2023 Membro di UMass Dartmouth, Team 2-2, Gulbrandsen Fall 2023
UMASSD-GULBRANDSEN-F23S2G2
4 Membri
13 Guide realizzate
1Commento della guida
Useless… the hardest part is to attach the drip tray to the container
H D - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 75
Tutti i Tempi: 726
