Micro-USB Port Replacement
Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
Locate the four main soldering points marked in red.
Be aware of the five additional soldered pins marked by the blue arrow.
Altre 3 persone hanno completato questa guida.
1Commento della guida
I want to know that what I have to do if want to replace the lithium battery with usb direct powered device.
where to buy this battery?
Roy Caño - Replica
