Salta al contenuto principale
Miadore Classic N64 Controller Buttons Replacement
angel villagomez
angel villagomez e 4 altri collaboratori
Ultimo aggiornamento il February 27, 2025
20 - 40 minuti
Facile
Vigilanza sulla Grammatica
Testo Confuso
Studente al lavoro
Introduzione
Vai al passo 1
This guide demonstrates how to replace the buttons on the Miadore Classic N64 Controller. If the buttons are damaged or just misaligned, this guide can help solve your issue. This guide can also be used if you just want to change the buttons with custom buttons.
Before you replace the buttons, you may want to review the Miadore Classic N64 Controller Buttons are Unresponsive troubleshooting page for tips on how to resolve your issue.
Unplug the controller from your device before you begin this repair.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Miadore Classic N64 Controller Buttons Replacement, Joystick: passo 1, immagine 1 di 3 Miadore Classic N64 Controller Buttons Replacement, Joystick: passo 1, immagine 2 di 3 Miadore Classic N64 Controller Buttons Replacement, Joystick: passo 1, immagine 3 di 3
    • Unscrew all nine 3.2 mm Phillips #000 screws from the back of the controller.
    • Remove the back panel of the controller.
  2. Miadore Classic N64 Controller Buttons Replacement: passo 2, immagine 1 di 2 Miadore Classic N64 Controller Buttons Replacement: passo 2, immagine 2 di 2
    • Remove the three 3.2 mm Phillips #000 screws holding the motherboard in place.
    • The motherboard will still be in place after the screws are removed.
  3. Miadore Classic N64 Controller Buttons Replacement: passo 3, immagine 1 di 3 Miadore Classic N64 Controller Buttons Replacement: passo 3, immagine 2 di 3 Miadore Classic N64 Controller Buttons Replacement: passo 3, immagine 3 di 3
    • Remove the three 3.2 mm Phillips #000 screws holding the joystick module in place.
    • Remove the joystick module.
  4. Miadore Classic N64 Controller Buttons Replacement: passo 4, immagine 1 di 2 Miadore Classic N64 Controller Buttons Replacement: passo 4, immagine 2 di 2
    • Remove the joystick by pulling it away from the needle-like object holding it in place.
    • Replace it with a new or custom joystick.
  5. Miadore Classic N64 Controller Buttons Replacement, Buttons: passo 5, immagine 1 di 3 Miadore Classic N64 Controller Buttons Replacement, Buttons: passo 5, immagine 2 di 3 Miadore Classic N64 Controller Buttons Replacement, Buttons: passo 5, immagine 3 di 3
    • Remove the right and left bumper.
    • If the bumper buttons are the buttons that need to be replaced, you can stop here.
  6. Miadore Classic N64 Controller Buttons Replacement: passo 6, immagine 1 di 3 Miadore Classic N64 Controller Buttons Replacement: passo 6, immagine 2 di 3 Miadore Classic N64 Controller Buttons Replacement: passo 6, immagine 3 di 3
    • Plastic spokes through holes in the motherboard keep it in place.
    • Pull the motherboard up with even pressure on all sides.
    • Set the motherboard to the side.
  7. Miadore Classic N64 Controller Buttons Replacement: passo 7, immagine 1 di 3 Miadore Classic N64 Controller Buttons Replacement: passo 7, immagine 2 di 3 Miadore Classic N64 Controller Buttons Replacement: passo 7, immagine 3 di 3
    • Remove the rubber pads. This will reveal the buttons underneath.
  8. Miadore Classic N64 Controller Buttons Replacement: passo 8, immagine 1 di 2 Miadore Classic N64 Controller Buttons Replacement: passo 8, immagine 2 di 2
    • Remove the buttons by pushing up from the bottom of the controller. This will cause them to pop out.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 31
Tutti i Tempi: 127
