Salta al contenuto principale
MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement
Arthur Shi
Arthur Shi
Ultimo aggiornamento il October 31, 2019
Nessuna stima
Difficile
Introduzione
Vai al passo 1
This guide shows how to remove and replace the entire pump assembly as a whole unit for the Mi-T-M gas pressure washer.
You have to remove the output assembly from the pump in order to replace the pump assembly. This requires removing many tight pipe fittings.
You will need something that is 3” tall to place underneath the pump assembly. This can be a wooden block, brick, etc. This will help brace the pump while you work on removing the fittings.
The following tools are optional, but can help with disassembly:
  • 1/4” socket
  • 11/16” wrench
  • 3/4” wrench
  • 15/16” wrench
  • 1” wrench
  1. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Determine the unloader assembly: passo 1, immagine 1 di 3 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Determine the unloader assembly: passo 1, immagine 2 di 3 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Determine the unloader assembly: passo 1, immagine 3 di 3
    • There are two versions of the unloader assembly:
    • First image—earlier pressure washers feature an all-in-one assembly (part 8-0631) that’s easy to replace, but gave users the ability to break the pump.
    • Second image—later models use a tamper-proof, harder to remove unloader (part 8-0656), connected by a series of pipe fittings.
    • This guide is written for the tamper-proof unloader assembly.
    • If you need to remove an all-in-one style unloader, use a large adjustable wrench to unscrew the two large Banjo bolts. This will disconnect the unloader from the pump assembly.
  2. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement: passo 2, immagine 1 di 2 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement: passo 2, immagine 2 di 2
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  3. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Loosen the hose clamp: passo 3, immagine 1 di 2 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Loosen the hose clamp: passo 3, immagine 2 di 2
    • Use a 1/4" socket or a large flathead screwdriver to loosen the hose clamp near the inlet filter.
    • Slide the hose clamp away from the end of the hose.
  4. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Disconnect the return hose: passo 4, immagine 1 di 2 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Disconnect the return hose: passo 4, immagine 2 di 2
    • Wiggle the hose and pull it off of the brass nipple.
  5. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Position the support block: passo 5, immagine 1 di 1
    • Slide a 3" tall block underneath the pump assembly to help support the pump.
  6. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Re-position the return elbow: passo 6, immagine 1 di 2 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Re-position the return elbow: passo 6, immagine 2 di 2
    • Use a 1/2" or adjustable wrench to loosen and twist the return elbow half a turn, so that it faces the opposite direction.
    • This will allow the fitting to clear the pump edge without being removed.
  7. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Loosen the filter: passo 7, immagine 1 di 2 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Loosen the filter: passo 7, immagine 2 di 2
    • Use a large adjustable wrench to loosen and unscrew the filter.
  8. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Remove the filter: passo 8, immagine 1 di 1
    • Remove the filter with the return elbow attached.
  9. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Loosen the input elbow: passo 9, immagine 1 di 2 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Loosen the input elbow: passo 9, immagine 2 di 2
    • Use a 1" or large adjustable wrench to loosen and unscrew the pump input elbow.
  10. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Remove the input elbow: passo 10, immagine 1 di 1
    • Remove the input elbow fitting.
  11. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Loosen the output assembly: passo 11, immagine 1 di 2 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Loosen the output assembly: passo 11, immagine 2 di 2
    • Use a 3/4" or adjustable wrench to loosen and disconnect the coupling from the pump assembly.
  12. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Remove the output assembly: passo 12, immagine 1 di 1
    • Remove the output assembly.
  13. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Align the axle: passo 13, immagine 1 di 3 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Align the axle: passo 13, immagine 2 di 3 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Align the axle: passo 13, immagine 3 di 3
    • Look through the top access hole on the pump, near the engine coupling. You should be able to see the pump shaft through the hole.
    • Slowly pull the starter cable. This will slowly turn the engine's axle.
    • Keep rotating the axle until you can see the set screw through the access hole.
  14. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Loosen the set screw: passo 14, immagine 1 di 1
    • Insert a 2.5 mm hex key into the set screw and loosen it counter-clockwise by two full turns.
    • Do not completely loosen the screw, or you will lose it.
  15. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Remove the mounting bolts: passo 15, immagine 1 di 3 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Remove the mounting bolts: passo 15, immagine 2 di 3 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Remove the mounting bolts: passo 15, immagine 3 di 3
    • Use a 1/2" wrench to remove the four 30 mm long bolts which mount the pump to the engine.
    • You should still have the support block under the pump assembly to help bear the pump's weight.
    • Re-assembly tip: note how the washers are stacked when reinstalling the bolts.
    • Replace the lock washers with new ones.
  16. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Slide the pump assembly off: passo 16, immagine 1 di 3 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Slide the pump assembly off: passo 16, immagine 2 di 3 MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Slide the pump assembly off: passo 16, immagine 3 di 3
    • Carefully pull the pump assembly away from the engine until it de-couples from the engine axle.
    • If you are having a hard time pulling the pump away, loosen the axle set screw by half a turn, and try again.
  17. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Remove the axle key: passo 17, immagine 1 di 1
    • Remove the axle key from either the engine axle, or the pump shaft.
    • Re-assembly note: Wipe the axle and key clean and coat with lubricating oil.
  18. MiTM Pressure Washers CA2703HDHB1 2017 Pump Assembly Replacement, Re-attach the motor: passo 18, immagine 1 di 1
    • Re-assembly note: To re-attach the motor:
    • Press the axle key into the notch on the engine axle.
    • Align the pump shaft with the keyed axle. You may have to rotate the pump to do so.
    • Slide the pump onto the axle until the coupling surfaces touch.
    • If there is a significant gap between the pump and engine, pull the pump off, and re-set the axle key.
Conclusione
When you re-connect the fittings, clean off the old thread sealant and apply new thread sealant (tape or pipe dope).
Arthur Shi
Membro da: 01/03/18
282.700 Reputazione
587 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.455 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 35
Tutti i Tempi: 1,565
