Salta al contenuto principale
Meta Quest 2 Controller Ring Shell Replacement
Arthur Shi
Arthur Shi
Ultimo aggiornamento il 6 giu 2024
15 - 30 minuti
Moderato
Introduzione
Vai al passo 1
This guide shows how to remove and replace a cracked controller ring shell for your Meta Quest 2 controller.
This guide is written with the right controller. If you're repairing the left controller, you can still use this guide, as the procedure is identical.
Cosa ti serve
Strumenti
  • iFixit Opening Tool
    iFixit Opening Tool
  • iOpener
    iOpener
  • T5 Torx Screwdriver
    T5 Torx Screwdriver
  • Spudger
    Spudger
Mostra di più…
  1. Meta Quest 2 Controller Ring Shell Replacement, Remove the battery cover: passo 1, immagine 1 di 3 Meta Quest 2 Controller Ring Shell Replacement, Remove the battery cover: passo 1, immagine 2 di 3 Meta Quest 2 Controller Ring Shell Replacement, Remove the battery cover: passo 1, immagine 3 di 3
    • Use your fingers to slide the battery cover down towards the strap end of the controller.
    • Remove the battery cover.
    • If you're taking the controller apart for repairs, remove the batteries in the controller.
  2. Meta Quest 2 Controller Ring Shell Replacement, Remove the wrist strap: passo 2, immagine 1 di 2 Meta Quest 2 Controller Ring Shell Replacement, Remove the wrist strap: passo 2, immagine 2 di 2
    • Use your fingers to grasp the wrist strap near the anchor peg.
    • Lift the wrist strap anchor peg straight out of its recess.
    • Remove the wrist strap.
  3. Meta Quest 2 Controller Ring Shell Replacement, Loosen the faceplate adhesive: passo 3, immagine 1 di 1
    • Heat an iOpener and apply it to the bottom edge of the controller faceplate for a minute.
    Why is this step needed? Yes there is adhesive on it, but it isn't that bad.
    DAB ARMY - Replica
    you dont need it, prob better to have it but not required to get the cover off
    jek - Replica
    For anyone stumbling across this like me, I can agree with the others: it is almost definitely a nice to have I'm sure, but I was able to get in just fine using an opening pick and opening tool.
    Aranohr - Replica
  4. Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller faceplate: passo 4, immagine 1 di 3 Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller faceplate: passo 4, immagine 2 di 3 Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller faceplate: passo 4, immagine 3 di 3
    • The controller faceplate is secured with adhesive and three friction pegs.
    • Press the edge of an opening tool into the seam between the controller faceplate and shell, near the Oculus button.
    • If you can’t get the opening tool into the seam, heat the area with an iOpener for a minute and try again.
    • Slide the opening tool to the base of the ring shell to loosen the adhesive.
  5. Meta Quest 2 Controller Ring Shell Replacement: passo 5, immagine 1 di 2 Meta Quest 2 Controller Ring Shell Replacement: passo 5, immagine 2 di 2
    • Use an opening tool to pry up on the seam to loosen the first friction peg.
  6. Meta Quest 2 Controller Ring Shell Replacement: passo 6, immagine 1 di 2 Meta Quest 2 Controller Ring Shell Replacement: passo 6, immagine 2 di 2
    • Continue prying around the entire faceplate to separate the remaining friction pegs and adhesive.
    • If you're having trouble, apply a heated iOpener to the faceplate for a minute and try again.
  7. Meta Quest 2 Controller Ring Shell Replacement, Remove the faceplate: passo 7, immagine 1 di 3 Meta Quest 2 Controller Ring Shell Replacement, Remove the faceplate: passo 7, immagine 2 di 3 Meta Quest 2 Controller Ring Shell Replacement, Remove the faceplate: passo 7, immagine 3 di 3
    • Remove the controller faceplate.
    • The three friction pegs should hold the faceplate securely, so you don’t need to replace the adhesive during reassembly. Be sure to firmly press the faceplate onto the controller so that all friction pegs fully engage.
  8. Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller ring shell: passo 8, immagine 1 di 2 Meta Quest 2 Controller Ring Shell Replacement, Loosen the controller ring shell: passo 8, immagine 2 di 2
    • Use a Torx T5 driver to remove the four screws securing the controller ring shell to the controller:
    • Two 4.7 mm‑long screws
    • Two 5.9 mm‑long screws
    those top screws in red are in very tight, and at an angle that prevents using a long screwdriver. I've found the only way I could get them out is using a bit, held down by my finger at the appropriate angle, while turning it with pliers.
    Ben Klopfenstein - Replica
    I wasn't able to remove the screws in red with a T5 bit, but switching to a T4 bit did the trick for me
    Aranohr - Replica
    same, used T4 instead
    Martin Samuelsson -
  9. Meta Quest 2 Controller Ring Shell Replacement: passo 9, immagine 1 di 2 Meta Quest 2 Controller Ring Shell Replacement: passo 9, immagine 2 di 2
    • Press the point of a spudger firmly against the white alignment square to release the ring shell.
  10. Meta Quest 2 Controller Ring Shell Replacement, Remove the controller ring shell: passo 10, immagine 1 di 3 Meta Quest 2 Controller Ring Shell Replacement, Remove the controller ring shell: passo 10, immagine 2 di 3 Meta Quest 2 Controller Ring Shell Replacement, Remove the controller ring shell: passo 10, immagine 3 di 3
    • Use your fingers to grab the end of the ring shell that doesn’t have the white alignment square.
    • Gently lift the ring shell up and away from the controller to unclip it from the controller.
    • Remove the controller ring shell.
Conclusione
Altre 2 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Arthur Shi
Membro da: 01/03/18
297.723 Reputazione
682 Guide realizzate
iFixit Membro di iFixit
Staff
119 Membri
21.667 Guide realizzate
1Commento della guida
This Tutorial was really fast and easy also, I fixed my controller and it works very well now, Thank you!
# “‪Diamond‬” # - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 27
Ultimi 30 Giorni: 155
Tutti i Tempi: 5,292
