Salta al contenuto principale
Merch Source Projector Entertainment II Motherboard
Michael Tan
Michael Tan e 5 altri collaboratori
Ultimo aggiornamento il June 16, 2015
15 minuti - 1 ora
Moderato
Passi mancanti
Introduzione
Vai al passo 1
Follow this guide to repair components on the logic board. All you will need a solder gun and steady hands.
Cosa ti serve
Strumenti
Mostra di più…
  1. Merch Source Projector Entertainment II Motherboard, Outer Casing: passo 1, immagine 1 di 2 Merch Source Projector Entertainment II Motherboard, Outer Casing: passo 1, immagine 2 di 2
    • Flip the projector onto its back and unscrew the nine 15mm screws using the Phillips #0 screw driver.
  2. Merch Source Projector Entertainment II Motherboard: passo 2, immagine 1 di 1
    • Flip the projector right side up and unscrew the two 12mm screws on the light bulb panel located at the rear of the projector with a Phillips #0 screw head.
    • The bottom right panel screw does not come completely out the panel door.
  3. Merch Source Projector Entertainment II Motherboard: passo 3, immagine 1 di 2 Merch Source Projector Entertainment II Motherboard: passo 3, immagine 2 di 2
    • Using your hands, gently pry the top and bottom of the projector casing apart.
  4. Merch Source Projector Entertainment II Motherboard, Motherboard: passo 4, immagine 1 di 2 Merch Source Projector Entertainment II Motherboard, Motherboard: passo 4, immagine 2 di 2
    • Use the plastic opening tool to gently disengage the ribbon cable from its back housing.
    • Once the ribbon cable is disengaged gently pull the cable off the motherboard.
    • Once the housing is disengaged, the ribbon cable should slide out easy. Do not pull too hard on the ribbon cable as it is very fragile.
  5. Merch Source Projector Entertainment II Motherboard: passo 5, immagine 1 di 2 Merch Source Projector Entertainment II Motherboard: passo 5, immagine 2 di 2
    • Unscrew the three 6 mm screws from the motherboard with the Phillips #0 screwdriver.
    • Be sure not to damage any of the wires atached to the motherboard.
  6. Merch Source Projector Entertainment II Motherboard: passo 6, immagine 1 di 2 Merch Source Projector Entertainment II Motherboard: passo 6, immagine 2 di 2
    • Solder off all of the connections on the motherboard with a soldering iron.
    • Once connections are soldered off, the motherboard should be detached and ready for replacement.
    • Need some help? Follow this guide to learn soldering basics.
    • While soldering the metal connections can get very hot. Never touch the iron with your hand. also make sure that the projector is fully turned off and not plugged in.
    • If there is hot glue on top on the connection with the motherboard, you will need to peel it off using your fingers.
Conclusione
Michael Tan
Membro da: 01/08/15
590 Reputazione
3 Guide realizzate
Cal Poly, Team 30-3, Green Spring 2015 Membro di Cal Poly, Team 30-3, Green Spring 2015
CPSU-GREEN-S15S30G3
4 Membri
10 Guide realizzate
3 Commenti
Was wondering if you could help me identify a microchip on the board by the speaker?
Brad Langland - Replica
Where can I get parts for the projector? I think my board is cooked.
Delgtm - Replica
mine acts like it does not recognize the rca cords. help
Kamela Mitchell - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 22
Tutti i Tempi: 1,927
