Salta al contenuto principale
Master and Dynamic MW50 Battery Replacement
Tyler Guffey
Tyler Guffey e 4 altri collaboratori
Ultimo aggiornamento il May 10, 2022
10 minuti
Moderato
Introduzione
Vai al passo 1
In order to safely replace or check other parts for this device, it is sometimes necessary to first disconnect the battery. This will also allow you to replace the battery if you determine it to be faulty. You will need to unsolder and solder to replace your battery, and there is an attached guide to show you how. You will be disassembling the right side of the headphones.
Cosa ti serve
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: passo 1, immagine 1 di 3 Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: passo 1, immagine 2 di 3 Master and Dynamic MW50 Battery Replacement, Master and Dynamic MW50 Disassembly: passo 1, immagine 3 di 3
    • Pull the cushion off of the desired side by gripping the top of the headphones and pulling the cushion off.
  2. Master and Dynamic MW50 Battery Replacement: passo 2, immagine 1 di 1
    • Remove the four 5mm screws from the earpiece with a Y1 Triwing screwdriver.
  3. Master and Dynamic MW50 Battery Replacement: passo 3, immagine 1 di 1
    • Use the Jimmy to lift up the black cover to get inside the device.
  4. Master and Dynamic MW50 Battery Replacement, Battery: passo 4, immagine 1 di 2 Master and Dynamic MW50 Battery Replacement, Battery: passo 4, immagine 2 di 2
    • Remove the tape attaching the thicker white wire to the battery. You may consider keeping the tape to reattach the wire later.
  5. Master and Dynamic MW50 Battery Replacement: passo 5, immagine 1 di 1
    • Desolder the two wires circled here.
  6. Master and Dynamic MW50 Battery Replacement: passo 6, immagine 1 di 2 Master and Dynamic MW50 Battery Replacement: passo 6, immagine 2 di 2
    • Use an iFixit opening tool or something similar to pry out the battery.
    • There are two small tabs circled here that are holding the battery in. Push these down while prying to make the battery come out easier.
    Where to get the replacement battery?
    Jon Allen McCarty - Replica
Conclusione
Tyler Guffey
Membro da: 01/24/19
208 Reputazione
2 Guide realizzate
Cal Poly, Team S1-G4, White Winter 2019 Membro di Cal Poly, Team S1-G4, White Winter 2019
CPSU-WHITE-W19S1G4
4 Membri
12 Guide realizzate
2Commenti sulla guida
Hi, do you know where it’s possible to buy replacement batteries??
Mike - Replica
Did you ever find out what spec of battery and where to buy? Really want to run my MW50s wirelessly again.
TP 75 -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 35
Tutti i Tempi: 2,131
