Magic Bullet NutriBullet Base Replacement
Introduzione
Vai al passo 1If you notice any sharp, moving components outside of your NutriBullet base, then use this replacement guide to learn how to remove and replace the base.
Cosa ti serve
Once the screws are removed, use slight tension to pull the plastic base up.
Altre 2 persone hanno completato questa guida.
3Commenti sulla guida
With a lot of force can’t get bottom of even 4 screws removed Bullet don’t work anymore may be a piece of junk now
Where can you buy the base to replace?
