Salta al contenuto principale
MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement
Andrew Optimus Goldheart
Andrew Optimus Goldheart e 3 altri collaboratori
Ultimo aggiornamento il August 22, 2022
15 - 30 minuti
Moderato
Introduzione
Vai al passo 1
Wi-Fi on the fritz? Just can't get onto that free coffee shop internet no matter how hard you try? You might need to replace your AirPort Board. Follow this guide to learn how.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement, Lower Case: passo 1, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Magnetic Project Mat
    $19.95
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement: passo 2, immagine 1 di 1
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case to remove it.
  3. MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement: passo 3, immagine 1 di 2 MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement: passo 3, immagine 2 di 2
    • The lower case is connected to the upper case with two plastic clips near its center.
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
  4. MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement, Battery Connector: passo 4, immagine 1 di 1
    • If necessary, remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement: passo 5, immagine 1 di 2 MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement: passo 5, immagine 2 di 2
    • Use the flat end of a spudger to lift the battery connector straight up out of its socket on the logic board.
    • Be sure you lift up only on the connector itself, not the socket, or you risk permanent damage to the logic board.
  6. MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement: passo 6, immagine 1 di 1
    • Bend the battery connector up out of the way to prevent accidental contact with its socket during your repair.
  7. MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement, AirPort Board: passo 7, immagine 1 di 3 MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement, AirPort Board: passo 7, immagine 2 di 3 MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement, AirPort Board: passo 7, immagine 3 di 3
    • Wedge the tip of a spudger underneath each of the antenna cables, near their connectors and pry up to disconnect them from the AirPort board.
    • The three cables are coded with black sleeves of different lengths. During reassembly:
    • Connect the long-sleeved cable to the center socket.
    • The short-sleeved cable connects next to the screw.
    • The remaining cable has no sleeve, and connects in the last empty socket, next to the fan.
  8. MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement: passo 8, immagine 1 di 1
    • Remove the single 2.7 mm T5 Torx screw securing the AirPort board to the I/O board.
  9. MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement: passo 9, immagine 1 di 3 MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement: passo 9, immagine 2 di 3 MacBook Pro 13" Retina Display Early 2015 AirPort Board Replacement: passo 9, immagine 3 di 3
    • Lift the free end of the AirPort board up slightly and pull it straight out of its socket on the logic board.
Conclusione
Altre 33 persone hanno completato questa guida.
iFixit Membro di iFixit
Staff
118 Membri
19.455 Guide realizzate
10 Commenti
Is this responsible for wifi? I re-did my screen and fixed it from blackening, but the wifi icon says "Wi-Fi: No hardware installed". Is this part responsible? If I replace it will I get wifi back?
Howard Lin - Replica
I changed the card and the wifi keep disabling itself after few minutes of use. Only reboot reactivate it.. Someone have an idea ?
Phil - Replica
Hey! have you found a solution? I have been having the same problem!
juiquebec -
I am having the same exact problem as described by Phil - 04/25/2017
I replaced the card but the wifi and bluetooth keeps disabling itself after few minutes of use , only reboot reactivate it.
I am thinking of changing the antenna ? any ideas? suggestion ?
your help will be very much appreciated .
Lio - Replica
This isn’t the solution you are looking for, but what I did to my 2015 mbp when the wifi card started failing was getting an external wifi adapter. It’s cheaper, small enough, and works. I got this type: https://www.tp-link.com/us/support/downl... but any type works, this one is just small enough to be unassuming.
stefanikid - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 61
Ultimi 30 Giorni: 208
Tutti i Tempi: 51,653
