Salta al contenuto principale
Logitech Harmony Smart Control Battery Contact  Replacement
Josh Hendricks
Josh Hendricks e 4 altri collaboratori
Ultimo aggiornamento il May 23, 2016
10 - 20 minuti
Difficile
Introduzione Migliore
Introduzione
Vai al passo 1
This guide requires soldering, for soldering guide click below.
Soldering Guide
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Logitech Harmony Smart Control Battery Contact  Replacement, Battery Contact: passo 1, immagine 1 di 2 Logitech Harmony Smart Control Battery Contact  Replacement, Battery Contact: passo 1, immagine 2 di 2
    • Use both thumbs to slide the grooved cover off of the remote
    • Once the cover is off, remove the battery.
  2. Logitech Harmony Smart Control Battery Contact  Replacement: passo 2, immagine 1 di 2 Logitech Harmony Smart Control Battery Contact  Replacement: passo 2, immagine 2 di 2
    • Locate both of the 4mm Phillips screws on the remote. Using the PH00 bit, remove the screws.
  3. Logitech Harmony Smart Control Battery Contact  Replacement: passo 3, immagine 1 di 3 Logitech Harmony Smart Control Battery Contact  Replacement: passo 3, immagine 2 di 3 Logitech Harmony Smart Control Battery Contact  Replacement: passo 3, immagine 3 di 3
    • Use a flat screwdriver or a prying tool to split the remote and separate the two pieces. Start from the bottom.
  4. Logitech Harmony Smart Control Battery Contact  Replacement: passo 4, immagine 1 di 2 Logitech Harmony Smart Control Battery Contact  Replacement: passo 4, immagine 2 di 2
    • Using the metal piece from the housing, pry the circuit board upwards. Do not disconnect it from the board.
    • Slide the circuit board out from the housing .
  5. Logitech Harmony Smart Control Battery Contact  Replacement: passo 5, immagine 1 di 1
    • Locate the battery contacts on the circuit board.
    • Using a soldering iron, remove the old solder and the battery contacts. Install new battery contacts and solder them.
Conclusione
IUPUI, Team 3-2, Harley Fall 2015 Membro di IUPUI, Team 3-2, Harley Fall 2015
IUPUI-HARLEY-F15S3G2
4 Membri
5 Guide realizzate
1Commento della guida
do you know where can i buy the springs?
IOANNIS KARAKOGLOU - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 10
Tutti i Tempi: 5,052
