Salta al contenuto principale
Logitech Harmony Companion Remote Motherboard Replacement
Cassidy Wardlow
Cassidy Wardlow e 3 altri collaboratori
Ultimo aggiornamento il February 14, 2022
5 minuti
Moderato
Introduzione
Vai al passo 1
The motherboard is a central part in the operation of your Companion remote. If your remote is not working after adjusting the settings and replacing the battery, you may need to replace the motherboard. All you need for this guide is a plastic opening tool and a Phillps #0 screwdriver.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Logitech Harmony Companion Remote Motherboard Replacement, Remote Battery: passo 1, immagine 1 di 1
    • Hold the remote with the Logitech label toward you.
  2. Logitech Harmony Companion Remote Motherboard Replacement: passo 2, immagine 1 di 1
    • Push the battery cover upward.
    MY Logitech Harmony smart control does NOT have a battery door. There is absolutely no way to get to any battery HELP
    ussscamp - Replica
  3. Logitech Harmony Companion Remote Motherboard Replacement: passo 3, immagine 1 di 3 Logitech Harmony Companion Remote Motherboard Replacement: passo 3, immagine 2 di 3 Logitech Harmony Companion Remote Motherboard Replacement: passo 3, immagine 3 di 3
    • Use your finger to lift the battery out of the compartment.
    • When the battery has lifted, push it up to remove it.
  4. Logitech Harmony Companion Remote Motherboard Replacement, Remote Motherboard: passo 4, immagine 1 di 2 Logitech Harmony Companion Remote Motherboard Replacement, Remote Motherboard: passo 4, immagine 2 di 2
    • Remove the two 5.0 mm Phillips #0 screws.
  5. Logitech Harmony Companion Remote Motherboard Replacement: passo 5, immagine 1 di 2 Logitech Harmony Companion Remote Motherboard Replacement: passo 5, immagine 2 di 2
    • Use the plastic opening tool to pry open the back cover of the remote.
    • It is recommended to have the point of the opening tool facing the back of the remote.
    • Insert the opening tool on each side of the bottom of the remote, and pull up until you hear the cover click open.
    • Pry the back cover off by sliding the plastic opening tool down each side.
  6. Logitech Harmony Companion Remote Motherboard Replacement: passo 6, immagine 1 di 2 Logitech Harmony Companion Remote Motherboard Replacement: passo 6, immagine 2 di 2
    • Use the plastic opening tool to remove the motherboard.
    Pay careful attention to how the battery holders (the wires at the top) are positioned before removing, especially the springs which are designed to push the battery out when lifted, but if not carefully reinstalled will not allow the battery click into place.
    Tom Scott - Replica
Conclusione
Altre 6 persone hanno completato questa guida.
USF Tampa, Team S1-G3, Nance Fall 2017 Membro di USF Tampa, Team S1-G3, Nance Fall 2017
USFT-NANCE-F17S1G3
3 Membri
4 Guide realizzate
1Commento della guida
Any source on that motherboard? I've got two dead buttons and replacement remotes are expensive and hard to come by.
Karl Wooster - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 82
Tutti i Tempi: 6,719
