Logitech Harmony Companion Remote Motherboard Replacement
Introduzione
Vai al passo 1The motherboard is a central part in the operation of your Companion remote. If your remote is not working after adjusting the settings and replacing the battery, you may need to replace the motherboard. All you need for this guide is a plastic opening tool and a Phillps #0 screwdriver.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
Use the plastic opening tool to remove the motherboard.
Altre 6 persone hanno completato questa guida.
1Commento della guida
Any source on that motherboard? I've got two dead buttons and replacement remotes are expensive and hard to come by.
