Salta al contenuto principale
Logitech Harmony 650 Screen Replacement
Connor Gallagher
Connor Gallagher e 4 altri collaboratori
Ultimo aggiornamento il April 10, 2023
8 minuti
Moderato
Introduzione
Vai al passo 1
It is recommended that you have the iFixit ProTech toolkit and have already taken out the motherboard and taken apart the case.
Cosa ti serve
Strumenti
Mostra di più…
  1. Logitech Harmony 650 Screen Replacement, Case: passo 1, immagine 1 di 2 Logitech Harmony 650 Screen Replacement, Case: passo 1, immagine 2 di 2
    • Remove the battery cover by applying pressure to the indented area and pushing the cover toward the rear of the device.
  2. Logitech Harmony 650 Screen Replacement: passo 2, immagine 1 di 1
    • Remove the batteries using the silver pull tab.
  3. Logitech Harmony 650 Screen Replacement: passo 3, immagine 1 di 1
    • Using a J000 Philips head screwdriver remove the four 5mm screws around the rim of the battery chamber.
  4. Logitech Harmony 650 Screen Replacement: passo 4, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • Remove the small plastic cover beneath the plastic LED housing by using a 3.0 flathead screwdriver and a spudger to pry it off. It is glued to the case. If you are having trouble removing it try applying some heat to loosen the glue.
  5. Logitech Harmony 650 Screen Replacement: passo 5, immagine 1 di 1
    • Remove the two 5mm screws located underneath the cover using a J000 Philips screwdriver bit.
  6. Logitech Harmony 650 Screen Replacement: passo 6, immagine 1 di 2 Logitech Harmony 650 Screen Replacement: passo 6, immagine 2 di 2
    • Using a plastic opening tool, pry the case off starting from the top of the device (nearest the transmitter). There are 3 tabs along the side of the case and one at the back.
    • The top led protector plastic cover will also be freed once back is removed.
  7. Logitech Harmony 650 Screen Replacement: passo 7, immagine 1 di 1
    • Remove the rear cover.
  8. Logitech Harmony 650 Screen Replacement, Motherboard: passo 8, immagine 1 di 2 Logitech Harmony 650 Screen Replacement, Motherboard: passo 8, immagine 2 di 2
    • Using a J0 screwdriver remove the three 5mm screws holding the motherboard to the front face. Two are located just below the processor in the middle of the device and the third is located at the very bottom.
  9. Logitech Harmony 650 Screen Replacement: passo 9, immagine 1 di 1
    • Remove the motherboard by gently pulling it away from the case.
  10. Logitech Harmony 650 Screen Replacement, Screen: passo 10, immagine 1 di 2 Logitech Harmony 650 Screen Replacement, Screen: passo 10, immagine 2 di 2
    • Remove the black rubber gasket that surrounds the screen from the top face of the motherboard.
    • The gasket has 3 tabs along each side. The thick side of the gasket faces the top.
    Ekranı nerden bulabilirim? Tedariği için aramam gereken kriter nedir?
    Mustafa - Replica
    Kimse yok mu????
    Mustafa - Replica
    where can i buy the screen!!!
    shortemperd Gotico - Replica
  11. Logitech Harmony 650 Screen Replacement: passo 11, immagine 1 di 1
    • Use a soldering iron to loosen the solder that connects the screen strip to the back of the motherboard. If it does not loosen easily then try using a soldering remover wick.
    • The soldering iron gets extremely hot use caution when using it around components.
  12. Logitech Harmony 650 Screen Replacement: passo 12, immagine 1 di 1
  13. Logitech Harmony 650 Screen Replacement: passo 13, immagine 1 di 1
    • Use a spudger or your hand to remove the screen from the motherboard. It is glued down.
Conclusione
Altre 4 persone hanno completato questa guida.
2Commenti sulla guida
Hey will beat buy honor a warrenty
antonioofficial - Replica
so where can i buy the screen!!!!
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,827
