Logitech Gamepad F310 Trigger Spring Replacement
Introduzione
Vai al passo 1If your triggers on your Logitech Gamepad F310 seem to be loose or broken, you might need to replace the springs inside them. Luckily this is a fairly easy process. Follow this guide to replace the springs on the triggers for your Gamepad controller.
The trigger spring is to help make trigger return back original position. The trigger is special function for gaming purpose like aiming, zooming and etc. So those are reason to replace trigger spring.
No special tools or skills are required.
Cosa ti serve
Use a Phillips #1 screwdriver to remove all seven 3 mm screws that secure the rear case.
Press along the seams of the controller and gently pull the front and rear case apart.
Use a Phillips #1 screwdriver to remove:
Four 3 mm screws
One 5 mm screw
Gently lift the motherboard off of the back case and slide the cord out of the top slot.
You're all finished! To reassemble your device, follow these instructions carefully in reverse order.
Preparati per le riparazioni future
Acquista tutti1Commento della guida
I completed this guide in conjunction with this video:
