Linksys WRT54GS v2 Antenna Ports Replacement
Introduzione
Vai al passo 1You will be desoldering the antenna ports.
Cosa ti serve
Strumenti
Mostra di più…
Remove the rubber inserts inside the the two purple feet located on the router's front case.
This may be a challenge, so try the following two methods:
Use a plastic opening tool. Insert the flat end of the tool into the seam and slowly pry the rubber feet out.
Use a metal spudger. Insert the point of the metal spudger directly into the hole of the rubber feet and pry the insert out.
Turn the circuit board over and identify which solder connection you will desolder.
The solder connections shown in red hold the right antenna port in place. There is one more attachment for this antenna on the other side of the board.
The solder connections shown in blue hold the left antenna port in place. Desolder these 4 points to remove the antenna port.
Desolder the connection by following iFixit's guide to repairing soldered connections: Come saldare e dissaldare componenti elettrici.
Altre 2 persone hanno completato questa guida.
