Salta al contenuto principale
Lenovo ThinkPad T470 SSD Assembly Replacement
Kristen Gismondi
Kristen Gismondi
Ultimo aggiornamento il May 18, 2024
15 - 20 minuti
Facile
Introduzione
Vai al passo 1
Use this guide to replace the SSD assembly in your Lenovo ThinkPad T470. The SSD assembly includes a plastic bracket, a metal enclosure, the SSD itself, and the SSD connector board. If you need to replace any of these individual components, follow the Lenovo ThinkPad T470 SSD Replacement guide.
Make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Cosa ti serve
Strumenti
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
Mostra di più…
  1. Lenovo ThinkPad T470 SSD Assembly Replacement, External Battery: passo 1, immagine 1 di 3 Lenovo ThinkPad T470 SSD Assembly Replacement, External Battery: passo 1, immagine 2 di 3 Lenovo ThinkPad T470 SSD Assembly Replacement, External Battery: passo 1, immagine 3 di 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T470 SSD Assembly Replacement: passo 2, immagine 1 di 3 Lenovo ThinkPad T470 SSD Assembly Replacement: passo 2, immagine 2 di 3 Lenovo ThinkPad T470 SSD Assembly Replacement: passo 2, immagine 3 di 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T470 SSD Assembly Replacement, Bottom Cover: passo 3, immagine 1 di 2 Lenovo ThinkPad T470 SSD Assembly Replacement, Bottom Cover: passo 3, immagine 2 di 2
    • Use a Phillips #1 screwdriver to loosen the six captive screws on the bottom cover of the laptop.
  4. Lenovo ThinkPad T470 SSD Assembly Replacement: passo 4, immagine 1 di 3 Lenovo ThinkPad T470 SSD Assembly Replacement: passo 4, immagine 2 di 3 Lenovo ThinkPad T470 SSD Assembly Replacement: passo 4, immagine 3 di 3
    • Use your hands to pull up on the back cover and release the plastic clips starting on the bottom side of the battery compartment.
    • Potential for device damage: Be sure to detach the plastic clips in this area first. You risk cracking the bottom cover if you attempt to detach it from around the edges of the laptop first.
    • Use your hands to pull up on the right side of the bottom cover to release the plastic clips.
    • Use your hands to pull up on the left side of the bottom cover to release the plastic clips.
  5. Lenovo ThinkPad T470 SSD Assembly Replacement: passo 5, immagine 1 di 1
    • Remove the bottom cover from the laptop.
    • Disconnect the battery from the board before continuing.
  6. Lenovo ThinkPad T470 SSD Assembly Replacement, SSD Assembly: passo 6, immagine 1 di 2 Lenovo ThinkPad T470 SSD Assembly Replacement, SSD Assembly: passo 6, immagine 2 di 2
    • Use the flat end of a spudger to flip up the metal clip securing the SSD connector to the motherboard.
  7. Lenovo ThinkPad T470 SSD Assembly Replacement: passo 7, immagine 1 di 2 Lenovo ThinkPad T470 SSD Assembly Replacement: passo 7, immagine 2 di 2
    • Use the flat end of a spudger to separate the connector from its socket.
  8. Lenovo ThinkPad T470 SSD Assembly Replacement: passo 8, immagine 1 di 3 Lenovo ThinkPad T470 SSD Assembly Replacement: passo 8, immagine 2 di 3 Lenovo ThinkPad T470 SSD Assembly Replacement: passo 8, immagine 3 di 3
    • Grab the tab on the left side of the SSD assembly, and pull up to remove it from the laptop.
Conclusione
Altre 3 persone hanno completato questa guida.
Kristen Gismondi
Membro da: 11/12/14
92.751 Reputazione
241 Guide realizzate
iFixit Membro di iFixit
Staff
120 Membri
19.661 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 45
Tutti i Tempi: 1,655
