Salta al contenuto principale
Lenovo ThinkPad T460 Hard Drive Replacement
Kristen Gismondi
Kristen Gismondi e un altro collaboratore
Ultimo aggiornamento il January 16, 2024
20 minuti
Facile
Introduzione
Vai al passo 1
Use this guide to replace the hard drive in your Lenovo ThinkPad T460 laptop.
A hard drive (also known as a hard disk drive, HDD, or hard disk) is a storage component in a computer. Hard drives use spinning disks and moveable parts, as opposed to the flash memory used in an SSD. Signs of a failing hard drive may include clicking or grinding noises, disappearing data, computer crashes, and an inability for your computer to recognize the hard drive.
If you are able to recover any data saved to your hard drive, be sure to back up your files before beginning this guide. Also, make sure to disable the internal battery, power down your device, and disconnect from any external power sources before you begin.
Cosa ti serve
Ricambi
Strumenti
  • Spudger
    Spudger
  • Phillips #1 Screwdriver
Mostra di più…
  1. Lenovo ThinkPad T460 Hard Drive Replacement, External Battery: passo 1, immagine 1 di 3 Lenovo ThinkPad T460 Hard Drive Replacement, External Battery: passo 1, immagine 2 di 3 Lenovo ThinkPad T460 Hard Drive Replacement, External Battery: passo 1, immagine 3 di 3
    • Before you begin this guide, make sure to disable the internal battery, power down your device, and disconnect from any external power sources.
    • Place the laptop so that the bottom is facing upwards.
    • Slide the latch on the left side of the battery to the left until it clicks in place.
  2. Lenovo ThinkPad T460 Hard Drive Replacement: passo 2, immagine 1 di 3 Lenovo ThinkPad T460 Hard Drive Replacement: passo 2, immagine 2 di 3 Lenovo ThinkPad T460 Hard Drive Replacement: passo 2, immagine 3 di 3
    • Slide the latch on the right side of the battery to the right and hold it in place with your thumb.
    • Use your other hand to slide the battery towards the back of the laptop.
    • Lift the battery up and away from the laptop.
  3. Lenovo ThinkPad T460 Hard Drive Replacement, Bottom Cover: passo 3, immagine 1 di 2 Lenovo ThinkPad T460 Hard Drive Replacement, Bottom Cover: passo 3, immagine 2 di 2
    • Loosen the eight captive screws in the bottom cover using a Phillips #1 screwdriver.
  4. Lenovo ThinkPad T460 Hard Drive Replacement: passo 4, immagine 1 di 3 Lenovo ThinkPad T460 Hard Drive Replacement: passo 4, immagine 2 di 3 Lenovo ThinkPad T460 Hard Drive Replacement: passo 4, immagine 3 di 3
    • Insert the flat end of a spudger in between the bottom cover and the rest of the laptop, starting in the lower left corner.
    • Pry the lower left corner of the bottom cover up by a few millimeters.
    • Slide the spudger along the bottom of the laptop to release the clips until you reach the lower right corner.
    • You may hear some snapping noises as the clips are released.
  5. Lenovo ThinkPad T460 Hard Drive Replacement: passo 5, immagine 1 di 2 Lenovo ThinkPad T460 Hard Drive Replacement: passo 5, immagine 2 di 2
    • Slide the spudger along the right and top sides of the bottom cover to release the clips.
    • Potential for device damage: If the clips do not release easily, check to ensure that the captive screws are fully loosened. Forcing the clips to detach can crack the bottom cover.
  6. Lenovo ThinkPad T460 Hard Drive Replacement: passo 6, immagine 1 di 2 Lenovo ThinkPad T460 Hard Drive Replacement: passo 6, immagine 2 di 2
    • Use the spudger to pry the upper left corner up by a few millimeters.
    • Pry up the sections of the bottom cover with printed logos of the ports.
    • Potential for device damage: Prying inside the ports themselves can damage your laptop. Be sure to only pry up on the sections of the cover that extend past the ports.
  7. Lenovo ThinkPad T460 Hard Drive Replacement: passo 7, immagine 1 di 2 Lenovo ThinkPad T460 Hard Drive Replacement: passo 7, immagine 2 di 2
    • Use the spudger to pry up the bottom cover in the lower portion of the external battery compartment by a few millimeters.
  8. Lenovo ThinkPad T460 Hard Drive Replacement: passo 8, immagine 1 di 3 Lenovo ThinkPad T460 Hard Drive Replacement: passo 8, immagine 2 di 3 Lenovo ThinkPad T460 Hard Drive Replacement: passo 8, immagine 3 di 3
    • Use both hands to lift the bottom cover up and away from the laptop.
  9. Lenovo ThinkPad T460 Hard Drive Replacement, Hard Drive: passo 9, immagine 1 di 2 Lenovo ThinkPad T460 Hard Drive Replacement, Hard Drive: passo 9, immagine 2 di 2
    • Remove the single 3.7 mm screw from the left side of the hard drive using a Phillips #1 screwdriver.
  10. Lenovo ThinkPad T460 Hard Drive Replacement: passo 10, immagine 1 di 3 Lenovo ThinkPad T460 Hard Drive Replacement: passo 10, immagine 2 di 3 Lenovo ThinkPad T460 Hard Drive Replacement: passo 10, immagine 3 di 3
    • Use your hand to lift up the hard drive by a few millimeters.
    • Pull the hard drive to the left to detach it from its connector, removing it from the laptop.
Conclusione
Altre 4 persone hanno completato questa guida.
Kristen Gismondi
Membro da: 11/12/14
92.132 Reputazione
241 Guide realizzate
iFixit Membro di iFixit
Staff
118 Membri
19.465 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 64
Ultimi 30 Giorni: 220
Tutti i Tempi: 11,823
