Salta al contenuto principale
Lenovo Legion Y7000P SSD Replacement
Spencer Day
Spencer Day e un altro collaboratore
Ultimo aggiornamento il April 4, 2025
15 - 20 minuti
Moderato
Introduzione
Vai al passo 1
Use this guide to replace or upgrade the M.2 2280 SSD in your Lenovo Legion Y7000P laptop.
This laptop is compatible with PCIe NVMe Gen 3 and 4 SSDs.
Before you perform this repair, back up your existing SSD if possible. If you're replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Lenovo Legion Y7000P SSD Replacement, Prepare your laptop for disassembly: passo 1, immagine 1 di 2 Lenovo Legion Y7000P SSD Replacement, Prepare your laptop for disassembly: passo 1, immagine 2 di 2
    • Allow your laptop's battery to drain below 25% before starting this repair—a charged battery may catch fire if damaged.
    • Unplug all cables and fully shut down your laptop.
  2. Lenovo Legion Y7000P SSD Replacement, Flip your laptop over: passo 2, immagine 1 di 1
    • Flip your laptop over so the rubber feet are facing up.
  3. Lenovo Legion Y7000P SSD Replacement, Unfasten the back cover: passo 3, immagine 1 di 2 Lenovo Legion Y7000P SSD Replacement, Unfasten the back cover: passo 3, immagine 2 di 2
    • Use a Phillips screwdriver to remove the 11 screws securing the back cover:
    • Five 11.5 mm‑long screws
    • Six 4.7 mm-long screws
  4. Lenovo Legion Y7000P SSD Replacement, Insert an opening pick: passo 4, immagine 1 di 2 Lenovo Legion Y7000P SSD Replacement, Insert an opening pick: passo 4, immagine 2 di 2
    • Insert the flat side of an opening pick between the top right corner of the back cover and frame.
  5. Lenovo Legion Y7000P SSD Replacement, Release the back cover's clips: passo 5, immagine 1 di 3 Lenovo Legion Y7000P SSD Replacement, Release the back cover's clips: passo 5, immagine 2 di 3 Lenovo Legion Y7000P SSD Replacement, Release the back cover's clips: passo 5, immagine 3 di 3
    • Plastic clips secure the back cover to the frame. You'll hear and feel them release as you work.
    • Keep the pick angled upwards while sliding to help release the clips.
    • Slide the opening pick down the right edge and around the bottom right corner to release the clips.
  6. Lenovo Legion Y7000P SSD Replacement: passo 6, immagine 1 di 3 Lenovo Legion Y7000P SSD Replacement: passo 6, immagine 2 di 3 Lenovo Legion Y7000P SSD Replacement: passo 6, immagine 3 di 3
    • Slide the opening pick along the front edge and up to the top left corner to release the remaining clips securing the back cover.
  7. Lenovo Legion Y7000P SSD Replacement, Remove the back cover: passo 7, immagine 1 di 3 Lenovo Legion Y7000P SSD Replacement, Remove the back cover: passo 7, immagine 2 di 3 Lenovo Legion Y7000P SSD Replacement, Remove the back cover: passo 7, immagine 3 di 3
    • Remove the back cover.
  8. Lenovo Legion Y7000P SSD Replacement, Reassembly information: passo 8, immagine 1 di 3 Lenovo Legion Y7000P SSD Replacement, Reassembly information: passo 8, immagine 2 di 3 Lenovo Legion Y7000P SSD Replacement, Reassembly information: passo 8, immagine 3 di 3
    • During reassembly:
    • Slide the two tabs near the center of the back cover's top edge under the hinge cover.
    • Press down firmly around the perimeter of the back cover to engage all the clips.
  9. Lenovo Legion Y7000P SSD Replacement, Heat the black cover: passo 9, immagine 1 di 2 Lenovo Legion Y7000P SSD Replacement, Heat the black cover: passo 9, immagine 2 di 2
    • A stiff, black cover runs across the heatsink and fans.
    • Removing the cover makes repairs much easier, but isn't required. If you don't want to remove the cover, you can roll it onto itself to keep it out of the way and skip the next two steps.
    • Heat an iOpener and apply it to the cover for two minutes.
    • You can also use a hair dryer. Follow this guide for more instructions.
  10. Lenovo Legion Y7000P SSD Replacement, Remove the cover: passo 10, immagine 1 di 3 Lenovo Legion Y7000P SSD Replacement, Remove the cover: passo 10, immagine 2 di 3 Lenovo Legion Y7000P SSD Replacement, Remove the cover: passo 10, immagine 3 di 3
    • Gently peel up and remove the black cover.
    • During reassembly, press the cover back into place using the residual adhesive.
  11. Lenovo Legion Y7000P SSD Replacement, Disconnect the battery: passo 11, immagine 1 di 3 Lenovo Legion Y7000P SSD Replacement, Disconnect the battery: passo 11, immagine 2 di 3 Lenovo Legion Y7000P SSD Replacement, Disconnect the battery: passo 11, immagine 3 di 3
    • Use the flat end of a spudger to push the battery connector straight out of its socket.
    • Push the tab on top of the battery connector, not the wires themselves.
  12. Lenovo Legion Y7000P SSD Replacement, Unfasten the SSD: passo 12, immagine 1 di 2 Lenovo Legion Y7000P SSD Replacement, Unfasten the SSD: passo 12, immagine 2 di 2
    • Use a Phillips screwdriver to remove the 3.9 mm‑long screw securing the SSD.
    • The SSD will pop up at a slight angle with the screw removed.
  13. Lenovo Legion Y7000P SSD Replacement, Remove the SSD: passo 13, immagine 1 di 2 Lenovo Legion Y7000P SSD Replacement, Remove the SSD: passo 13, immagine 2 di 2
    • Pull the SSD straight out of its socket and remove it.
    • During reassembly, insert the SSD at a slight downward angle into its socket.
Conclusione
Check your repair by running hardware tests with Lenovo Diagnostics.
Spencer Day
Membro da: 09/14/22
112.197 Reputazione
811 Guide realizzate
iFixit Membro di iFixit
Staff
120 Membri
20.083 Guide realizzate
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 91
Ultimi 30 Giorni: 561
Tutti i Tempi: 1,937
