Lenovo Legion 5 15ACH6H Right SSD Replacement
Introduzione
Vai al passo 1Use this guide to upgrade or replace the right side M.2 solid-state drive (SSD) in a Lenovo Legion 5 15ACH6H gaming laptop. This laptop is only compatible with NVME SSDs, and is therefore not compatible with SATA SSDs.
Before you perform this repair, back up your existing SSD if possible. If you are replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD.
Finally, be sure to completely power off and unplug your laptop. Make sure the laptop is not in standby, sleep, or hibernation mode.
Cosa ti serve
Kit di riparazione
Questi kit contengono tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
Mostra di più…
Use a Phillips screwdriver to remove the following ten screws securing the back cover to frame:
Six 12.5 mm PH1 screws
Four 4.7 mm PH1 screws
Insert the rounded edge of an opening pick between the back cover and the frame in the lower right corner.
Insert the edge of an opening pick between the back cover and the frame on the right edge.
Angle the pick to about 30˚ and slide down the left edge to release the clips.
Repeat the same procedure on the left edge to release the clips.
Position the laptop vertically so you can easily access the plastic vents.
Slide the rounded edge of an opening pick between the frame and the plastic vents on the left side near the USB-C port.
Rotate the pick so that it is positioned on top of the plastic vents.
Slide the opening pick between the frame and the plastic vents on the right side near the USB-A port.
Use the pointed end of a spudger to push each side of the battery connector to loosen it.
Use a Phillips screwdriver to remove the three 5.1 mm PH00 screws securing the right SSD shield to the motherboard.
Grip the edges of the SSD near the screw indent.
Gently pull to remove the SSD.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Lenovo Legion answers community for help.
Altre 4 persone hanno completato questa guida.
5 Commenti
if I leave one SSD of such a company, and change the right or left one to Samsung, will they function normally together?
i bad speak english but i was able write you 👍
Tell me please where RAM
Won't there be a problem if I install a 2TB drive even though the manufacturer limits it to 1TB?
no problem i installed one
