Salta al contenuto principale
JBL Go 4 Battery Replacement
Cosa ti serve
  1. JBL Go 4 Battery Replacement, Battery: passo 1, immagine 1 di 3 JBL Go 4 Battery Replacement, Battery: passo 1, immagine 2 di 3 JBL Go 4 Battery Replacement, Battery: passo 1, immagine 3 di 3
    • Insert an opening tool into the seam in between the grille and chassis, in the top corner opposite the strap.
    • Slide the tool along the edge of the housing until the grille releases.
    • Remove the grille.
    • Be sure that the battery has been drained completely before attempting this replacement.
    Chiedi a FixBot
    Aggiungi Commento
  2. JBL Go 4 Battery Replacement: passo 2, immagine 1 di 3 JBL Go 4 Battery Replacement: passo 2, immagine 2 di 3 JBL Go 4 Battery Replacement: passo 2, immagine 3 di 3
    • Insert an opening tool in the opposite corner, lifting carefully.
    • Slide the tool along the edge until the cover pops off.
    • Gently pull the housing up and to the side.
    • When the plate becomes loose, be incredibly gentle to avoid damaging the cable that connects the battery to the housing.
    Chiedi a FixBot
    Aggiungi Commento
  3. JBL Go 4 Battery Replacement: passo 3, immagine 1 di 2 JBL Go 4 Battery Replacement: passo 3, immagine 2 di 2
    • Find the connection between the motherboard and the battery cable as labeled.
    • Gently depress the plastic tabs and slowly wiggle the connector until it comes free.
    • Be incredibly gentle with this connector as any excessive force can damage the motherboard.
    Chiedi a FixBot
    Aggiungi Commento
  4. JBL Go 4 Battery Replacement: passo 4, immagine 1 di 2 JBL Go 4 Battery Replacement: passo 4, immagine 2 di 2
    • Insert an opening tool beneath the battery, on the side opposite to the battery cable.
    • Using a lever motion, pry the battery out slowly, sliding it further under to break the adhesive up.
    • It's important to note that the battery is held on with a small adhesive pad, so more force than should feel necessary will be needed.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
For optimal performance, after completing this guide, calibrate your newly installed battery.
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Jackosn Caron
Membro da: 03/20/25
255 Reputazione
2 guide realizzate
2Commenti sulla guida
Great guide, thanks! Small point -
Typo - “Insert an opening into the seam”. I think you’re missing ‘tool’.
Alexander Dyas - Rispondi Condividi
Thanks for pointing that out, @alexanderdyas. We took care of the typo. In the future, feel free to go ahead and make the edit!
Connor Bassolino - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 3
Ultimi 7 giorni: 34
Ultimi 30 giorni: 177
Tutti i Tempi: 1,460
