Salta al contenuto principale
IBM ThinkPad T42 Display Replacement
Austin Kidd
Austin Kidd e 5 altri collaboratori
Ultimo aggiornamento il June 29, 2019
15 - 25 minuti
Moderato
Necessarie Immagini Migliori
Passi mancanti
Foto Azione
Introduzione
Vai al passo 1
Removal/repair of the display
Cosa ti serve
Strumenti
  1. IBM ThinkPad T42 Display Replacement, Bottom cover: passo 1, immagine 1 di 1
    • Use a Phillips #0 screwdriver to remove the twenty screws on the underside of the T42.
  2. IBM ThinkPad T42 Display Replacement, Rear screws: passo 2, immagine 1 di 1
    • Remove the four Phillips screws located on either side of the rear of the T42 (there are two on each end.)
    leave these four screws alone. No need to remove them.
    fredwb - Replica
    There are tiny numbers showing the lengths of the screws. 1-2-3-4 where 1 is the shortest.
    The dark red circles are not very easy to see. How about white ones?
    mattikaki - Replica
  3. IBM ThinkPad T42 Display Replacement, Keyboard and Trackpad: passo 3, immagine 1 di 1
    • Flip the laptop over and open the screen to access the keyboard and trackpad.
    • The keyboard and trackpad are connected to the motherboard. Before removing the keyboard and trackpad, disconnect both components from the motherboard, as shown in the following step.
    • The bezel and keyboard will be loose, be careful.
  4. IBM ThinkPad T42 Display Replacement: passo 4, immagine 1 di 2 IBM ThinkPad T42 Display Replacement: passo 4, immagine 2 di 2
    • Carefully maneuver the palm rest away from the keyboard, as both the keyboard and palm rest/trackpad will come off together.
    • Remember, both the keyboard and trackpad have connectors to the motherboard. Disconnect these before completely removing either component.
  5. IBM ThinkPad T42 Display Replacement, Bezel Removal: passo 5, immagine 1 di 2 IBM ThinkPad T42 Display Replacement, Bezel Removal: passo 5, immagine 2 di 2
    • Remove the plastic bezel along the edges, you may need to pry the areas circled with a spudger to remove the bezel.
  6. IBM ThinkPad T42 Display Replacement, Display Screws: passo 6, immagine 1 di 1
    • Unscrew the screws holding down the display.
    • Along with the one pictured in red, there is another one along the top right edge.
    could you post a pic of all the screws and where they go?
    Seth King - Replica
  7. IBM ThinkPad T42 Display Replacement, Display and Ribbon Cable Removal: passo 7, immagine 1 di 1
    • Carefully unplug the display ribbon on the motherboard, then carefully lift the display free from the device.
Conclusione
Altre 6 persone hanno completato questa guida.
Austin Kidd
Membro da: 04/21/10
317 Reputazione
3 Guide realizzate
Cal Poly, Team 29-76, Johann Spring 2010 Membro di Cal Poly, Team 29-76, Johann Spring 2010
CPSU-JOHANN-S10S29G76
4 Membri
37 Guide realizzate
2Commenti sulla guida
@Seth
Just use the pic numbering left to right each of the 4 rows.
Start at the top and remove in sequence, placing each on a strip of heavy tape to keep the screws in sequence.
Place a second strip on top when finished to secure the sequence until it's time to re-assemble.
Michael G - Replica
Very poor & sketchy guide! NO mention at all of how to handle the other wires involved in disconnecting the screen (lid) from the laptop base, eg: the wireless antenna connections and instructions like: "Unscrew the screws holding it down" are far too vague! holding WHAT down ffs!!!!
wbcam - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 21
Tutti i Tempi: 13,266
