Salta al contenuto principale
IBM ThinkPad T41 RAM Replacement
Marissa Blustein
Marissa Blustein e 7 altri collaboratori
Ultimo aggiornamento il 19 mar 2017
10 - 15 minuti
Moderato
Introduzione
Vai al passo 1
This simple repair guide will aid you in taking apart your IBM ThinkPad T41 laptop to reach and replace its RAM.
Cosa ti serve
Strumenti
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
Mostra di più…
  1. IBM ThinkPad T41 RAM Replacement, Keyboard: passo 1, immagine 1 di 1
    • Close the screen and turn the closed laptop over.
    • Remove all 17 screws on the bottom of the computer.
    • The multiple colors (turquoise, red, blue, orange, yellow, and purple) are for organizational purposes, indicating different screws.
    • The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
    You need to remove the battery, hard drive, and UltraDrive before starting step 1.
    cak - Replica
  2. IBM ThinkPad T41 RAM Replacement: passo 2, immagine 1 di 1
    • Remove the extra RAM cover, by lifting where the screw was and pulling out.
    If there's extra RAM under the cover, remove it by spreading the retaining clips.
    cak - Replica
  3. IBM ThinkPad T41 RAM Replacement: passo 3, immagine 1 di 1
    • Turn the laptop right side up and open the screen.
    • Lift the keyboard, using a spudger at the seam between the keyboard and trackpad.
    • Careful of the ribbon cable underneath, which may tear if the keyboard is lifted too vigorously.
  4. IBM ThinkPad T41 RAM Replacement: passo 4, immagine 1 di 1
    • Unplug the keyboard’s ribbon cable, by lifting up the edges of the plug.
    • Remove the keyboard.
  5. IBM ThinkPad T41 RAM Replacement, RAM: passo 5, immagine 1 di 1
    • Push apart the retaining clips on the RAM.
    • Note: The RAM should pop up a little bit.
  6. IBM ThinkPad T41 RAM Replacement: passo 6, immagine 1 di 1
    • Lift out the RAM chip.
Conclusione
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 7-8, Maness Spring 2010 Membro di Cal Poly, Team 7-8, Maness Spring 2010
CPSU-MANESS-S10S7G8
4 Membri
29 Guide realizzate
1Commento della guida
You only need to take out 4 screws on the bottom of the laptop that have a picture of a keyboard beside them to remove the keyboard. I don’t know why the tutorial says to take out all the screws. Other than that, great article.
Gary Thurman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 15
Tutti i Tempi: 7,565
