IBM ThinkPad T41 RAM Replacement
Introduzione
Vai al passo 1This simple repair guide will aid you in taking apart your IBM ThinkPad T41 laptop to reach and replace its RAM.
Cosa ti serve
Strumenti
Close the screen and turn the closed laptop over.
Remove all 17 screws on the bottom of the computer.
The yellow marker at the rear denotes the UltraBay device retaining screw. This screw is optional as the UltraBay mechanism will hold the drive or battery in place anyway. The yellow marker at the front denotes the hard disk caddy retaining screw.
Altre 3 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti1Commento della guida
You only need to take out 4 screws on the bottom of the laptop that have a picture of a keyboard beside them to remove the keyboard. I don’t know why the tutorial says to take out all the screws. Other than that, great article.
You need to remove the battery, hard drive, and UltraDrive before starting step 1.
cak - Replica
