Salta al contenuto principale
Huawei S10 Tablet  USB Charge Port Replacement
Harvey
Harvey e 2 altri collaboratori
Ultimo aggiornamento il August 5, 2024
10 - 15 minuti
Facile
Guida fornita dalla comunità
  1. Huawei S10 Tablet  USB Charge Port Replacement, SIM & Micro SD Card removal: passo 1, immagine 1 di 2 Huawei S10 Tablet  USB Charge Port Replacement, SIM & Micro SD Card removal: passo 1, immagine 2 di 2
    • Open the cover and press the SIM card and Micro SD card in to release them both.
    • Remove the screw under the hinge cover.
  2. Huawei S10 Tablet  USB Charge Port Replacement, Remove Back Cover: passo 2, immagine 1 di 1
    • Use a prying tool to loosen the back cover from the display.
    • There are plastic clips holding the display and back cover together, but they come apart quite easily.
  3. Huawei S10 Tablet  USB Charge Port Replacement, Remover Display Cable: passo 3, immagine 1 di 1
    • Carefully separate the display unit from the back cover, but not too far.
    • There is a cable connecting the two together.
    • Lift the ZIF Connector and remove the Display Cable.
    • Lay the display to one side.
  4. Huawei S10 Tablet  USB Charge Port Replacement, USB Charger Port Removal: passo 4, immagine 1 di 2 Huawei S10 Tablet  USB Charge Port Replacement, USB Charger Port Removal: passo 4, immagine 2 di 2
    • Flip the ZIF connector to loosen the flex cable for the USB charger port.
    • It is possible the cable is glued down, sliding a flat tip underneath should be enough to loosen it for removal.
    • Remove the two screws holding the charger port in place.
  5. Huawei S10 Tablet  USB Charge Port Replacement, Install New Charger Port: passo 5, immagine 1 di 2 Huawei S10 Tablet  USB Charge Port Replacement, Install New Charger Port: passo 5, immagine 2 di 2
    • Install the new charger port, Insert the cable in the ZIF connector and test to make sure it charges. Replace the screws for the USB Board
    • Insert the display into the back cover.
    • Replace the screw by the SIM card / Micro SD card slot.
    • Completed!
Conclusione
Altre 2 persone hanno completato questa guida.
Harvey
Membro da: 02/15/16
5.820 Reputazione
10 Guide realizzate
3Commenti sulla guida
Is this charger available
Doyin Nwakanma - Replica
Charger port for Huawei s10
My s10 is not charging,if i plug it will show as if it was going to charge but it won't so what do i do in this situation
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 32
Tutti i Tempi: 3,045
