Salta al contenuto principale
How to fix Mobee Magic Mouse disconnection issues
Peter Barnett
Peter Barnett e 3 altri collaboratori
Ultimo aggiornamento il 18 ott 2023
Nessuna stima
Molto facile
Guida fornita dalla comunità
Introduzione
I came here looking for a solution to my intermittent connection problems on my Mobee Magic Mouse - Apple iMac. I could not find anything, but I found this YouTube guide which has solved the problem.
Cosa ti serve
Strumenti
Mostra di più…
Istruzioni Video
Linea Traguardo
Altre 30 persone hanno completato questa guida.
5Commenti sulla guida
I disassembled the Mobee battery pack by removing the 2 tiny screws holding the battery-cover together. One of the batteries had both poles covered with small pieces of greyish tape. Looked like someone forgot to remove them at assembly. I removed the tape. Works well now.
Leuk
BEANTWOORDEN
YatLok Mok - Replica
I thought I had to buy a new mouse until I found this. Foil proved it. Now for the permanent fix with the solder! Thank you.
Steve Gilbert - Replica
The batteries inside the mobee are AAA, not AA. I replaced them some time ago :)
Arjen Gerstel - Replica
I use regular rechargeable batteries, not Mobee ones, but also had a lot of random disconnects. Had read all I could find on the subject but no luck. Finally understood that the problem is on the pointy end of the batteries! So far so good, no more disconnects! Thank you!
cazumanc - Replica
What is the screw type and size for the Magic Mouse battery pack? They're so small I can barely see them! Are they tiny Allen/Hex heads?
Jeffrey Powell - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 31
Ultimi 30 Giorni: 123
Tutti i Tempi: 39,663
