Salta al contenuto principale
How to Clean the HP DeskJet 3524 Printhead
Kevin D
Kevin D e 11 altri collaboratori
Ultimo aggiornamento il 10 apr 2023
20 minuti - 2 ore
Moderato
Guida fornita dalla comunità
Introduzione
Vai al passo 1
This guide provides direction on cleaning the print-head in your HP DeskJet 3524 printer. The print-head is the mechanism which transfers ink onto the paper. The HP DeskJet 3524 user manual also provides additional directions for cleaning the print-head.
Cosa ti serve
Strumenti
Mostra di più…
  1. How to Clean the HP DeskJet 3524 Printhead, How to Clean the HP DeskJet 3524 Printhead: passo 1, immagine 1 di 3 How to Clean the HP DeskJet 3524 Printhead, How to Clean the HP DeskJet 3524 Printhead: passo 1, immagine 2 di 3 How to Clean the HP DeskJet 3524 Printhead, How to Clean the HP DeskJet 3524 Printhead: passo 1, immagine 3 di 3
    • Power on the printer.
    • To access the cartridge door, locate the two tabs on the left and right side of the printer. Lift up on the tabs and the print wagon will move into the access area.
    • After the wagon is accessible, the print-head will center itself in the printer. Once it is centered, remove the ink cartridges. To do this, press on the front tab of each cartridge. After the cartridges are removed, wrap them in a paper towel and set them to the side.
    • With the print-head still accessible in the center, power off the printer and unplug the machine.
  2. How to Clean the HP DeskJet 3524 Printhead: passo 2, immagine 1 di 2 How to Clean the HP DeskJet 3524 Printhead: passo 2, immagine 2 di 2
    • Next, apply pressure on the "clean out door." The door will loosen and allow removal.
  3. How to Clean the HP DeskJet 3524 Printhead: passo 3, immagine 1 di 2 How to Clean the HP DeskJet 3524 Printhead: passo 3, immagine 2 di 2
    • Next, locate the seven torx screws (highlighted in red circles). To avoid confusion when reassembling later, we suggest drawing a picture of the printer and taping the screws to the image.
    • After removing the seven screws, loosen the lever from the scanner compartment.
    First remove the lever so you can access the two top screws. Remove the lever by pulling it while pushing its top hinge.
    Peter Shams - Replica
    Hold the top lid so it doesn't crash down behind the printer
    Ken Brown - Replica
  4. How to Clean the HP DeskJet 3524 Printhead: passo 4, immagine 1 di 3 How to Clean the HP DeskJet 3524 Printhead: passo 4, immagine 2 di 3 How to Clean the HP DeskJet 3524 Printhead: passo 4, immagine 3 di 3
    • Next, remove the orange cover. Use caution as the display unit is still attached to the cover. If you pull the cover off too quickly, you could tear the flat cable.
    • In the second and third pictures, you will see 2 black plastic buttons. Push on the buttons and the display unit will separate from the orange cover.
    • When reassembling, ensure the white flat ribbon cable is correctly attached. If it is not attached correctly, you will be unable to push the orange cover closed.
  5. How to Clean the HP DeskJet 3524 Printhead: passo 5, immagine 1 di 1
    • Next, locate the 2 iron springs and remove with pliers.
    • After removing the springs, gently remove the print-head, but not completely as the print-head is still attached to the printed circuit board (PCB).
  6. How to Clean the HP DeskJet 3524 Printhead: passo 6, immagine 1 di 3 How to Clean the HP DeskJet 3524 Printhead: passo 6, immagine 2 di 3 How to Clean the HP DeskJet 3524 Printhead: passo 6, immagine 3 di 3
    • The printed circuit board (PCB) is the flat green object perpendicular to the printer.
    • Gently remove the PCB by unscrewing the two torx screws (highlighted in red circles).
    • Prepare to remove the flat cables attached to the PCB. They are also connected to the print-head.
    Screws for PCB are not required to be removed. You can try to take cable out white PCB is in its place.
    I agree that removing the PCB screws is not necessary and risks damaging the connection between the PCB and the Head.
    Ken Brown - Replica
  7. How to Clean the HP DeskJet 3524 Printhead: passo 7, immagine 1 di 2 How to Clean the HP DeskJet 3524 Printhead: passo 7, immagine 2 di 2
    • There are 2 flat cables. To avoid confusion when reassembling, mark one to ensure the cables are correctly matched to the socket.
    • After making the necessary markers, gently pull the flat cables away from the socket.
  8. How to Clean the HP DeskJet 3524 Printhead: passo 8, immagine 1 di 3 How to Clean the HP DeskJet 3524 Printhead: passo 8, immagine 2 di 3 How to Clean the HP DeskJet 3524 Printhead: passo 8, immagine 3 di 3
    • Because the next steps involve water, we suggest cleaning the print-head over the sink. Before you begin, gather the following: 2 bowls of water (one with distilled water and one with regular water), cotton swabs, syringe, and paper towels.
    • Fill the syringe with distilled water and spray the small holes on the print-head. Use the cotton swabs to scrub and clean the crevices.
    • Please note: You will only use the distilled water to clean the device. The regular bowl of water is used for cleaning the syringe.
  9. How to Clean the HP DeskJet 3524 Printhead: passo 9, immagine 1 di 3 How to Clean the HP DeskJet 3524 Printhead: passo 9, immagine 2 di 3 How to Clean the HP DeskJet 3524 Printhead: passo 9, immagine 3 di 3
    • Please note: It is important that you do not spill distilled water or regular water on the PCB. Use a cotton swab to clean around the PCB.
    • If you spill any water on the PCB, immediately clean the PCB with isopropyl alcohol.
    • After cleaning the print-head, allow the device to air dry for a few hours.
    • In the last picture, you will see 4 black spots in the water. That is hard, dried ink which caused my printing problem.
  10. How to Clean the HP DeskJet 3524 Printhead: passo 10, immagine 1 di 2 How to Clean the HP DeskJet 3524 Printhead: passo 10, immagine 2 di 2
    • When reassembling the print-head, ensure the black lint is under the black connector (see photo). If the blink lint is above the connector, you will receive a "wagon error" code. The wagon will essentially hit the right side of the printer, unable to go tot he left side.
    • After the printer is reassembled, print an "alignment page" and a "cleaning print head page."
    If you still get bad print results, do a few “clean print head” and “align page” and see the quality of the print each time. It should get better (I started getting a good print out after 5th attempt)
Conclusione
Altre 10 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Kevin D
Membro da: 05/02/14
7.418 Reputazione
21 Guide realizzate
6Commenti sulla guida
I put the head back and reassembled correctly , but the carriage goes left and few cms and returned hitting right side , repeats twice and shows carriage jam error.The transparent ribbon is in right slot.The gears roll noisy before stopping.
Bejoy Thomas - Replica
Had the same issue. Were you able to resolve?
joycecamara888 -
Hi Thomas,
Did you checked the black ribbon/ lint is in the correct place?
did you reset the printer ?
also check this page : https://h30434.www3.hp.com/t5/Inkjet-Pri...
Kevin D - Replica
This is a great guide. Very clear and easy to follow. You might want to add something about freeing the restraining arm on the cover.
Stephen F - Replica
Thanks for this guide. I used it on my HP3525. I added one step which was to put a few millimeters of distilled water in a small dish and stood the printheads in the water for a few minutes then I gently lifted and lowered the printheads. The amount of black ink that came off was amazing. My first print was almost perfect.
Ken Brown - Replica
I follow the work steps but now the printer say there is damage to the print head take contact with HP??? So now i xcan trow it away i think??
J.A. van Rookhuizen - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 63
Tutti i Tempi: 9,427
