Salta al contenuto principale
Harman Kardon Onyx Studio 2 Control Board Replacement
Alexandra Achtenberg
Alexandra Achtenberg e un altro collaboratore
Ultimo aggiornamento il May 5, 2021
10 - 20 minuti
Facile
Introduzione
Vai al passo 1
If the buttons on your device aren't working, it may be time to replace your control board. Follow this guide to do so.
Cosa ti serve
Strumenti
Mostra di più…
  1. Harman Kardon Onyx Studio 2 Control Board Replacement, Front Panel: passo 1, immagine 1 di 3 Harman Kardon Onyx Studio 2 Control Board Replacement, Front Panel: passo 1, immagine 2 di 3 Harman Kardon Onyx Studio 2 Control Board Replacement, Front Panel: passo 1, immagine 3 di 3
    • Using a plastic opening tool, pry off the front grill by wedging it in the notch on the front of the device.
    Where can I find a new front panel for my speaker
    consomme69 - Replica
    If I take this off can I put it back on
    Burger King - Replica
  2. Harman Kardon Onyx Studio 2 Control Board Replacement: passo 2, immagine 1 di 2 Harman Kardon Onyx Studio 2 Control Board Replacement: passo 2, immagine 2 di 2
    • Remove the five 14.4 mm T10 Torx screws.
    There are NO torxscrews. You have to pull out the rubber grille grips that are inside the screw holes FIRST, then use a regular sized Phillips head screwdriver to remove the cover. No Torxscrewdiver needed. I found this out after I had already purchased one from you guys.
    phillip columbus - Replica
    Mi bocina no tiene los 5 tornillos a la vista,tiene las cavidades ciegas, como lo abro???
    Eduardo Heine - Replica
    Yes there are no Torx screws… you have to remove the rubber grips them the Philip Screws..
    Joe Lim - Replica
  3. Harman Kardon Onyx Studio 2 Control Board Replacement: passo 3, immagine 1 di 1
    • Gently pull the front apart from the back.
  4. Harman Kardon Onyx Studio 2 Control Board Replacement: passo 4, immagine 1 di 2 Harman Kardon Onyx Studio 2 Control Board Replacement: passo 4, immagine 2 di 2
    • Remove the four wires connecting the front and back panels.
    • Pinch the connector tab and pull gently upwards.
    • Repeat for the other three connectors.
    Please can I get a replacement of my panel to the phone
    Chinedu Ogunedo - Replica
  5. Harman Kardon Onyx Studio 2 Control Board Replacement, Control Board: passo 5, immagine 1 di 1
    • Pull the silicone button band off of the outer edge of the speaker.
  6. Harman Kardon Onyx Studio 2 Control Board Replacement: passo 6, immagine 1 di 2 Harman Kardon Onyx Studio 2 Control Board Replacement: passo 6, immagine 2 di 2
    • Disconnect the two pressure connections from the circuit board.
  7. Harman Kardon Onyx Studio 2 Control Board Replacement: passo 7, immagine 1 di 2 Harman Kardon Onyx Studio 2 Control Board Replacement: passo 7, immagine 2 di 2
    • Gently remove the control board band by placing fingers in contact with it through the button openings.
    • Work from the outer edges in so as not to bend the band.
    From where to buy Control panel
    ali - Replica
    From where to buy this control panel
    ali - Replica
    My speakers control board band broke. If possible, where can I find replacement?
    Abraham Lepez - Replica
Conclusione
Altre 4 persone hanno completato questa guida.
USF Tampa, Team 16-5, Blackwell Spring 2017 Membro di USF Tampa, Team 16-5, Blackwell Spring 2017
USFT-BLACKWELL-S17S16G5
3 Membri
24 Guide realizzate
9Commenti sulla guida
Do you guys know where to get a control board, because my board is broken so i am looking for one
Zhou Yuqi - Replica
Where to get control board onyx 2.
Mike Champagne - Replica
My on/off button keeps blinking…..would somebody please email me cause I am a techno nitwit……..i’m gonna bring this piece of non chargeable crap outside and go Italian on it with the 12 gauge! SERENITY NOW!
Sincerely,
email ; jorcal3318@aol.com
Frank Vitolo - Replica
power button continually blinks. Won’t turn on, can’t pair, no other action can be taken, just the blinking power button. what’s the solution? Please share….
rachael friesen -
Speaker plays for split second then fades away like wtf
Paul Berrellez - Replica
Speaker comes on loud then Fades away like the volume is stuck on low
My volume button is not working,cant raise the volume on my speaker. And the volume is turned all the way down! Please help
Joseph Hernandez - Replica
Hi I have a problem with my control board
The volume will auto smaller and smaller until it's mute
Any idea to fix it or buy a replacement part?
And I want to buy replacement battery ,any stock available?
My email
Leoyu.leoyu@gmail.com
leoyu.leoyu - Replica
My Bluetooth connection button is not working
Joseph Bush - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 40
Tutti i Tempi: 14,965
