Salta al contenuto principale
Hair Dryer Button Switchboard Replacement
Mitch
Mitch e 11 altri collaboratori
Ultimo aggiornamento il September 14, 2024
30 minuti - 1 ora
Moderato
Attrezzi Non Corretti
Fallo a Fettine
Introduzione
Vai al passo 1
Is your hairdryer not producing the right amount of heat as it used to? This guide will show you step-by-step how to carefully replace its switchboard from an old to a new.
Before you start, please turn the hairdryer off and unplug it prior to this repair and get the following tools: a Philips #1 Screwdriver and a plastic opening tool to remove parts of the hairdryer as seen in Steps 2, 5, and 6. Have a Soldering Workstation at the ready as well.
Pay Close Attention To:
Step 2: Removing the grate will allow you to proceed to step 5 and 6, which leads to 7. If you don't, you won't be able to open the hairdryer properly.
Step 6: Utilize a plastic opening tool at step 6 to reduce the risk of cracking or damaging the hairdryer cover.
Step 7: In the photo, you can see a red circle around where the TURBO button is and a green around the SWITCHBOARD. Next to that, you'll see a circular device above a red wire - that is the internal fan that controls the heating system. In front of the fan is the motor and a heating element cover. Please be careful around these parts. If you need extra guidance or support going forward, ask a professional.
Step 8 & 9: Use the desoldering wick and a soldering iron as found in the Soldering Kit to fix the switchboard and, possibly, the turbo button. This step must be done with caution given the wiring and the process of desoldering and soldering to establish electric flow in the device.
Cosa ti serve
Strumenti
  1. Hair Dryer Button Switchboard Replacement, Nozzle: passo 1, immagine 1 di 2 Hair Dryer Button Switchboard Replacement, Nozzle: passo 1, immagine 2 di 2
    • Remove the black air concentrating nozzle by gently twisting and pulling the nozzle.
    • If nozzle is not attached, skip to next step.
  2. Hair Dryer Button Switchboard Replacement, Grating: passo 2, immagine 1 di 1
    • Using a screwdriver, remove the screw located underneath the air concentrating nozzle. This screw attaches the hair dryer body to the hair dryer grating.
    • For most hair dryers, use a Phillips #1 screwdriver. For hair dryers with smaller screws, consider using a Phillips #00 screwdriver.
  3. Hair Dryer Button Switchboard Replacement: passo 3, immagine 1 di 1
    • Detach the hair dryer grating from the body by gently twisting the grating from side to side.
  4. Hair Dryer Button Switchboard Replacement: passo 4, immagine 1 di 1
    • Separate the hair dryer grating into the three pieces seen in the image.
  5. Hair Dryer Button Switchboard Replacement, Button Switchboard: passo 5, immagine 1 di 1
    • Using a Phillips #1 Screwdriver, remove the screws located on the hair dryer handle.
  6. Hair Dryer Button Switchboard Replacement: passo 6, immagine 1 di 1
  7. Hair Dryer Button Switchboard Replacement: passo 7, immagine 1 di 1
    • The hairdryer is now disassembled. The fan, motor, heating element cover, and internal wiring are exposed.
    • Please be careful around these parts of the hairdryer. Even if the device is off, they may be warm to the touch.
    • This is the TURBO button.
    • This is the SWITCHBOARD button.
  8. Hair Dryer Button Switchboard Replacement: passo 8, immagine 1 di 1
    • Gently pull the turbo button away from the hair dryer body.
    • If the turbo setting is still not working after you replace the switchboard, consider using soldering techniques to replace the turbo button. It may be why the hairdryer is not working properly, too.
    اين توجد مفاتيح تشغيل جديدة
    حمادة احمد - Replica
  9. Hair Dryer Button Switchboard Replacement: passo 9, immagine 1 di 1
    • Gently pull the button switchboard away from the hair dryer body.
    • Using a desoldering wick and a soldering iron, desolder the wires. This will help with the electrical connection issues that may be occurring.
    • Refer to the following page for desoldering instructions: Soldering Skills
    Where can I get a new Switch Board for a Conair hair dryer?
    William Kunszt - Replica
Conclusione
Mitch
Membro da: 10/04/12
34 Reputazione
5 Guide realizzate
Cal Poly, Team 24-29, Regan Fall 2012 Membro di Cal Poly, Team 24-29, Regan Fall 2012
CPSU-REGAN-F12S24G29
5 Membri
11 Guide realizzate
1Commento della guida
I have a hairdryer with loose wire. Can you help me to find where the wire should be welded?
ziad musa - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 69
Tutti i Tempi: 8,969
