Salta al contenuto principale
HP Stream 8 Battery Replacement
Nick Miller
Nick Miller e 10 altri collaboratori
Ultimo aggiornamento il January 4, 2024
40 minuti - 1 ora
Moderato
Introduzione
Vai al passo 1
If your HP Stream 8 model 5801 battery needs to be replaced because it has lost the ability to hold a charge, then this is the guide for you.
The battery provides power to the tablet. A faulty battery or battery that isn't able to hold a charge properly needs to be replaced.
Before using this guide, make sure you are using the original HP brand cable and AC/DC adapter. You should also make sure you have the adapter plugged directly into the wall outlet. If you charge your tablet for an hour and still have no charge, continue to follow this guide and replace your battery.
A punctured battery can cause a dangerous fire. If your battery is swollen, please review What to do with a swollen battery.
Before you begin, power down your device completely and disconnect from any power source.
Cosa ti serve
Strumenti
Mostra di più…
  1. HP Stream 8 Battery Replacement, Midframe: passo 1, immagine 1 di 1
    • Use your nail or a spudger to pry the back cover off of the device.
    Hey bro are you have a battery for stream 8
    Kashif joiya - Replica
  2. HP Stream 8 Battery Replacement: passo 2, immagine 1 di 1
    • Slide your finger around the rest of the back cover, lifting it completely off of the device.
  3. HP Stream 8 Battery Replacement: passo 3, immagine 1 di 1
    • Remove ten Phillips #00 screws from the inside cover.
  4. HP Stream 8 Battery Replacement: passo 4, immagine 1 di 1
    • Pry up the inside cover the same way as in the first step.
  5. HP Stream 8 Battery Replacement, Front-Facing Camera: passo 5, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Lift up on the small black tab at the connection point to unlock the flex ribbon cable using the tweezers.
  6. HP Stream 8 Battery Replacement: passo 6, immagine 1 di 1
    • Remove the front facing camera with tweezers.
  7. HP Stream 8 Battery Replacement, Rear-Facing Camera: passo 7, immagine 1 di 1
    • Carefully pry up the gray metal piece on the end of the flex ribbon cable using tweezers.
  8. HP Stream 8 Battery Replacement: passo 8, immagine 1 di 1
    • Remove the back facing camera with the tweezers.
  9. HP Stream 8 Battery Replacement, Motherboard: passo 9, immagine 1 di 1
    • Carefully remove the battery connector from the system board using the tweezers.
  10. HP Stream 8 Battery Replacement: passo 10, immagine 1 di 1
    • Lift up on the small black tab to unlock the LCD screen flex ribbon cable using the tweezers.
  11. HP Stream 8 Battery Replacement: passo 11, immagine 1 di 1
    • Carefully remove the LCD screen flex ribbon cable from the system board using the tweezers.
  12. HP Stream 8 Battery Replacement: passo 12, immagine 1 di 1
    • Carefully remove the USB flex ribbon cable from the connection point on the system board using the tweezers.
  13. HP Stream 8 Battery Replacement: passo 13, immagine 1 di 1
    • Remove the two Phillips using the screwdriver with a PH00 Phillips head.
  14. HP Stream 8 Battery Replacement: passo 14, immagine 1 di 1
    • Remove the motherboard from the device.
  15. HP Stream 8 Battery Replacement, Battery: passo 15, immagine 1 di 1
    • Remove the 6 PH00 Phillips screws.
  16. HP Stream 8 Battery Replacement: passo 16, immagine 1 di 1
    • The battery can now be removed from the device.
    Di mana saya bisa membeli baterai prnggantinya?
    Taman Sutarman (Park Tam Soet) - Replica
Conclusione
Altre 3 persone hanno completato questa guida.
Nick Miller
Membro da: 04/11/16
669 Reputazione
6 Guide realizzate
Cal Poly, Team 34-14, Maness Spring 2016 Membro di Cal Poly, Team 34-14, Maness Spring 2016
CPSU-MANESS-S16S34G14
4 Membri
12 Guide realizzate
2Commenti sulla guida
We're I can buy battery for stream 8 tablet 4000mah
Marlon Ultado - Replica
Bonjour,
pouvez-vous m'indiquer où je pourrais trouver une batterie compatible ?
Bien cordialement
GAVALDA - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 39
Tutti i Tempi: 5,029
