Salta al contenuto principale
HP EliteBook 850 G3 Display Assembly Replacement
Annabeth Grover
Annabeth Grover e 4 altri collaboratori
Ultimo aggiornamento il January 3, 2024
20 minuti
Moderato
Introduzione
Vai al passo 1
If your HP EliteBook 850 G3 display assembly is malfunctioning use this guide to replace it. The display screen on your computer is the panel that is inside the device, which displays the image. If you are experiencing a blank screen on a powered computer or a gray flickering screen, be sure to first rule out troubleshooting options. Then Use this display assembly guide to repair a broken screen display. Before beginning, make sure to power off your laptop completely and disconnect from any external power source. Before using this guide, feel free to check out the troubleshooting page to see if any issues can be resolved without a replacement.
Cosa ti serve
Strumenti
Mostra di più…
  1. HP EliteBook 850 G3 Display Assembly Replacement, Battery: passo 1, immagine 1 di 1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face up.
  2. HP EliteBook 850 G3 Display Assembly Replacement, Unscrew the bottom: passo 2, immagine 1 di 2 HP EliteBook 850 G3 Display Assembly Replacement, Unscrew the bottom: passo 2, immagine 2 di 2
    • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
  3. HP EliteBook 850 G3 Display Assembly Replacement: passo 3, immagine 1 di 2 HP EliteBook 850 G3 Display Assembly Replacement: passo 3, immagine 2 di 2
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry the back off.
  4. HP EliteBook 850 G3 Display Assembly Replacement, Remove the battery screws: passo 4, immagine 1 di 2 HP EliteBook 850 G3 Display Assembly Replacement, Remove the battery screws: passo 4, immagine 2 di 2
    • Use the Phillips #0 screwdriver to remove the two battery screws.
    • The two battery screws are captured screws and do not come out.
  5. HP EliteBook 850 G3 Display Assembly Replacement, Lift the battery: passo 5, immagine 1 di 3 HP EliteBook 850 G3 Display Assembly Replacement, Lift the battery: passo 5, immagine 2 di 3 HP EliteBook 850 G3 Display Assembly Replacement, Lift the battery: passo 5, immagine 3 di 3
    • Lift and pull the flap located at the top of the battery to remove it.
  6. HP EliteBook 850 G3 Display Assembly Replacement, WiFi Card: passo 6, immagine 1 di 1
    • Flip the laptop over so the model stickers face the ceiling.
  7. HP EliteBook 850 G3 Display Assembly Replacement: passo 7, immagine 1 di 2 HP EliteBook 850 G3 Display Assembly Replacement: passo 7, immagine 2 di 2
    The screw on the far left middle, under the card cover, is a longer screw.
    martin rodley - Replica
  8. HP EliteBook 850 G3 Display Assembly Replacement: passo 8, immagine 1 di 2 HP EliteBook 850 G3 Display Assembly Replacement: passo 8, immagine 2 di 2
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry back off.
  9. HP EliteBook 850 G3 Display Assembly Replacement: passo 9, immagine 1 di 1
    • Use the Phillips #0 screwdriver to remove the 3.3mm screw on the WiFi card.
  10. HP EliteBook 850 G3 Display Assembly Replacement: passo 10, immagine 1 di 2 HP EliteBook 850 G3 Display Assembly Replacement: passo 10, immagine 2 di 2
    • Slide out the WiFi card.
  11. HP EliteBook 850 G3 Display Assembly Replacement: passo 11, immagine 1 di 3 HP EliteBook 850 G3 Display Assembly Replacement: passo 11, immagine 2 di 3 HP EliteBook 850 G3 Display Assembly Replacement: passo 11, immagine 3 di 3
    • Disconnect the coaxial cables wires from the WiFi card.
  12. HP EliteBook 850 G3 Display Assembly Replacement, Fan: passo 12, immagine 1 di 1
    • Gently unclip the plastic frame.
  13. HP EliteBook 850 G3 Display Assembly Replacement: passo 13, immagine 1 di 3 HP EliteBook 850 G3 Display Assembly Replacement: passo 13, immagine 2 di 3 HP EliteBook 850 G3 Display Assembly Replacement: passo 13, immagine 3 di 3
    • Use a Phillips #0 screwdriver to unscrew the four captive screws located near the fan and heatsink assembly.
  14. HP EliteBook 850 G3 Display Assembly Replacement: passo 14, immagine 1 di 2 HP EliteBook 850 G3 Display Assembly Replacement: passo 14, immagine 2 di 2
    • Carefully remove the connector for the fan.
  15. HP EliteBook 850 G3 Display Assembly Replacement: passo 15, immagine 1 di 3 HP EliteBook 850 G3 Display Assembly Replacement: passo 15, immagine 2 di 3 HP EliteBook 850 G3 Display Assembly Replacement: passo 15, immagine 3 di 3
    • Carefully remove the fan and heatsink assembly from the laptop.
  16. HP EliteBook 850 G3 Display Assembly Replacement, Display Assembly: passo 16, immagine 1 di 2 HP EliteBook 850 G3 Display Assembly Replacement, Display Assembly: passo 16, immagine 2 di 2
    • Use the Phillips #0 screwdriver to remove the 7.7mm screw and six 5.8 mm screws from the corners inside the laptop.
  17. HP EliteBook 850 G3 Display Assembly Replacement: passo 17, immagine 1 di 1
    • Use the Phillips #0 screwdriver to remove the 5.7 mm screw under the plastic frame.
  18. HP EliteBook 850 G3 Display Assembly Replacement: passo 18, immagine 1 di 1
    • Use the opening pick to unplug the cable with the black tab on top.
  19. HP EliteBook 850 G3 Display Assembly Replacement: passo 19, immagine 1 di 3 HP EliteBook 850 G3 Display Assembly Replacement: passo 19, immagine 2 di 3 HP EliteBook 850 G3 Display Assembly Replacement: passo 19, immagine 3 di 3
    • Disconnect wire over gold tape and remove tape. You will have to peel the wire up to get to the tape.
    • The tape is not reusable.
  20. HP EliteBook 850 G3 Display Assembly Replacement: passo 20, immagine 1 di 2 HP EliteBook 850 G3 Display Assembly Replacement: passo 20, immagine 2 di 2
    • Remove the coaxial cables from the wifi card and from clear plastic holds. Remove the black tape and slip out from black clip.
    • This tape is not reusable.
  21. HP EliteBook 850 G3 Display Assembly Replacement: passo 21, immagine 1 di 2 HP EliteBook 850 G3 Display Assembly Replacement: passo 21, immagine 2 di 2
    • Open the top of the laptop and bend the hinges so that the metal bits in the corners will come up.
  22. HP EliteBook 850 G3 Display Assembly Replacement: passo 22, immagine 1 di 2 HP EliteBook 850 G3 Display Assembly Replacement: passo 22, immagine 2 di 2
    • Take the display assembly off.
Conclusione
Altre 2 persone hanno completato questa guida.
USF Tampa, Team S1-G1, Leahy Fall 2019 Membro di USF Tampa, Team S1-G1, Leahy Fall 2019
USFT-LEAHY-F19S1G1
4 Membri
6 Guide realizzate
3Commenti sulla guida
looks like there are duplicate steps for cover removal.
Cody White - Replica
do tou have tuchscreen assenbly for same nmodel ??
shiva netra - Replica
do upu have couch scfeen assembly for this model ; hp elitebook 450g3
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 24
Tutti i Tempi: 3,041
