Salta al contenuto principale
Google Pixel Slate Front-Facing Camera Replacement
Spencer Alonge
Spencer Alonge e 3 altri collaboratori
Ultimo aggiornamento il June 25, 2019
5 - 10 minuti
Moderato
Introduzione
Vai al passo 1
Use this guide to remove and replace the front-facing camera of your Google Pixel Slate.
Cosa ti serve
Strumenti
Mostra di più…
  1. Google Pixel Slate Front-Facing Camera Replacement, Screen: passo 1, immagine 1 di 3 Google Pixel Slate Front-Facing Camera Replacement, Screen: passo 1, immagine 2 di 3 Google Pixel Slate Front-Facing Camera Replacement, Screen: passo 1, immagine 3 di 3
    • Orient the Google Pixel Slate so that the screen is facing upwards.
    • Use the iFixit opening tool to separate screen from main body.
    • Use the suction cup to remove the screen from the body of the device.
    The tool and suction does not work for me. The adhesive is too strong.
    beep - Replica
    It’s so easy to crack the screen here. I recommend using heat to soften the bond and avoid cracking the screen. Ideally a heating pad ($$$), but a heat gun or hair dryer also does the trick. I’ve seen a temperature range of 80-90 C (matching specs from a heating pad). I heated a pizza stone to temperature to make a homemade heating pad. That worked to soften the adhesive here.
    beep - Replica
    The adhesive is very strong, and they are not just at the edge. Some of them a little further inside, and be careful not to cut the speak grill.
    Kings Lee - Replica
  2. Google Pixel Slate Front-Facing Camera Replacement: passo 2, immagine 1 di 3 Google Pixel Slate Front-Facing Camera Replacement: passo 2, immagine 2 di 3 Google Pixel Slate Front-Facing Camera Replacement: passo 2, immagine 3 di 3
    • Gently disconnect the three flat-wires from the screen.
    • Carefully separate and remove the screen from the body of the device.
    Where can I source the screen?
    Brandon Price - Replica
  3. Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: passo 3, immagine 1 di 3 Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: passo 3, immagine 2 di 3 Google Pixel Slate Front-Facing Camera Replacement, Front-Facing Camera: passo 3, immagine 3 di 3
    • Once removed, place the screen face down.
    • Peel back the black, adhesive strip covering the front camera so that the silver plate is exposed.
  4. Google Pixel Slate Front-Facing Camera Replacement: passo 4, immagine 1 di 3 Google Pixel Slate Front-Facing Camera Replacement: passo 4, immagine 2 di 3 Google Pixel Slate Front-Facing Camera Replacement: passo 4, immagine 3 di 3
    • Hold back the adhesive tape to expose the two black 2mm screws that are holding down the cover plate.
    • Use the T2 Torx screwdriver to remove the two 2mm screws.
  5. Google Pixel Slate Front-Facing Camera Replacement: passo 5, immagine 1 di 2 Google Pixel Slate Front-Facing Camera Replacement: passo 5, immagine 2 di 2
    • Once the two 2mm screws are removed, lift and remove the cover plate.
  6. Google Pixel Slate Front-Facing Camera Replacement: passo 6, immagine 1 di 2 Google Pixel Slate Front-Facing Camera Replacement: passo 6, immagine 2 di 2
    • Pull upwards on the flat wire to remove the front-facing camera from the device.
    • The camera may be secured to the screen body with adhesive tape. Apply gentle force to remove the camera by removing the tape.
Conclusione
Altre 2 persone hanno completato questa guida.
Cal Poly, Team S2-G5, Maness Spring 2019 Membro di Cal Poly, Team S2-G5, Maness Spring 2019
CPSU-MANESS-S19S2G5
4 Membri
5 Guide realizzate
1Commento della guida
Do you offer the cable that runs from the camera to the tablet motherboard or the front facing camera with cable?
Heidi Hose - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 14
Tutti i Tempi: 910
