Google Pixel C Screen Replacement
Introduzione
Vai al passo 1This guide will outline how to replace a cracked, shattered, or faulty screen on a Google Pixel C.
Use a heat gun to melt the adhesive that holds the screen to the device
Move the heat gun around the edge of the screen for approximately 1 minute, or until the screen can be lifted off in the next step.
Use a suction cup to assist in lifting the screen while prying around its edges with a plastic spudger.
If necessary use a metal spudger to pry the screen up, taking care not to scratch the device.
Detach the cables for the camera by lifting the small flap using the tip of your fingernail or a spudger. Gently pull the ribbon cable out.
Attrezzo utilizzato in questo passaggio:Tweezers$4.99
Follow the same removal procedure to detach the wide gold cable.
This is not very useful if there is no way of getting the parts.
Hi i seem to have a loose item in my pixel c causing the backlight to not light up, when it doesn’t i can bang on the device and it will come on.
my question is if i am able to remove the screen in one piece what type of adhesive do i need to re-glue it also leaving it able to be re heated to be removed in the future if need be
Altre 9 persone hanno completato questa guida.
28Commenti sulla guida
Where can a replacement screen be located?
Where can i buy a spare screen for this tablet?
Yes, I have to buy the screen too, but where??
All very nice but unfortunately useless without knowing where to get the parts :(
Ciao Lorenzo, sei poi riuscito a trovare il ricambio?
DEUTSCH
Ganz ehrlich, diese Anleitung hat mir persönlich nur teilweise weitergeholfen. Die Schritte sind ausführlich erklärt, jedoch fehlen einige wichtige Details wie z.B. die benötigte Temperaturstärke für den Air Heater um den Industriekleber schmelzen zu lassen, um das Display zu entfernen.
Dafür hätte ich mir gerne mehr Informationen gewünscht anstatt ‘stundenlang’ selbst zu experimentieren. 250°C und mindestens 2 1/2 Minuten einmal ringsherum föhnen hat den gewünschten Erfolg gebracht.
ENGLISH
Honestly, this guide only provided partial help. The steps are explained in detail, but some important details, e.g. the required temperature for the Air Heater to melt the industrial adhesive to remove the display were lacking. For that I would like to have more information instead of 'experimenting for hours' myself. 250 ° C and at least 2 1/2 minutes of guiding the heat around the frame has brought the desired success.
Hi, did you find a spare display?
Where can we get a new screen?
Nobody have lcd assembly for this?????
It seems the ifixit staff abandoned this article after creating it, as I see a lot of repeat questions regarding where to acquire a replacement screen but no answer.
I’d like to know where to acquire adhesive to get the screen tightly back in place, after I’ve opened it up. Not to mention the best way to use a heat gun on the screen, to make sure no harm comes to the screen or the parts inside.
This article is nice, but no where near complete.
I found this link
i checked that site its a scam one dont buy there ^^^i contacted some reapir shops they told me there are no parts worldwide aviable …. if someone got an broken pixel c i would but the digitizer from it
There is a MAJOR flaw with the Pixel C, the LCD ribbon! If you've had you Pixel C for any length of time, you may notice a "half-screen" blackout, or multicolored pixels. I have been through 4 now (under warranty trades) and all four did the same thing after a month or two. What I found was that the ribbon connecting the system to the LCD was loose, but this was not the issue. I found where the manufacturer had glued the LCD terminal ribbon to the LCD was partially ripped (no I did not rip it separating the unit). The ribbon appeared to be brittle and very fragile. I suspect that when the unit gets hot (playing games, etc.) and the constant pressure of taping the screen near this ribbon caused it to rip. This is an engineering flaw and the only solution is to keep replacing this digitizer screen when is starts to misbehave. Spend you $$$ on something more reliable, like a Samsung.
I have the same problem. A repairer told me the parts is not available in US now. It can be ordered from China. However, he suggested me to just give up and buy another tablet(of course - not Pixel c). It will take more than two weeks to get it shipped.
Hi Mr. Wu.I noticed what you said ‘lt can be ordered from China’. my pixel c screen was crack. l live in china if that repairer could tell u where is the china screen factory. I can help u buy this parts and sent to your place by ups. i really like pixel c,pls help me,
u can contact by hewenxin1995@gmail.com. thanks.
I have a Pixel C and the touch screen stopped working intermittently and now is completely dead. I called Google but it is 6 months out of warranty (2 year). They won’t help any further and told me that a replacement screen can’t be bought. If an address in China is found, please share it as I like the Pixel C very much and don’t have the money to buy a replacement.
HI my name Graham
Can please help me on pixel c tablet for some when I power up it's not coming on have try to do a hard reset but still want to come on.
Thanks
Graham
Hi my name is graham can you please on my pixel c tablet whe I power up it's not coming online to a hard resetbut still will come on.
Thanks
Graham -
The backlight of the screen suddenly failed, I want the check if the cables have some loose. I use the hair dryer and blade to pry the screen off , but the touch screen unexpectedly failed. I have done a lot of this stuff to the apple products, even if I crack the screen the functions remain good.
Google pixel C, What a garbage product, from all aspects!
Me too am looking for the LCD part so any one can help plz contact me at kasim.y.adam@gmail.com
Donde compro remplazo
Investigue y el problema más común en estás tablet es que el regulador de brillo deja de funcionar pero yo no sé cómo encontrarlo si alguien sabe se lo agradecería que me pase la información mi correo de contacto es el siguiente santydtkt12@gmail.com gracias entre todos ojalá encontremos una solución
