Salta al contenuto principale
Google Pixel 9a Screen Replacement
Cosa ti serve
  1. Google Pixel 9a Screen Replacement, Safety precautions: passo 1, immagine 1 di 2 Google Pixel 9a Screen Replacement, Safety precautions: passo 1, immagine 2 di 2
    • Let your Pixel's battery drain below 25% before starting this repair. A charged lithium‑ion battery may catch fire if damaged.
    • Unplug all cables and completely power down your phone.
    Chiedi a FixBot
    Aggiungi Commento
  2. Google Pixel 9a Screen Replacement, Safety precautions: passo 2, immagine 1 di 2 Google Pixel 9a Screen Replacement, Safety precautions: passo 2, immagine 2 di 2
    • Glass shards can complicate disassembly—or worse, cause injury. If your phone has a cracked screen, follow these steps:
    • Apply overlapping strips of packing tape to the cracked glass until the whole screen is covered—this will allow the suction cup to stick to the screen.
    • Only cover the glass itself—don't stick any tape to the frame.
    • Consider wearing safety glasses to protect your eyes from any glass shaken free during the repair.
    Chiedi a FixBot
    Aggiungi Commento
  3. Google Pixel 9a Screen Replacement, Heat the top edge: passo 3, immagine 1 di 1
    • The screen adhesive is very strong, requiring significant heat to soften it. If you have difficulty separating the adhesive, reheat the screen and try again.
    • Use a hair dryer, heat gun, or hot mat to heat the top edge of the screen until it's almost too hot to touch.
    • Be careful not to overheat the phone—the battery and plastic components are susceptible to heat damage. Stop heating if the frame becomes too hot to touch.
    • If you're using a hot mat, set it to 80° C (176° F) and place your phone screen side down for 10 minutes.
    Chiedi a FixBot
    Aggiungi Commento
  4. Google Pixel 9a Screen Replacement, Apply a suction handle: passo 4, immagine 1 di 2 Google Pixel 9a Screen Replacement, Apply a suction handle: passo 4, immagine 2 di 2
    • Apply a suction handle to the center of the screen's top edge.
    Chiedi a FixBot
    Aggiungi Commento
  5. Google Pixel 9a Screen Replacement, Insert your tool under the screen: passo 5, immagine 1 di 3 Google Pixel 9a Screen Replacement, Insert your tool under the screen: passo 5, immagine 2 di 3 Google Pixel 9a Screen Replacement, Insert your tool under the screen: passo 5, immagine 3 di 3
    Strumento utilizzato in questo passaggio:
    Jimmy
    $7.95
    • Don't insert any tools deeper than 2 mm, or you may damage the front camera.
    • Insert the tip of a Jimmy downward into the speaker cutout on the top edge of your phone.
    • If you don't have a Jimmy, you can use another small metal tool. Make sure it's thin and rigid.
    • Pull up on the suction handle with strong, steady force while lowering the Jimmy until it slides under the screen.
    • Inserting your tool is very difficult. Reheat the screen at any point and try again if it feels stuck.
    Chiedi a FixBot
    Aggiungi Commento
  6. Google Pixel 9a Screen Replacement, Insert an opening pick: passo 6, immagine 1 di 3 Google Pixel 9a Screen Replacement, Insert an opening pick: passo 6, immagine 2 di 3 Google Pixel 9a Screen Replacement, Insert an opening pick: passo 6, immagine 3 di 3
    • Slide the tip of an opening pick under the screen into the gap created by the Jimmy.
    • Remove the Jimmy.
    Chiedi a FixBot
    Aggiungi Commento
  7. Google Pixel 9a Screen Replacement, Separate the top edge adhesive: passo 7, immagine 1 di 3 Google Pixel 9a Screen Replacement, Separate the top edge adhesive: passo 7, immagine 2 di 3 Google Pixel 9a Screen Replacement, Separate the top edge adhesive: passo 7, immagine 3 di 3
    • Remember: Don't insert your pick deeper than 2 mm, or you may damage the front camera.
    • Slide your opening pick along the top edge of the screen to separate the adhesive securing it.
    • Leave the pick inserted under the top right corner of the screen to prevent the adhesive from re‑sealing.
    Chiedi a FixBot
    Aggiungi Commento
  8. Google Pixel 9a Screen Replacement, Remove the suction handle: passo 8, immagine 1 di 2 Google Pixel 9a Screen Replacement, Remove the suction handle: passo 8, immagine 2 di 2
    • Use the small tab to remove the suction handle from the screen.
    Chiedi a FixBot
    Aggiungi Commento
  9. Google Pixel 9a Screen Replacement, Heat the right edge of the screen: passo 9, immagine 1 di 3 Google Pixel 9a Screen Replacement, Heat the right edge of the screen: passo 9, immagine 2 di 3 Google Pixel 9a Screen Replacement, Heat the right edge of the screen: passo 9, immagine 3 di 3
    Chiedi a FixBot
    Aggiungi Commento
  10. Google Pixel 9a Screen Replacement, Separate the right edge adhesive: passo 10, immagine 1 di 3 Google Pixel 9a Screen Replacement, Separate the right edge adhesive: passo 10, immagine 2 di 3 Google Pixel 9a Screen Replacement, Separate the right edge adhesive: passo 10, immagine 3 di 3
    • Slide your opening pick down the right edge to separate the adhesive securing it.
    • Leave the pick inserted under the bottom right corner of the screen to prevent the adhesive from re‑sealing.
    Chiedi a FixBot
    Aggiungi Commento
  11. Google Pixel 9a Screen Replacement, Heat the bottom edge: passo 11, immagine 1 di 1
    Chiedi a FixBot
    Aggiungi Commento
  12. Google Pixel 9a Screen Replacement, Separate the bottom edge adhesive: passo 12, immagine 1 di 2 Google Pixel 9a Screen Replacement, Separate the bottom edge adhesive: passo 12, immagine 2 di 2
    • Slide your opening pick along the bottom edge of the screen to separate the adhesive securing it.
    • Leave the pick inserted under the bottom left corner of the screen to prevent the adhesive from re‑sealing.
    Chiedi a FixBot
    Aggiungi Commento
  13. Google Pixel 9a Screen Replacement, Heat the left edge: passo 13, immagine 1 di 3 Google Pixel 9a Screen Replacement, Heat the left edge: passo 13, immagine 2 di 3 Google Pixel 9a Screen Replacement, Heat the left edge: passo 13, immagine 3 di 3
    Chiedi a FixBot
    Aggiungi Commento
  14. Google Pixel 9a Screen Replacement, Separate the left edge adhesive: passo 14, immagine 1 di 3 Google Pixel 9a Screen Replacement, Separate the left edge adhesive: passo 14, immagine 2 di 3 Google Pixel 9a Screen Replacement, Separate the left edge adhesive: passo 14, immagine 3 di 3
    • Be careful not to insert your pick too far near the center of the left edge, or you may damage the screen cable.
    • Slide your opening pick up the left edge to separate the adhesive securing it.
    Chiedi a FixBot
    Aggiungi Commento
  15. Google Pixel 9a Screen Replacement, Lay the screen flat: passo 15, immagine 1 di 2 Google Pixel 9a Screen Replacement, Lay the screen flat: passo 15, immagine 2 di 2
    • Swing the screen over the left edge of your phone (like opening the cover of a book) and lay it down flat.
    • If you feel resistance when lifting the screen, use an opening pick to separate any leftover adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  16. Google Pixel 9a Screen Replacement, Remove the cable cover screw: passo 16, immagine 1 di 2 Google Pixel 9a Screen Replacement, Remove the cable cover screw: passo 16, immagine 2 di 2
    • The battery is exposed through a small cutout near the screen cable. Be very careful not to damage it with your tools.
    • Use a Torx Plus 3IP screwdriver to remove the 1.7 mm‑long screw securing the cable cover.
    Chiedi a FixBot
    Aggiungi Commento
  17. Google Pixel 9a Screen Replacement, Remove the cable cover: passo 17, immagine 1 di 3 Google Pixel 9a Screen Replacement, Remove the cable cover: passo 17, immagine 2 di 3 Google Pixel 9a Screen Replacement, Remove the cable cover: passo 17, immagine 3 di 3
    • Use tweezers or your fingers to lift and remove the cable cover.
    Chiedi a FixBot
    Aggiungi Commento
  18. Google Pixel 9a Screen Replacement: passo 18, immagine 1 di 2 Google Pixel 9a Screen Replacement: passo 18, immagine 2 di 2
    • Remember: The battery is exposed through a small cutout near the screen cable. Be very careful not to damage it with your tool.
    • Use the point of a spudger to pry up and disconnect the screen press connector from its top left corner.
    Chiedi a FixBot
    Aggiungi Commento
  19. Google Pixel 9a Screen Replacement, Remove the screen: passo 19, immagine 1 di 1
    • Remove the screen.
    Chiedi a FixBot
    Aggiungi Commento
  20. Google Pixel 9a Screen Replacement, Disassembly complete: passo 20, immagine 1 di 1
    • Congratulations on completing disassembly! The remaining steps will show how to reassemble your phone.
    Chiedi a FixBot
    Aggiungi Commento
  21. Google Pixel 9a Screen Replacement, Clean the frame: passo 21, immagine 1 di 2 Google Pixel 9a Screen Replacement, Clean the frame: passo 21, immagine 2 di 2
    • Take your time during this step. A clean frame allows replacement adhesive to lay totally flat, ensuring a better bond.
    • Use a spudger and tweezers to scrape up and remove any screen adhesive from the perimeter of the frame.
    • Most of the adhesive should have stayed on the screen during removal, so there may not be any adhesive to remove.
    • Using some high‑concentration (>90%) isopropyl alcohol and a lint‑free cloth (or coffee filter), clean the areas of the frame where the adhesive was.
    • Be careful not to damage the silver foam pads around the perimeter of the phone.
    • Wait for any alcohol to dry completely before continuing.
    Chiedi a FixBot
    Aggiungi Commento
  22. Google Pixel 9a Screen Replacement, Find the adhesive orientation: passo 22, immagine 1 di 2 Google Pixel 9a Screen Replacement, Find the adhesive orientation: passo 22, immagine 2 di 2
    • Check if your replacement screen comes with adhesive pre‑installed around its perimeter. If it does, skip down six steps. If it doesn't, follow the next six steps to install new screen adhesive on the frame.
    • Before applying the screen adhesive, make sure you know how it will sit on the frame. If you apply the adhesive incorrectly, you'll need to restart with new adhesive.
    • Hold the adhesive above the frame to find its orientation. Use cutouts in the liner to help visualize how it will lay in the frame.
    Chiedi a FixBot
    Aggiungi Commento
  23. Google Pixel 9a Screen Replacement, Peel the liner halfway down: passo 23, immagine 1 di 1
    • Peel down the top half of the large, clear liner to expose the adhesive—don't fully remove the liner yet.
    Chiedi a FixBot
    Aggiungi Commento
  24. Google Pixel 9a Screen Replacement, Apply the adhesive: passo 24, immagine 1 di 3 Google Pixel 9a Screen Replacement, Apply the adhesive: passo 24, immagine 2 di 3 Google Pixel 9a Screen Replacement, Apply the adhesive: passo 24, immagine 3 di 3
    • Take your time aligning the adhesive with the frame—it's very sticky and can't be moved after you apply it.
    • With the larger, clear liner folded towards the bottom of the phone, lay the exposed top edge of the adhesive onto the frame.
    • Use the lip of the frame to help align the adhesive.
    • Once the top edge is properly aligned, gently press down on the top corners with your fingers to secure the adhesive.
    Chiedi a FixBot
    Aggiungi Commento
  25. Google Pixel 9a Screen Replacement: passo 25, immagine 1 di 3 Google Pixel 9a Screen Replacement: passo 25, immagine 2 di 3 Google Pixel 9a Screen Replacement: passo 25, immagine 3 di 3
    • Slowly lay the rest of the adhesive onto the frame, pressing it into place and peeling away the larger liner as you go.
    Chiedi a FixBot
    Aggiungi Commento
  26. Google Pixel 9a Screen Replacement, Remove the top liner: passo 26, immagine 1 di 3 Google Pixel 9a Screen Replacement, Remove the top liner: passo 26, immagine 2 di 3 Google Pixel 9a Screen Replacement, Remove the top liner: passo 26, immagine 3 di 3
    • Use the pull tab to remove the large, colored liner.
    Chiedi a FixBot
    Aggiungi Commento
  27. Google Pixel 9a Screen Replacement, Secure the adhesive: passo 27, immagine 1 di 3 Google Pixel 9a Screen Replacement, Secure the adhesive: passo 27, immagine 2 di 3 Google Pixel 9a Screen Replacement, Secure the adhesive: passo 27, immagine 3 di 3
    • Use a spudger to press down firmly on the screen adhesive around the perimeter of your phone to secure it to the frame.
    Chiedi a FixBot
    Aggiungi Commento
  28. Google Pixel 9a Screen Replacement, Remove the screen liners: passo 28, immagine 1 di 3 Google Pixel 9a Screen Replacement, Remove the screen liners: passo 28, immagine 2 di 3 Google Pixel 9a Screen Replacement, Remove the screen liners: passo 28, immagine 3 di 3
    • Your replacement screen has various protective liners and pieces of tape on the underside that must be removed before installing the screen. Your screen may have different pieces in different locations, so make sure to check carefully!
    • Tape may be covering the front camera and holding the screen cable in place.
    • There may be multiple protective liners covering the bottom of the screen.
    • Do not remove any of the liners from the screen adhesive around the perimeter yet.
    Chiedi a FixBot
    Aggiungi Commento
  29. Google Pixel 9a Screen Replacement: passo 29, immagine 1 di 3 Google Pixel 9a Screen Replacement: passo 29, immagine 2 di 3 Google Pixel 9a Screen Replacement: passo 29, immagine 3 di 3
    • Use your fingers to carefully remove any tape from the front camera cutout and screen cable.
    • If there's tape covering the top of the connector, use tweezers to remove it. Be careful not to pull on or tear the screen cable.
    Chiedi a FixBot
    Aggiungi Commento
  30. Google Pixel 9a Screen Replacement: passo 30, immagine 1 di 3 Google Pixel 9a Screen Replacement: passo 30, immagine 2 di 3 Google Pixel 9a Screen Replacement: passo 30, immagine 3 di 3
    • Carefully remove any liners covering the bottom of the screen.
    • The exposed copper underside of your Pixel's screen is very fragile. Even a small scratch or dent can damage the screen underneath. Be very careful not to touch it with your tools during the remainder of your repair.
    Chiedi a FixBot
    Aggiungi Commento
  31. Google Pixel 9a Screen Replacement, Lay the screen down: passo 31, immagine 1 di 1
    • Carefully lay your replacement screen display‑side‑down just to the left of your phone so you can reconnect the cable.
    Chiedi a FixBot
    Aggiungi Commento
  32. Google Pixel 9a Screen Replacement, Reconnect the screen: passo 32, immagine 1 di 2 Google Pixel 9a Screen Replacement, Reconnect the screen: passo 32, immagine 2 di 2
    • Align the screen press connector over its socket and gently press down with your finger—first on one of the short sides, then on the other—until the connector clicks into place.
    Chiedi a FixBot
    Aggiungi Commento
  33. Google Pixel 9a Screen Replacement, Install the cable cover: passo 33, immagine 1 di 3 Google Pixel 9a Screen Replacement, Install the cable cover: passo 33, immagine 2 di 3 Google Pixel 9a Screen Replacement, Install the cable cover: passo 33, immagine 3 di 3
    • Hook the bottom edge of the screen cable cover into its cutout and lay the cover into place.
    Chiedi a FixBot
    Aggiungi Commento
  34. Google Pixel 9a Screen Replacement: passo 34, immagine 1 di 2 Google Pixel 9a Screen Replacement: passo 34, immagine 2 di 2
    • Remember: The battery is exposed through a small cutout near the screen cable. Be very careful not to damage it with your tools.
    • Use a Torx Plus 3IP screwdriver to install the 1.7 mm‑long screw securing the cover.
    Chiedi a FixBot
    Aggiungi Commento
  35. Google Pixel 9a Screen Replacement, Remove the remaining liner: passo 35, immagine 1 di 3 Google Pixel 9a Screen Replacement, Remove the remaining liner: passo 35, immagine 2 di 3 Google Pixel 9a Screen Replacement, Remove the remaining liner: passo 35, immagine 3 di 3
    • Use tweezers or your fingers to remove the final adhesive liner from the perimeter of the screen.
    • If you applied adhesive directly to the frame, remove that remaining liner, holding the screen up out of the way as necessary, without straining the cable.
    • If the adhesive starts to peel up with the liner, check that you’ve pushed all of it into place with your spudger. If it continues to peel up, hold it down with the point of your spudger as you go.
    Chiedi a FixBot
    Aggiungi Commento
  36. Google Pixel 9a Screen Replacement, Put the screen onto the frame: passo 36, immagine 1 di 3 Google Pixel 9a Screen Replacement, Put the screen onto the frame: passo 36, immagine 2 di 3 Google Pixel 9a Screen Replacement, Put the screen onto the frame: passo 36, immagine 3 di 3
    • Carefully flip the screen over and align it over the frame.
    • Double check that the screen is aligned properly before pressing it into place, otherwise you may damage the screen through the copper backing.
    • Once aligned, press the screen into the frame.
    Chiedi a FixBot
    Aggiungi Commento
  37. Google Pixel 9a Screen Replacement: passo 37, immagine 1 di 3 Google Pixel 9a Screen Replacement: passo 37, immagine 2 di 3 Google Pixel 9a Screen Replacement: passo 37, immagine 3 di 3
    • Firmly press around the perimeter of the screen to secure the adhesive.
    • You can also hold your phone up and squeeze firmly around the perimeter to strengthen the adhesive bond. For an even more secure bond, lay your phone screen-down on a clean and flat surface underneath a few books overnight.
    • When powering on your phone for the first time:
    • Lay the phone screen-side up on a clean, flat surface. Remove the plastic liner from the screen, making sure nothing touches the phone while you do so (fingers, screen protectors, or cases).
    • To calibrate the display’s fingerprint reader, use Google’s Pixel Update and Software Repair tool.
    Chiedi a FixBot
    Aggiungi Commento
Conclusione
Congratulations on completing your repair!
To calibrate your display’s fingerprint reader, use Google’s Pixel Update and Software Repair tool.
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Altre 30 persone hanno completato questa guida.
Spencer Day
Membro da: 09/14/22
191.471 Reputazione
1.204 guide realizzate
iFixit Membro di iFixit
Staff
122 Membri
25.947 guide realizzate
5Commenti sulla guida
Sehr gelungene Anleitung.
Mir ist zwischendurch das Handy gestartet und ich konnte dann die PIN nicht eingeben. Mit einem Hard Reset (Powertaste > 20 sec drücken) und Neustart ging es dann. Der Fingerabdrucksensor musste ebenfalls kalibiert werden.
Und dank dieser tollen Anleitung habe ich ich mein Telefon wieder in Ordnung gebracht!
Florian - Rispondi Condividi
Existen reemplazos originales de la pantalla!?? O todos son modelos genéricos!??
Fercho Noriega - Rispondi Condividi
This guide saved me buying a new phone and at least 150! This was my first ever replacement and if anything knowing that it's ok if the old screen cracks and breaks as it comes off is the advice of give. Once the old one popped off installation of the ifixit new one took maybe 5 minutes. What a great guide!
Steve S - Rispondi Condividi
I replaced my screen on my pixel 9A I folded directions and I used the kit that I bought from I fix it now my phone screen will not turn on when I press the power button on my phone is the vibrates twice and nothing happens what did I do wrong please help
Sean M - Rispondi Condividi
Just completed this repair and the guide was great! I was dreading getting the original screen off. This guide mentioned you could use a heat mat to warm the adhesive on the original screen, which seemed like a good idea, but I didn't have one, so I left my phone face down on a heated desk blotter on its highest setting for about 10 minutes and the screen lifted off first try. I didn't need to use a heat gun, hair dryer, or alcohol to loosen it. Took less than 3 minutes to get the screen off and it was a clean separation with no residue. Also, I saw a recommendation on a video tutorial to pre-bend the screen connector cable into an S-shape (accordion fold) before setting the new screen in place so it lays flat and I thought that was a helpful tip not mentioned in this guide so I did that. 100% pleased with iFixit for this repair. Highly recommend!
Bethany Wink - Rispondi Condividi
Aggiungi Commento
Visualizza statistiche:
Ultime 24 ore: 75
Ultimi 7 giorni: 559
Ultimi 30 giorni: 2,715
Tutti i Tempi: 27,625
