Salta al contenuto principale
Garmin StreetPilot c320 Battery Replacement
Arturo Barajas
Arturo Barajas e 8 altri collaboratori
Ultimo aggiornamento il January 28, 2014
20 minuti
Difficile
Foto Azione
Introduzione
Vai al passo 1
Before disassembling anything be sure that the device is powered off. This installation is much easier for those familiar with the use of soldering irons. Those who have never used one before should look at this guide.
Cosa ti serve
Strumenti
Mostra di più…
  1. Garmin StreetPilot c320 Battery Replacement, Rear Case Assembly: passo 1, immagine 1 di 2 Garmin StreetPilot c320 Battery Replacement, Rear Case Assembly: passo 1, immagine 2 di 2
    • Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
    • Pry the outer frame off the perimeter of the rear panel assembly.
    • The cover will easily pop off.
  2. Garmin StreetPilot c320 Battery Replacement: passo 2, immagine 1 di 2 Garmin StreetPilot c320 Battery Replacement: passo 2, immagine 2 di 2
    • Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
    • Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
    • Be extremely cautious when separating both halves, as the rear case assembly is still attached to the front case assembly via a few connectors.
  3. Garmin StreetPilot c320 Battery Replacement: passo 3, immagine 1 di 1
    • Gently pull the battery cable connector from its socket on the motherboard.
    • The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
  4. Garmin StreetPilot c320 Battery Replacement, Battery: passo 4, immagine 1 di 1
    • Do not disconnect the black wire. Doing so may cause severe damage to your device.
    • Remove the two #00 Phillips screws securing the battery to the rear case assembly.
  5. Garmin StreetPilot c320 Battery Replacement: passo 5, immagine 1 di 2 Garmin StreetPilot c320 Battery Replacement: passo 5, immagine 2 di 2
    • Use a plastic opening tool to peel back the battery bracket.
    • Cautiously grasp the battery and lift it out of the device.
Conclusione
Cal Poly, Team 11-19, Maness Winter 2012 Membro di Cal Poly, Team 11-19, Maness Winter 2012
CPSU-MANESS-W12S11G19
4 Membri
4 Guide realizzate
2Commenti sulla guida
Where can I purchase a new Garmin StreetPilot c320 Battery Replacement battery?
john Lyons
11 Cavanaugh Cres
Terrace Bay Ontario
P0T2W0 Canada
John Lyons - Replica
Thanks' - I just found two of my old Garmin StreetPilot c320 units in storage.
This will be the project of the evening watching movies.
New 18650 Battery with charging protection is ready.
Thankfully these are ten times easier than the TomTom just completed with new battery install.
Cheers
Philscbx - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 6
Tutti i Tempi: 2,477
