Salta al contenuto principale
Game Boy Advance LCD Screen and Front Cover Replacement
Aldo Corona
Aldo Corona e 10 altri collaboratori
Ultimo aggiornamento il 24 ott 2022
20 - 30 minuti
Difficile
Tagliatore di Passi
Introduzione
Vai al passo 1
Use this guide to replace your cracked or broken LCD screen or front case.
Cosa ti serve
Ricambi
Strumenti
  • Phillips #1 Screwdriver
  • Spudger
    Spudger
  • Tri-point Y0 Screwdriver
    Tri‑point Y0 Screwdriver
Mostra di più…
Panoramica Video
  1. Game Boy Advance LCD Screen and Front Cover Replacement, Remove the Battery Cover/Batteries: passo 1, immagine 1 di 3 Game Boy Advance LCD Screen and Front Cover Replacement, Remove the Battery Cover/Batteries: passo 1, immagine 2 di 3 Game Boy Advance LCD Screen and Front Cover Replacement, Remove the Battery Cover/Batteries: passo 1, immagine 3 di 3
    • Take the battery cover off by releasing the locking tab and hinging the cover away. Remove the batteries inside the cover
    • Do not forget to remove the batteries! This applies to working with any electronic device as working with live electricity may damage the device or cause malfunctions
  2. Game Boy Advance LCD Screen and Front Cover Replacement, Unscrew the Back Panel: passo 2, immagine 1 di 2 Game Boy Advance LCD Screen and Front Cover Replacement, Unscrew the Back Panel: passo 2, immagine 2 di 2
    • Remove the six back panel screws using a Tri-wing Screwdriver.
    • Remove bottom back panel screw with a Phillips #1 screw driver. (Image #2)
  3. Game Boy Advance LCD Screen and Front Cover Replacement, Remove the Back Panel: passo 3, immagine 1 di 1
    • Remove the back panel by pulling away with one hand and the front secured in the other hand.
    • Removal of the back panel may cause shoulder buttons and side panels to come loose and fall off.
  4. Game Boy Advance LCD Screen and Front Cover Replacement, Remove Triggers: passo 4, immagine 1 di 2 Game Boy Advance LCD Screen and Front Cover Replacement, Remove Triggers: passo 4, immagine 2 di 2
    • Remove left and right triggers by lifting and pulling them away from the system.
    • Do the same for side panels
    • For finicky or jammed triggers only! Adjust and correct triggers and reassemble. Most jammed triggers are caused by buttons misplaced or jammed in its enclosure.
    my side pannel on the right is a little loose how do i fix it
    Mark - Replica
  5. Game Boy Advance LCD Screen and Front Cover Replacement, Remove the On/Off Switch: passo 5, immagine 1 di 1
    • Remove the gray On/Off Switch by pulling up and away from the unit. Replace with another switch if necessary.
  6. Game Boy Advance LCD Screen and Front Cover Replacement, Buttons and LCD Screen: passo 6, immagine 1 di 1
    • Remove the three screws on the circuit board with a Phillips #1 screw driver.
  7. Game Boy Advance LCD Screen and Front Cover Replacement: passo 7, immagine 1 di 2 Game Boy Advance LCD Screen and Front Cover Replacement: passo 7, immagine 2 di 2
    • Pull circuit board away from the front panel by pulling up at the bottom of the circuit board, keeping the top ribbon still connected.
    • Handle with care! The ribbon connecting the circuit board to the LCD screen can easily be damaged and will require replacement if broken.
  8. Game Boy Advance LCD Screen and Front Cover Replacement, Buttons: passo 8, immagine 1 di 3 Game Boy Advance LCD Screen and Front Cover Replacement, Buttons: passo 8, immagine 2 di 3 Game Boy Advance LCD Screen and Front Cover Replacement, Buttons: passo 8, immagine 3 di 3
    Attrezzo utilizzato in questo passaggio:
    • Remove the rubber button pads from their pockets.
    • Remove the plastic buttons and the D-pad from beneath the rubber pads with tweezers or by hand.
  9. Game Boy Advance LCD Screen and Front Cover Replacement, LCD Screen: passo 9, immagine 1 di 3 Game Boy Advance LCD Screen and Front Cover Replacement, LCD Screen: passo 9, immagine 2 di 3 Game Boy Advance LCD Screen and Front Cover Replacement, LCD Screen: passo 9, immagine 3 di 3
    • Use a spudger/tweezers/fingernail to unlatch the LCD ribbon port by pulling the grey tabs on the sides upwards (towards the top edge of the PCB).
    • Once the LCD ribbon port has been unlatched, the LCD ribbon should very easily slide out and can be removed with zero force using fingers or tweezers.
  10. Game Boy Advance LCD Screen and Front Cover Replacement: passo 10, immagine 1 di 3 Game Boy Advance LCD Screen and Front Cover Replacement: passo 10, immagine 2 di 3 Game Boy Advance LCD Screen and Front Cover Replacement: passo 10, immagine 3 di 3
    • Use the spudger to lift the screen from the front panel. Place the spudger in the space directly left of the D-pad.
    • The screen and the front panel is connected by a black tape that could rip if not removed carefully.
    Friendly warning. My LCD screen broke during this step. The tape can really hold it in there.
    Chris Raybould - Replica
    So do I! So the best solution to avoid it is to airdry the front cover to melt glue...
    Nicolas Puyet - Replica
Linea Traguardo
Altre 6 persone hanno completato questa guida.
Preparati per le riparazioni future
Acquista tutti
Cal Poly, Team 16-29, Maness Winter 2010 Membro di Cal Poly, Team 16-29, Maness Winter 2010
CPSU-MANESS-W10S16G29
5 Membri
62 Guide realizzate
1Commento della guida
I think the rating for this is too high. As long as you keep track of small screws and buttons & be wary of the ribbon cable, it's an easy replacement. But thank you for the detailed guide!
Noah - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 67
Tutti i Tempi: 19,087
