Fujifilm Finepix S1800 Shutter Button Replacement
Introduzione
Vai al passo 1Is the button to take a photo on your Fujifilm Finepix S1800 jammed or broken? This guide will show you step by step on how to replace the jammed or broken button.
Cosa ti serve
Unscrew the four 4mm screws on the left-hand side of the camera with the JIS #1 screwdriver.
Remove the three 2 mm screws from the back cover plate with the Phillips #000 screwdriver.
Gently lift the back cover away from the device.
Lift the flash.
Remove the two 4 mm screws from the top of the camera with the JIS #1 screwdriver.
Remove the two 2 mm screws underneath the plate with the Phillips #000 screwdriver.
Altre 2 persone hanno completato questa guida.
