Salta al contenuto principale
Fujifilm FinePix HS30EXR Motherboard Replacement
Andrew Scouten
Andrew Scouten e 4 altri collaboratori
Ultimo aggiornamento il January 5, 2024
30 minuti
Difficile
Introduzione
Vai al passo 1
This guide is meant to be used with the intention to replace the Fujifilm FinePix HS30EXR motherboard, which is the central part of the camera.
Warning: As the motherboard plays such a central role in the camera's function, the many wires and cables that connect the many parts to the camera together can be damaged in the replacement process. To avoid any excess damage, treat all wires and cables with care.
Cosa ti serve
Ricambi
Strumenti
Mostra di più…
  1. Fujifilm FinePix HS30EXR Motherboard Replacement, Frame: passo 1, immagine 1 di 1
    • Flip the camera so that the bottom is facing upwards.
    • With the Phillips #00 screwdriver, remove all four screws.
  2. Fujifilm FinePix HS30EXR Motherboard Replacement: passo 2, immagine 1 di 1
    • Flip the camera so that it is now on the right side.
  3. Fujifilm FinePix HS30EXR Motherboard Replacement: passo 3, immagine 1 di 1
    • Flip the camera so that it is now on the left side.
    • Move or remove the flap hiding the camera ports.
    • With the Phillips #00 screwdriver, remove all screws.
  4. Fujifilm FinePix HS30EXR Motherboard Replacement: passo 4, immagine 1 di 1
    • Flip the camera so that it is now on the top side.
    • With a spudger, pry off the highlighted metal piece of the camera.
  5. Fujifilm FinePix HS30EXR Motherboard Replacement: passo 5, immagine 1 di 1
  6. Fujifilm FinePix HS30EXR Motherboard Replacement: passo 6, immagine 1 di 1
    • Pull the LCD screen up and out of the way.
    • With the Phillips #00 screwdriver, remove the screws.
  7. Fujifilm FinePix HS30EXR Motherboard Replacement: passo 7, immagine 1 di 2 Fujifilm FinePix HS30EXR Motherboard Replacement: passo 7, immagine 2 di 2
    • With a spudger, pry off the frame.
    • If the frame does not easily dislodge after a few attempts, ensure that all screws are taken out.
  8. Fujifilm FinePix HS30EXR Motherboard Replacement, Motherboard: passo 8, immagine 1 di 1
    • Slowly and carefully pull the frame away to have a better view of the inside.
  9. Fujifilm FinePix HS30EXR Motherboard Replacement: passo 9, immagine 1 di 1
    • Peel back (or off) the black tape to expose more of the inside of the camera.
    • Flip the white switch of the highlighted chamber up, and that should unlock the ribbon cable from its compartment.
    • To see if this worked, gently pull the ribbon cable out of the compartment. It should come out without force.
  10. Fujifilm FinePix HS30EXR Motherboard Replacement: passo 10, immagine 1 di 1
    • Disconnect the ribbon cable.
  11. Fujifilm FinePix HS30EXR Motherboard Replacement: passo 11, immagine 1 di 1
    • With the Phillips #00 screwdriver, remove all five screws.
    • Remove the metal casing.
  12. Fujifilm FinePix HS30EXR Motherboard Replacement: passo 12, immagine 1 di 1
  13. Fujifilm FinePix HS30EXR Motherboard Replacement: passo 13, immagine 1 di 1
    • Ensure the four ribbon cables are disconnected from the motherboard.
    • Be aware, one is under the black tape.
  14. Fujifilm FinePix HS30EXR Motherboard Replacement: passo 14, immagine 1 di 1
    • Begin desoldering all four highlighted areas.
  15. Fujifilm FinePix HS30EXR Motherboard Replacement: passo 15, immagine 1 di 1
    • Remove the motherboard.
Conclusione
Baylor, Team S1-G2, Williams Fall 2018 Membro di Baylor, Team S1-G2, Williams Fall 2018
BU-WILLIAMS-F18S1G2
4 Membri
12 Guide realizzate
2 Commenti
have you instructions to remove power on and selector assembly?
renato.ciccone - Replica
have you istructions to remove the poweron switch asm. for the hs30exr?
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,356
