Introduzione
Use this guide to replace or clean the analog sticks on the Dualshock 4 controller.
Using the Phillips #00 Screwdriver, remove the four 6.0 mm screws securing the rear cover to the controller.
Detach the motherboard ribbon connecting the two sides of the controller by pulling it straight out with your fingers.
After the two halves are separated, place the top of the controller off to the side.
Remove the single 6.0 mm Phillips screw found below the battery retainer with the Phillips #00 Screwdriver.
Gently detach the touchpad ribbon connected to the motherboard using the blunt forceps. The touchpad ribbon is connected to the motherboard by a connector that flips to tighten and loosen. During reassembly, to reattach the ribbon, the plastic tray will need to be gently removed from the motherboard and the flip-lock flipped up.
Successful disassembly of the controller will result in the following three parts, respectively:
Motherboard Assembly
Front Cover
Rear Cover
Pull the analog stick covers straight off the joystick posts attached to the motherboard with your fingers.
Altre 79 persone hanno completato questa guida.
12 Commenti
So I followed all the steps, got the sticks in. But when I put the controller back together it Wouldent turn on. Do you guys have any clue as to what it could be?
Same exact thing happened to me, just wouldn't turn back on
Me too and all the reconnected cables are connected correctly, but it just won’t work.
Andy Hui -
Hope you guys still keep the parts, since the problem can be resolved by following the post below successfully. :)
Andy Hui -
i think you didn't put a wire in
