Salta al contenuto principale
Dell G15-5511 Gaming Right SSD (Slot 2) Replacement
Clay Eickemeyer
Clay Eickemeyer e 2 altri collaboratori
Ultimo aggiornamento il June 16, 2023
15 - 30 minuti
Moderato
Introduzione
Vai al passo 1
This guide will walk you through the process of replacing the right SSD in your Dell G15-5511 Gaming laptop.
Your laptop might not come with a standoff bracket to install an additional SSD. In this case, you'll need to purchase one.
Before you perform this repair, back up your existing SSD if possible. If you’re replacing the SSD where your operating system is installed, familiarize yourself with a disk cloning utility so you’ll be ready to migrate your data to the new SSD.
Cosa ti serve
Kit di riparazione
Questi kit contengono tutti i ricambi e gli strumenti necessari per completare questa guida.
Ricambi
Strumenti
Mostra di più…
  1. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Unfasten the back cover: passo 1, immagine 1 di 2 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Unfasten the back cover: passo 1, immagine 2 di 2
    • For your safety, discharge the battery below 25% and power down your device before disassembly.
    • Use a Phillips #1 screwdriver to remove the four 6.8 mm-long screws that secure the cover.
    • Use a Phillips #1 screwdriver to loosen the four captive screws.
  2. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Unclip the front corners: passo 2, immagine 1 di 2 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Unclip the front corners: passo 2, immagine 2 di 2
    • Insert an opening pick between the bottom-left corner of the back cover and the chassis.
    • Pry up to release the clips securing the back cover.
    • You'll hear a click whenever a clip is released.
  3. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement: passo 3, immagine 1 di 2 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement: passo 3, immagine 2 di 2
    • Insert your opening pick again between the bottom-right corner of the back cover and the chassis.
    • Pry up to release the remaining clips securing the back cover.
  4. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Remove the back cover: passo 4, immagine 1 di 3 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Remove the back cover: passo 4, immagine 2 di 3 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Remove the back cover: passo 4, immagine 3 di 3
    • Grip the front of the back cover and lift it away from the laptop.
    • Pull the back cover towards you to disconnect the clips along the top of the back cover.
    • Remove the back cover.
  5. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Disconnect the battery: passo 5, immagine 1 di 3 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Disconnect the battery: passo 5, immagine 2 di 3 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Disconnect the battery: passo 5, immagine 3 di 3
    • Use the flat end of a spudger to push the battery connector's square tab away from the socket and disconnect it.
  6. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Install the standoff: passo 6, immagine 1 di 3 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Install the standoff: passo 6, immagine 2 di 3 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Install the standoff: passo 6, immagine 3 di 3
    • The right SSD slot has two locations install the standoff bracket—one for the short M.2 2230 SSD, and one for the longer M.2 2280 SSD.
    • Use the flat end of a spudger to press the the bracket into the slot. The wings of the standoff will clip underneath the tabs of the slot.
    • Slide in the standoff edge of the bracket first.
  7. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Insert the SSD: passo 7, immagine 1 di 2 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Insert the SSD: passo 7, immagine 2 di 2
    • Grip your 80 mm-long (M.2 2280) SSD by the corners near the screw indent.
    • Slide the SSD into the socket.
  8. Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Fasten the SSD: passo 8, immagine 1 di 2 Dell G15-5511 Gaming Right SSD (Slot 2) Replacement, Fasten the SSD: passo 8, immagine 2 di 2
    • Use your Phillips #0 screwdriver to fasten the 4.2 mm-long screw to the SSD standoff.
Conclusione
To reassemble your Dell G15, follow these instructions in reverse order.
For general information on how to install a SSD, refer to this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Dell laptop answers community for help.
Clay Eickemeyer
Membro da: 09/19/22
81.653 Reputazione
455 Guide realizzate
Guide Team Membro di Guide Team
Staff
9 Membri
11.379 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 10
Ultimi 7 Giorni: 44
Ultimi 30 Giorni: 182
Tutti i Tempi: 4,668
