Compaq Evo N1000v Floppy Drive Replacement
Introduzione
Vai al passo 1Once a staple in personal computing, the floppy drive has become outdated. In the case of an older keyboard or retro setup of the computer, one may find that the floppy drive still plays a very important role. Whether one is trying to troubleshoot a malfunctioning floppy drive or looking to replace it entirely, knowing how to safely remove it without damage to the keyboard or other surrounding components is paramount. In this tutorial, we will take you through a step-by-step process of removing the floppy drive installed on your Compaq Evo N1000v keyboard without causing any damage.
Before you begin the repair, make sure to power off your laptop and unplug it from the charger.
Cosa ti serve
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
