Salta al contenuto principale
Brother MFC-490CW Print head Replacement
Henry Cho
Henry Cho e 8 altri collaboratori
Ultimo aggiornamento il August 13, 2024
40 minuti - 1 ora
Moderato
Introduzione
Vai al passo 1
If your Brother MFC-490CW printer has begun printing faded or streaked documents, has received a message requesting to change the printhead, or must have the printhead cleaned continuously between printing documents it might be time to replace the printhead.
If you are having difficulty with your printer, please review the troubleshooting page before proceeding with replacing the printhead.
The following guide will lead you step by step through the process of replacing the printhead. It is important to have the correct tools listed below and enough time set aside to efficiently replace the printhead.
Remember to always unplug any electrical device prior to beginning any work to prevent any electrical issues or risk being shocked.
Cosa ti serve
Strumenti
iFixit guadagna commissioni quando acquisti tramite questi link.
  1. Brother MFC-490CW Print head Replacement, Remove screws holding the front panel: passo 1, immagine 1 di 1
    • Use a Phillips #2 screwdriver to remove the three 12.1 mm screws holding the control panel in place.
  2. Brother MFC-490CW Print head Replacement, Unplug the panel from the rest of the printer: passo 2, immagine 1 di 3 Brother MFC-490CW Print head Replacement, Unplug the panel from the rest of the printer: passo 2, immagine 2 di 3 Brother MFC-490CW Print head Replacement, Unplug the panel from the rest of the printer: passo 2, immagine 3 di 3
    • Lift up the front panel from the device.
    • Gently lift up and disconnect the data cables that attach the panel to the printer.
  3. Brother MFC-490CW Print head Replacement, Separate the arm holding scanner unit: passo 3, immagine 1 di 3 Brother MFC-490CW Print head Replacement, Separate the arm holding scanner unit: passo 3, immagine 2 di 3 Brother MFC-490CW Print head Replacement, Separate the arm holding scanner unit: passo 3, immagine 3 di 3
    • Before removing the unit, apply 2 or 3 pieces of tape to secure the top and bottom of the unit.
    • Lift the scanner unit.
    • Gently twist the top portion of the arm.
    • The top portion should release from the scanner unit.
    • Rotate the arm approximately 45 degrees to remove the bottom portion of the arm from the device.
  4. Brother MFC-490CW Print head Replacement, Remove the scanner unit from the device: passo 4, immagine 1 di 3 Brother MFC-490CW Print head Replacement, Remove the scanner unit from the device: passo 4, immagine 2 di 3 Brother MFC-490CW Print head Replacement, Remove the scanner unit from the device: passo 4, immagine 3 di 3
    • Slide the unit either to the left or right and begin to push the unit away from the device.
    • Once one hinge is separated from the device, begin to remove the other hinge from the device.
    • Gently place the unit on the work surface.
    • Be careful not to pull too hard. the wires connecting the unit to the device must be removed.
  5. Brother MFC-490CW Print head Replacement, Remove left wire panels: passo 5, immagine 1 di 3 Brother MFC-490CW Print head Replacement, Remove left wire panels: passo 5, immagine 2 di 3 Brother MFC-490CW Print head Replacement, Remove left wire panels: passo 5, immagine 3 di 3
    • While it is not necessary to use a prying tool, using one may make it easier to lift the panels.
    • Starting from the back of the printer, use the exposed portion of the panel to gently pry the panel up from the printer.
  6. Brother MFC-490CW Print head Replacement, Remove right wire panel: passo 6, immagine 1 di 3 Brother MFC-490CW Print head Replacement, Remove right wire panel: passo 6, immagine 2 di 3 Brother MFC-490CW Print head Replacement, Remove right wire panel: passo 6, immagine 3 di 3
    • From the back of the device, use the exposed portion of the panel to begin to lift the panel away from the device.
  7. Brother MFC-490CW Print head Replacement, Removing left set of power cables: passo 7, immagine 1 di 3 Brother MFC-490CW Print head Replacement, Removing left set of power cables: passo 7, immagine 2 di 3 Brother MFC-490CW Print head Replacement, Removing left set of power cables: passo 7, immagine 3 di 3
    • Before removing the cables, create a diagram of the locations of the different cables with some tape or Post-Its.
    • Remove the three power cables that connect the scanner to the motherboard.
  8. Brother MFC-490CW Print head Replacement, Remove the ground wire: passo 8, immagine 1 di 2 Brother MFC-490CW Print head Replacement, Remove the ground wire: passo 8, immagine 2 di 2
    • Use a Phillips #2 screwdriver to remove the 12.1 mm screw to remove the ground wire.
  9. Brother MFC-490CW Print head Replacement, Remove data cable: passo 9, immagine 1 di 3 Brother MFC-490CW Print head Replacement, Remove data cable: passo 9, immagine 2 di 3 Brother MFC-490CW Print head Replacement, Remove data cable: passo 9, immagine 3 di 3
    • Gently pull the data cable away from the motherboard.
    • Slide the cable out of the slots to remove the cable from the device.
    • The scanner unit is now separated. Place the unit and ground screw in a safe part of the workspace until needed for re-assembly.
  10. Brother MFC-490CW Print head Replacement, Remove front screws of the device cover: passo 10, immagine 1 di 1
    • Use the Phillips #2 screwdriver to remove the three 14.1 mm screws.
    • Use the Phillips #2 screwdriver to remove the 12.1 mm screw.
    The diagram shows two of each size, but the instructions list (3) 14.1mm and "the" 12.1mm screws.
    Joseph Usher - Replica
  11. Brother MFC-490CW Print head Replacement, Remove the paper tray: passo 11, immagine 1 di 1
    • Pull the paper tray away from the device.
  12. Brother MFC-490CW Print head Replacement, Remove center screw near the USB and ethernet ports: passo 12, immagine 1 di 1
    • Use the Phillips #2 screwdriver to remove the 8 mm screw at the center of the device.
  13. Brother MFC-490CW Print head Replacement, Remove rear panel screws: passo 13, immagine 1 di 1
    • Use the Phillips #2 screwdriver to remove the two 14.1 mm screws holding the panel in place.
  14. Brother MFC-490CW Print head Replacement, Remove red power cable: passo 14, immagine 1 di 1
    • This cable needs to be removed to allow the removal of the device cover.
    • Gently remove the red power cable from the motherboard.
  15. Brother MFC-490CW Print head Replacement, Remove paper jam clear cover: passo 15, immagine 1 di 2 Brother MFC-490CW Print head Replacement, Remove paper jam clear cover: passo 15, immagine 2 di 2
    • Gently push the upper-left tab of the cover and separate the hinged portion of the cover from the rest of the device.
    • Once one side is free, slide the other side away from the device.
    • Pull the cover away from the device.
    Step 15 It takes more than a gentle push. A fingertip is not sufficient. Use the spudger carefully
    Naldo - Replica
  16. Brother MFC-490CW Print head Replacement, Remove the device cover: passo 16, immagine 1 di 3 Brother MFC-490CW Print head Replacement, Remove the device cover: passo 16, immagine 2 di 3 Brother MFC-490CW Print head Replacement, Remove the device cover: passo 16, immagine 3 di 3
    • Using a spudger, loosen the two clipped portions of the cover located at the back-center of the cover.
    • Once the clips are free the rest of the cover can be lifted up and away from the device.
    Pull the front of the cover up about 2-3 inches and the two pictured clips at the back will release easier.
    Naldo - Replica
  17. Brother MFC-490CW Print head Replacement, Release the clear print head guide wire: passo 17, immagine 1 di 2 Brother MFC-490CW Print head Replacement, Release the clear print head guide wire: passo 17, immagine 2 di 2
    • Gently pull the wire to the left so the end of the wire is released.
    • Slide the wire away from the top of the print head unit.
  18. Brother MFC-490CW Print head Replacement, Releasing the print head from the carriage: passo 18, immagine 1 di 2 Brother MFC-490CW Print head Replacement, Releasing the print head from the carriage: passo 18, immagine 2 di 2
    • Using a spudger, press down on the plastic housing of the carriage that the print head rests on.
    • Slide the print head to the left of the device.
  19. Brother MFC-490CW Print head Replacement, Removing the print head from the rails.: passo 19, immagine 1 di 3 Brother MFC-490CW Print head Replacement, Removing the print head from the rails.: passo 19, immagine 2 di 3 Brother MFC-490CW Print head Replacement, Removing the print head from the rails.: passo 19, immagine 3 di 3
    • Slide the print head until it is at the end of the rail.
    • Push the print head unit towards the back of the device and lift the unit from the back rail.
    • Gently release the other end of the print head to remove it from the front rail.
    Do Step 20 before doing Step 19.
    Naldo - Replica
  20. Brother MFC-490CW Print head Replacement, Release the print heat conveyor: passo 20, immagine 1 di 1
    • Using the spudger, press the spring section of the white pulley.
    • Release the conveyor from the pulley while the spring is still compressed.
    • Remove the conveyor from the gear on the other side of the device.
    • Optional: Slide the conveyor off the print head.
    Doing Step 20 prior to doing Step 19 will make Step 19 easier and likely less damaging to the conveyor belt.
    Naldo - Replica
  21. Brother MFC-490CW Print head Replacement, Opening the top print head cover.: passo 21, immagine 1 di 1
    • Squeeze the ends of the cover, then release the cover, revealing the processor unit.
    Not even close. Three clip points need to be released before the cover will come off.
    #1. Un-clip the end nearest to where the ink tubes attach.
    #2 and #3. Release the clips on each side of the cover where his left thumb and pointer finger are holding the cover.
    Naldo - Replica
  22. Brother MFC-490CW Print head Replacement, Remove the data cable from the print head processing unit.: passo 22, immagine 1 di 2 Brother MFC-490CW Print head Replacement, Remove the data cable from the print head processing unit.: passo 22, immagine 2 di 2
    • Slide the black cap away from the port.
    • Slide the data cable out of the port.
    Some basic knowledge of how these tape connections function is very helpful.
    Naldo - Replica
  23. Brother MFC-490CW Print head Replacement, Remove print head processor unit: passo 23, immagine 1 di 3 Brother MFC-490CW Print head Replacement, Remove print head processor unit: passo 23, immagine 2 di 3 Brother MFC-490CW Print head Replacement, Remove print head processor unit: passo 23, immagine 3 di 3
    • Lift the processor out of the print head.
    • Slide the cables attached to the processor away from the print head unit.
  24. Brother MFC-490CW Print head Replacement, Remove the inkjet nozzle unit.: passo 24, immagine 1 di 3 Brother MFC-490CW Print head Replacement, Remove the inkjet nozzle unit.: passo 24, immagine 2 di 3 Brother MFC-490CW Print head Replacement, Remove the inkjet nozzle unit.: passo 24, immagine 3 di 3
    • Remove the metal clip holding the nozzle unit.
    • Lift the unit from the rest of the print head unit.
    For Step 24, Kat makes a very good point about the rubber gasket that lies between the nozzle unit and the print head. If you don’t transfer that gasket, you will probably wind up with ink running everywhere but onto your paper.
    Naldo - Replica
    Nothing is mentioned about transferring the conveyor belt. Do it carefully.
    Naldo - Replica
    Where can one buy a replacement printhead?
    nrpardee - Replica
Conclusione
To reassemble your device, follow these instructions in reverse order
Altre 28 persone hanno completato questa guida.
Henry Cho
Membro da: 10/29/14
1.037 Reputazione
2 Guide realizzate
UMass Dartmouth, Team 4-4, Miles Fall 2014 Membro di UMass Dartmouth, Team 4-4, Miles Fall 2014
UMASSD-MILES-F14S4G4
3 Membri
11 Guide realizzate
11Commenti sulla guida
I did follow this guide for a Brother MFC-6490CW although they are not identical it was very helpful for me to follow up to the removal of the print head as I only wanted to clean some blocked nozzles but the principle was the same
crystalbic - Replica
*Note my new print head did not come with the rubber gasket that the sits between the inkjet nozzle unit and the new print head, remember to look for it and move it to the new one.
Kat - Replica
Also after putting the new print head on the inkjet nozzle unit lines / tubing is full of air and needs to be primed in order for the ink to flow again because there is a huge air bubble in the print head.
To do this best way is to (if it is back together without pulling it apart):
1) Start the printer to print a page and when it has started while the paper is still under the print head disconnect the power that way the print head is in the middle and not parked on the right side.
2)Put a couple pieces blotting paper or in my case I used folded up paper towel under the print head
3)Take out all the ink cartridges and using a large syringe and a small tube full of a cleaning solution or use a kit that u can buy online.
Kat - Replica
*Caught off guard not knowing I would need to do this I improvised breaking an old ink cartridge and cutting off the ink nozzle flush with the cartridge so i had the female rubber grommet end and about a ½" piece of plastic tube, I then cut off a bit of spare air hose for my fish tank and got an empty squeeze sauce bottle with a long nozzle and put in some alcohol. I put the plastic tube into the female end and the other end onto the sauce bottle.
Connect it to where the ink cartridge goes in and push the fluid through the line till you see ink / fluid come out of the print head, then do the other lines possibly changing the blotting paper in between colors depending how much mess it makes
Kat - Replica
Then replace the ink cartridges and run a cleaning or to and print a few full color pages .... dont panic if the colors dissapears for a while and it comes out blank because the alcohol needs to fully come out but the new ink will flow up the tubes after the alcohol .... this actually took quite a while to start printing colors again but it did get there and a few more cleans once it was and it was fantastic
The Printer has not printed as well for years :)
Kat - Replica
Great advice, Kat, Thank you! I wouldn't have thought of doing that.
Joseph Usher -
Thank you for the information removing those ink pipe was difficult but your guide helped
Attibutt - Replica
Hi do you have to do step 18 in reverse when you reassemble?
Djdje - Replica
Easier than I thought, but better with gloves ;-)
Andrea - Replica
Bought a new print head for £25. Then I read this guide and decided it looked pretty difficult and my printer Brother MFC-J4510DW c.2014 would have too many differences to confidently use this guide. Instead I found a technique to clean the old print head and it worked. Clean the print head with a paper towel soaked in Windex .. or as we say in UK: a folded piece of kitchen roll soaked in a little window cleaner (my window spray says it contains "5% anionic surfactant" and vinegar - worked well). This is good: https://www.youtube.com/watch?v=Itl3UsPZ...
Peter Fennell - Replica
sfter putting together and turning it on it makes a stuttering noise and will not do anything, don't know what is wrong. any ideas?
marilla - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 55
Ultimi 30 Giorni: 215
Tutti i Tempi: 41,375
