Salta al contenuto principale
Beats Pill 1.0 Speaker Replacement
Dylan Cooper Dalrymple
Dylan Cooper Dalrymple e 9 altri collaboratori
Ultimo aggiornamento il July 19, 2024
10 - 15 minuti
Facile
Strada Panoramica
Introduzione
Vai al passo 1
This guide will serve as a reference on how to replace the speakers on the Beats Pill 1.0. In order to follow this guide, you will need to have the Beats Pill partially disassembled. We would recommend going through our general disassembly guide for guidance on how to disassemble the Pill. For this guide, we will assume that you have fully disassembled the product according to our general disassembly guide.
Cosa ti serve
Strumenti
  • Phillips #0 Screwdriver
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Mostra di più…
  1. Beats Pill 1.0 Speaker Replacement, Removing the Case Screws: passo 1, immagine 1 di 3 Beats Pill 1.0 Speaker Replacement, Removing the Case Screws: passo 1, immagine 2 di 3 Beats Pill 1.0 Speaker Replacement, Removing the Case Screws: passo 1, immagine 3 di 3
    • Using the spudger, create space between the speaker covers and then remove.
    • On the underside of the device, remove the rubber stand with the BeatsPill logo on it.
    • Using an ESD-safe Phillips #0 screwdriver, remove the four screws that were underneath the rubber stand.
    I bought a brand new Beats Pill 1.0 online last week the first night it seemed to work all right the next day I charged it I plugged it in and it was crackling on the left hand side from the front and now the whole volume of both sides very low but it is still getting a Bluetooth connectivity I tried to reset it by holding the baby and the power button to get this thing in the back to flag it would not reset that way any suggestions I meant it is for a lot of money I paid $170 I thought I was getting a brand new device
    Steven Sudnick - Replica
  2. Beats Pill 1.0 Speaker Replacement, Removing Center Cover: passo 2, immagine 1 di 3 Beats Pill 1.0 Speaker Replacement, Removing Center Cover: passo 2, immagine 2 di 3 Beats Pill 1.0 Speaker Replacement, Removing Center Cover: passo 2, immagine 3 di 3
    • Remove the two screws with a Phillips #0 screwdriver.
    • Slowly remove the center band and two clip rings until the adhesive separates. Sit to the side the clip rings and the center band
  3. Beats Pill 1.0 Speaker Replacement, Separate the Device: passo 3, immagine 1 di 3 Beats Pill 1.0 Speaker Replacement, Separate the Device: passo 3, immagine 2 di 3 Beats Pill 1.0 Speaker Replacement, Separate the Device: passo 3, immagine 3 di 3
    • Use the spudger to pry the device apart along its seam, starting in the middle.
    • Open the device to separate the front and back panels.
  4. Beats Pill 1.0 Speaker Replacement, Disconnect Speaker Wiring: passo 4, immagine 1 di 2 Beats Pill 1.0 Speaker Replacement, Disconnect Speaker Wiring: passo 4, immagine 2 di 2
    • Carefully remove the yellow, red, black, and white wires from the motherboard.
    • Ground yourself when touching the motherboard.
  5. Beats Pill 1.0 Speaker Replacement, Disconnect NFC Sensor Wiring: passo 5, immagine 1 di 2 Beats Pill 1.0 Speaker Replacement, Disconnect NFC Sensor Wiring: passo 5, immagine 2 di 2
    • Carefully remove the black and red NFC sensor wires.
  6. Beats Pill 1.0 Speaker Replacement, Disconnect Control Wiring: passo 6, immagine 1 di 2 Beats Pill 1.0 Speaker Replacement, Disconnect Control Wiring: passo 6, immagine 2 di 2
    • Carefully remove the control cables (4 black, 1 red).
  7. Beats Pill 1.0 Speaker Replacement, Speaker: passo 7, immagine 1 di 2 Beats Pill 1.0 Speaker Replacement, Speaker: passo 7, immagine 2 di 2
    • Using the Phillips #0 screwdriver, unscrew the two screws that holds the speakers down.
  8. Beats Pill 1.0 Speaker Replacement: passo 8, immagine 1 di 1
    • Each speaker is held down by two clips. On the front face of the speaker, push the speaker outward while pushing one of the clips that holds it down to the side. Repeat this on the other speaker and clip. The speakers should pop out.
    What happens after step 8? Does this help my blown speaker?
    Haley - Replica
    Where to buy these?
    jalecxq - Replica
Conclusione
Altre 9 persone hanno completato questa guida.
USF Tampa, Team 5-4, Blackwell Fall 2015 Membro di USF Tampa, Team 5-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G4
4 Membri
13 Guide realizzate
10Commenti sulla guida
Do you have a link to the speakers that are used for the speaker pill, the current one seems to be broken and I cant find the replacements anywhere
justin perez - Replica
Just wanted to add a comment regarding where to find the actual replacement speakers for the Beats Pill 1.0. I quite certain that the over all size of each individual speaker is 1" including the plastic bezel around the speaker. The actual size of the speaker itself is 3/4" and I believe I have found a replacement speaker to use if one of the speakers in your Beats Pill 1.0 gets blown or damaged. Below is the link to the replacement speaker, found on www.partsexpress.com. It looks almost identical to the stock speaker installed in the Pill 1.0, minus the custom bezel around the speaker that is used to secure the speakers inside the Pill.
http://www.parts-express.com/tymphany-pm...
Buying all 4 speakers at once saves you 75 cent compared to the price of buying just a single speaker.
Hope this helps anyone looking for replacement speakers for their Beats Pill 1.0
Brad Shirer - Replica
I just got all 4 new speakers to replace the older ones as the rubber rims have all soften and sort of disintegrated/damaged. Only problems with the replacement speakers plastic body are not same as original ones. So the speakers won’t fit the 2 clips, so almost no way to secure the speakers. Probably need to be Super glue.
Victor -
I plugged my speaker in because it needed a charge and the metal piece inside the speaker went into it help
Tanner McKinley - Replica
Where can i pay for a new speakers??, help me please…
j.j.g.n - Replica
why wouldn’t i want to replace the original speakers with authentic beats replacement speaker that are the exact duplicates?, i will not replace the original beats speakers with substandard replacements that don’t fit properly and at best are nothing but a poor rigged up $@$*
alexanderbroche - Replica
Anyone know where to get the EXACT OEM replacement speakers?
Jason Hoag - Replica
I want a new replacement speaker please
Onujiogu - Replica
I plugged the beats charger into my beats pill plus and nothing happened and it will not charge, what can I do to fix the problem.or where can I send the speaker for repairs?
Need help please to fix this problem
Bruce Ard - Replica
Where i can buy the speakers? i can't find it anywhere
Filippo Notari - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 59
Ultimi 30 Giorni: 220
Tutti i Tempi: 41,036
