Salta al contenuto principale
Auking M8-F PCB Button Panel Replacement
Aubrey Haynes
Aubrey Haynes e 4 altri collaboratori
Ultimo aggiornamento il December 27, 2023
25 - 45 minuti
Moderato
Introduzione
Vai al passo 1
Use this guide to replace the power panel on your AuKing M8-F projector.
The power panel is a component found on devices responsible for controlling whether the device is powered on and functioning or turned off, conserving power and the state of the other components. A faulty power panel could lead to problems like turning the device on and off. This could over time damage the condition of certain components making them less functional.
If you are experiencing issues with the power button or the rest of the button panel, please take a look at the troubleshooting page to find another possible cause for your condition. If no other condition matches your problem, then the power panel might be the problem.
Before continuing this guide, be sure to turn off your projector completely.
Cosa ti serve
Strumenti
Mostra di più…
  1. Auking M8-F PCB Button Panel Replacement, PCB Button Panel: passo 1, immagine 1 di 2 Auking M8-F PCB Button Panel Replacement, PCB Button Panel: passo 1, immagine 2 di 2
    • Make sure that the device is unplugged from any power source before attempting any repairs.
    • Flip the projector on its opposite side.
    • Remove all six of the 11 mm screws using a Phillips #1 screwdriver.
    • Remove the two 14 mm screws using a Phillips #1 screwdriver.
  2. Auking M8-F PCB Button Panel Replacement: passo 2, immagine 1 di 2 Auking M8-F PCB Button Panel Replacement: passo 2, immagine 2 di 2
    • Carefully prop open the top of the projector.
    • Disconnect the cable attached to the top lid.
    • Remove the top lid.
  3. Auking M8-F PCB Button Panel Replacement: passo 3, immagine 1 di 2 Auking M8-F PCB Button Panel Replacement: passo 3, immagine 2 di 2
    • Remove the wire cord attached to the top panel to separate both the top panel and the wire cord.
  4. Auking M8-F PCB Button Panel Replacement: passo 4, immagine 1 di 3 Auking M8-F PCB Button Panel Replacement: passo 4, immagine 2 di 3 Auking M8-F PCB Button Panel Replacement: passo 4, immagine 3 di 3
    • Remove six of the 5 mm screws using a Phillips #00 screwdriver to detach the power panel.
    • Remove the power panel.
Conclusione
Aubrey Haynes
Membro da: 09/13/23
277 Reputazione
3 Guide realizzate
1Commento della guida
I have a problem not covered here.
When I power up, only a red light is lit. Any ideas?
sasquachnw@duck.com
sasquachnw - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 10
Tutti i Tempi: 127
